September 23, 2026, 14:47:35 pm
Wheel Spacers
Topic: Wheel Spacers (Read 5945 times)
Chris W
Wheel Spacers
July 05, 2008, 16:39:25 pm »
I am running Gas Burners with re-drilled drums on short axles and the tire just kisses the spring plate and upper body mount. Would a 5 mm spacer be acceptable on each wheel stud?
Re: Wheel Spacers
July 05, 2008, 16:50:39 pm »
Convert to type 3 drums or rear discs. Get a little more track width and increase braking power.
ian c
Re: Wheel Spacers
July 05, 2008, 17:21:11 pm »
a quality made hub-centric spacer will do , as long as your wheel studs are long enough .
porsche sell iirc 6mm and 17mm . people like ruf and techart sell various sizes .
if you follow zachs advice , and get the spacing right and upgrade the brakes in one swoop , this has got to be better than spacers .
(o\ ! /o)
John Rayburn
Re: Wheel Spacers
July 11, 2008, 19:18:39 pm »
Type 3 drums will give you about 1/2 inch or 13mm.
I also park at Nick's.
Chris W
Re: Wheel Spacers
July 11, 2008, 20:02:32 pm »
After measuring I don't have enough room on the studs for spacers so........I might swap for long axles or Type 3 brakes. 13mm would be perfect I just need to find some brakes.
