November 02, 2026, 22:31:15 pm
| | |-+  Project `55
Pages: 1 2 3 [4] 5 6 ... 14 Print
Author Topic: Project `55  (Read 308444 times)
kev d
« Reply #90 on: August 12, 2009, 13:35:26 pm »
Nice work Kev, like the sill's simple solution to the problem  Cool
Missed the thead on your car so far somehow flow under my radar , but im a likein what I see  Smiley
Cheers bud Wink
Kafur1
« Reply #91 on: August 20, 2009, 02:47:15 am »
really nice job! keep up the good work.
« Reply #92 on: August 20, 2009, 04:51:33 am »
Decided to do a bit of bodywork while I was waiting for additional cage peices to arrive from Houser`s Smiley
I`ve stripped the paint off all the outer panels & it looks a whole lot better, it`s been a long time since this car had a shine Grin
Started on some of the bigger dents too, I`ve got a single side spot welder / dent puller & its brilliant for pulling dents on double skinned areas, (not that I`ve got many of those...), start on the lowest spot in the damaged area and work out using a body file to show the low areas.
It also lets you keep strain on while working stretched areas with the hammer & dolly.
Hi Kev I See The Tar Babe Project Body in the Back Ground Whats the Story on it??
« Last Edit: August 20, 2009, 04:54:46 am by Shubee2 (DSK) » Logged
Black Sheep
less is more
« Reply #93 on: August 20, 2009, 07:53:06 am »
Youve resisted the temptation to roof chop it then Kev . think I would have been steight onto that with the Babe to use as the perfect guide  Cool
13.03 @ 98mph
jamiep_jamiep
« Reply #94 on: August 20, 2009, 09:26:00 am »
Great work Kev!
« Reply #95 on: August 20, 2009, 09:31:07 am »
We could tell you, but then we'd have to kill you... Wink
kev d
« Reply #96 on: September 01, 2009, 10:47:03 am »
Got a little bit more done on the cage the other week & its coming together Grin
I`ve got the tubes cut for the LH side sill & door bars but probably won`t get back on it for a few weeks as I`m away again this thursday Sad
Hope to have it on its wheels soon & sort out the ride height & gearbox mounts etc.
Cheers,
Kev
« Reply #97 on: September 01, 2009, 14:31:58 pm »
mmm tarbabe still progress Huh  Grin Grin , by the way good work kev  Wink
« Reply #98 on: September 01, 2009, 16:30:34 pm »
Just for you Fabs, if you look at the front of Tar Babe in that first picture, you will see an area of bent red metal where the bumper mount used to be. This was damage sustained when Greg Aronson spun the Tar Babe and hit the guard rail That was when he decided to sell the car to Ron and Mike. The damage was crudely 'fixed' with bondo, but when we dug it out, you could still see the original paint – and bent inner fender!
OK Kev, back to work... Wink
« Reply #99 on: September 01, 2009, 16:37:41 pm »
thx keith  Wink
Tekken
www.proturbovw.com
« Reply #100 on: December 11, 2009, 20:56:31 pm »
Hey Kev,nice work!
Updates?
Best regards.
Stian
Russell
« Reply #101 on: December 11, 2009, 23:22:08 pm »
kevs currently in Korea on holiday (working)  Grin
Best Regards
Russell
kev d
« Reply #102 on: December 12, 2009, 23:44:17 pm »
Hi Stian,
No updates to report unfortunatley Sad
I have bought some goodies though Grin
Life getting in the way again!
I`m going home this weekend & hope to get a bit of garage time next month.
Anything new going on with your car?
Cheers,
Kev
 Wink
Tekken
www.proturbovw.com
« Reply #103 on: December 13, 2009, 15:48:34 pm »
Hi Stian,
Cheers,
Kev
What goodies..? Wink
Only the front beam left on my car now.More rollcage,new clutch and  clutch system,new engine plans ++ Lips Sealed
 Wink
kev d
« Reply #104 on: December 14, 2009, 07:38:03 am »
Sounds promising Cool
I'd be happy to look after you're old engine & box if you don't need them... Wink
« Reply #105 on: December 14, 2009, 11:51:38 am »
1st tea is on you then? see you tommorow if your back?
kev d
« Reply #106 on: December 15, 2009, 00:02:04 am »
Normal teaboy duties for me starting saturday then?? Wink
Seeya!
kev d
« Reply #107 on: January 24, 2010, 13:37:40 pm »
First couple of days back in the garage for a while Grin
Got the body lifted off on Friday night & spent Saturday welding up the cage, also made the beam clamps / connector tubes.
