October 13, 2026, 08:07:44 am
8600 miles and still 4 lobes
Topic: 8600 miles and still 4 lobes (Read 23094 times)
July 14, 2008, 00:54:09 am »
tore 2165 down, cam is still a cam, all but one lifter look new (the one shows slightest wear).
not a plug, but I am happy with my Valvoline.
Re: 8600 miles and still 4 lobes
July 14, 2008, 01:02:41 am »
That the FK-45. How do the lifter bores look? What are the specs on the new cam? You staying with the 2165?
July 14, 2008, 01:04:28 am »
Good news, Jim!!
July 14, 2008, 02:15:37 am »
What are the lifters? I probably missed it if you told us.
July 14, 2008, 04:21:35 am »
Bugpack-Tayco lifters, Valvoline 15W40 Premium Blue, with dose of a ZDDP additive.
it is going back together this week and next as 2165cc
July 14, 2008, 08:37:45 am »
How's the sweater holding up?
airstuff
July 14, 2008, 09:39:47 am »
Quote from: Jim Ratto on July 14, 2008, 00:54:09 am
Hey Jim,
any pics of the lifters and the cam?
July 14, 2008, 10:54:20 am »
good to hear jim!
i hope i can expect the same longevity of my engle cam and bugpack-tayco lifters if i can find some good oil
DVK ~
July 14, 2008, 12:32:23 pm »
Wait—only 4 lobes? So half of them
did
go flat?
July 14, 2008, 14:13:48 pm »
Quote from: javabug on July 14, 2008, 12:32:23 pm
did
go flat?
benssp
www.callookvw.com
July 14, 2008, 14:55:23 pm »
did
go flat?
cam not lifters
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Casey
July 14, 2008, 16:21:56 pm »
Great news Jim! I finally took the diaper off mine. Now dipstick likes to push out.
Tony M
July 14, 2008, 16:28:00 pm »
Glad to hear that Jim - This gives hope to all that have had lifter problems - Good to see that some parts are still made with quality -
July 14, 2008, 16:53:15 pm »
Quote from: Jim Ratto on July 14, 2008, 14:13:48 pm
did
go flat?
Hey now don't I look dumb! I was having an OHC moment—2 lobes per cyl.
Go ahead and ban me from technical posts.
July 14, 2008, 18:51:35 pm »
[Valvoline™ plug]not a plug, but I am happy with my Valvoline.[/Valvoline™ plug]
There, I fixed your post for ya, Jim.
Joking aside, I'm not surprised that Valvoline holds up in h.p. air-cooled engines. That's all I've ever used in mine. Seems to work rather well. But oil preferences are like our opinions... we all have one. So, I'm guessing that you're gonna go with the same cam on the rebuild, yes?
July 14, 2008, 19:03:06 pm »
Quote from: DKK_Fred on July 14, 2008, 18:51:35 pm
Hi Mark,
I did a bunch of researching on the oil for this last motor after having a cam failure in the previous, even though I did what I "thought" was the correct thing to do...i.e. synthetic. I had no idea how bad some synthetics are fro flat tappet hp stuff, like my Bug motor. Thanks to LN Engineering's posting on engine oil for Porsche and VW's I found that this Valvoline has the "stuff" we need to make things live. No I am not going back to FK45, not because it is worn and certainly not because it eats lifter bores (my lifter bores still look untouched... no rock, the ID's are still pickled gold-green) but because I feel it doesn't have enough overlap for my taste. I am going with a Pauter cam very similar to 86C Web.
so to conclude, the engine will be 94 x 78mm, 9.3:1, 044 44 x 37.5 heads ported by yours truly and Clyde Berg, Pauter R6E8 cam with 1.25 rockers, 48 Webers, 1-3/4" header pipes. I picked up a few new goodies while in Bay Area too, from my friend John Holleran (owns a Porsche speed and fab/resoration/dyno shop).
Last Edit: July 14, 2008, 21:12:30 pm by Jim Ratto
July 15, 2008, 01:17:51 am »
Quote from: javabug on July 14, 2008, 16:53:15 pm
did
go flat?
I'm pullin' your beer card
July 15, 2008, 01:21:44 am »
Quote from: Jim Ratto on July 14, 2008, 19:03:06 pm
Hi Mark,
Nice! Were you using Valvoline 100% synthetic or the Dura-Blend (mix of fossil and synthetic)?
July 15, 2008, 02:52:11 am »
Quote from: Sarge on July 15, 2008, 01:17:51 am
did
go flat?
Oh COME ON!!!
July 15, 2008, 17:40:20 pm »
Quote from: DKK_Fred on July 15, 2008, 01:21:44 am
Hi Mark,
I was using two different synths: Mobil 1 15W50 and Lubro Moly 5W40
now I use conventional Valvo PB 15W40
July 15, 2008, 18:35:28 pm »
Quote from: Casey on July 14, 2008, 16:21:56 pm
is pulley spitting up too? Sounds like a breahter issue....
Casey
July 15, 2008, 20:28:08 pm »
Yes, out of pulley too. Breather lines are still dry. Running 40wt and filled to 2nd line on dip stick. Jim says run 20/50 and fill to lower line. TBC........ I will be at Drag In though!
July 16, 2008, 00:54:50 am »
Quote from: Casey on July 15, 2008, 20:28:08 pm
First line for me, too...or just a shade past. Anymore and it'll spew.
July 16, 2008, 00:55:52 am »
Quote from: Sarge on July 16, 2008, 00:54:50 am
Does Bates have lines on his "dipstick"?
July 16, 2008, 01:03:59 am »
Quote from: Jim Ratto on July 16, 2008, 00:55:52 am
That's between you and Bates...I ain't goin' there!
July 16, 2008, 11:09:43 am »
I had a problem with my 2276 oil breathing - I had a T-piece in the breather lines that was actually pressurising one half of the motor! Changed the routing of the breather tubes and my rocker cover gasket sealing problem was suddenly gone.
July 16, 2008, 11:32:54 am »
Good to hear Jim, (you know) i had same good experience with Webcam/Scat Lube-A-Lobe combo.
July 18, 2008, 23:12:14 pm »
Pulled rest of motor down the other night, and I am pretty impressed with how fresh everything looks. Rod bearings still have the grey dull overlay, mains no battle scars, Mahle pistons still showing the grey coat on skirts, and no huff marks at cylinder-to-head seal (no copper gaskets, I wanted a tight deck). I have to say that this little guy made a hell of a street motor, lots of torque, took a good beating, good throttle response, lived in the heat and wild times. If anybody was going to ask me for a mean street combo, I'd have to suggest this last motor.
New cam is a little more aggressive, at 271 deg @ .050 about same lift as K45. The heads appear to have way more port volume on the intakes, from about mid manifold to valve. Can you say peaky?
July 19, 2008, 08:06:43 am »
tweaky!!!!
July 21, 2008, 17:38:30 pm »
I'm checking the valve lift on my engine. I have some slight difference between each valve. I wonder what is the tolerance?