Theres still plenty to do on it - gearbox & shifter mounts, steering column & seat mounts plus all the little tabs etc, but its moving forward anyway!
Decided to go back to a stock width beam because I`ve got the wheels & tyres I'm using which should'nt have any clearance issues & I think a slightly wider footprint will help with stability.
Hopefully have it powder coated in the next couple of months though.
Also got a set of front runners & slicks for it, looking forward to seeing these holding it of the ground rather than axle stands.. Wink
kev d
« Reply #108 on: January 29, 2010, 22:33:03 pm »
Its been a busy week on the oval at last Grin
Thats the chassis pretty much done except for the gearbox mounts & vertigate shifter, there's still a few mounting tabs etc to do but nothing major.
My chief advisor Wink reckons a hydraulic clutch is worth fitting, so I need to work out the best way of doing that.
The body went back on tonight and the next stage will be fitting the steering column, after that I'm going to begin the alloy panels for the front & rear bulkheads.
That little lot should keep me busy for a time Wink
kev d
« Reply #109 on: March 08, 2010, 17:00:35 pm »
Not really an update yet but I collected these bits today.. Cool
Now I've just got to work out how it all goes together Roll Eyes
Rocket Ron
It's old school for a reason
« Reply #110 on: March 08, 2010, 17:43:15 pm »
Kev
Having real problems getting this bonnet to you
to big for a standard pallet, too big for parcel force and all the other carriers want you to open an account a a min monthly charge of £50
Is anyone coming to volks world show from your neck of the woods ?? or maybe Richie when he's down again ?
Or maybe Russel has a pallet / carrier account  my post code at work is DT11 0AE if he has.
any ideas ??
Ron
13.12 @ 101.84
Grooving out on life
kev d
« Reply #111 on: March 08, 2010, 18:45:42 pm »
No worries Ron, I might be down for VoWo after all & might manage to sort something out Smiley
Thanks for trying anyway Cool
Cheers,
Kev
JSL
« Reply #112 on: March 11, 2010, 11:54:53 am »
Looks amazing Kev!
Good work!!
J
kev d
« Reply #113 on: March 11, 2010, 21:46:40 pm »
Looks amazing Kev!
Good work!!
J
Cheers bud!
Got a bit of garage time this week & managed to get a bit done Grin
The steering column's now mounted using a stock colapsable column mounted off a bracket on the dash bar and a 1200 bug top housing trimmed back to just the bearing carrier, falls just in the right place & comfortable to use.
Also started cutting card templates for the alloy front bulkhead, looks like it'll work out with 4 pieces, just need to finalise what pedal box I'm using so I can work around the master cylinders.
Main job has been fitting the T2 gearbox, it's tacked in position now but I'm going to fit the shifter & rods to make sure it all works before final welding.
Looks like 1 rod will sit above the tunnel & 2 underneith, either way I've chopped out all the pipework to make room - and I did'nt think there was anything else left to cut off this thing..
ESH
« Reply #114 on: March 13, 2010, 13:05:01 pm »
It's not done yet?  Shocked
Apologies Kev but one of the Gasser Garage crew, (can't remember who, had a funny accent), was giving me shit so I thought I'd throw some back.  Smiley
kev d
« Reply #115 on: March 13, 2010, 19:10:23 pm »
Nah must be mistaken matey, none of us would dream of having a dig at someone elses expense.. Wink
Seeya soon Grin
kev d
« Reply #116 on: March 16, 2010, 22:42:04 pm »
Its in Grin
Needs some plating & tidying up on the tunnel but its fitted & seems to work ok Shocked
Looks like I might be at VoWo after all with a big shopping list Wink
« Reply #117 on: March 16, 2010, 22:48:30 pm »
looking good kev, will you be at VoWo all weekend?
kev d
« Reply #118 on: March 16, 2010, 22:54:00 pm »
Not sure yet, was due away on a job but now looks like I`m home till the 2nd so probably will be Cool
See you there??
« Reply #119 on: March 16, 2010, 22:57:14 pm »
yep, not sure what day yet, but i have weekend ticket, so can play it cool
