October 13, 2026, 04:04:44 am
| | |-+  wich gearbox
Author Topic: wich gearbox  (Read 9092 times)
henk
« on: July 15, 2008, 21:19:39 pm »
hallo
i had my first go on the 400 meter in chimay i only road once because i drove my car over there and had to get back home
i did a 16.70.the engine is a 1776 with stock heads and valves so i am happy whit that for my first time but offcourse i want to go faster
so next time i gonna put some lower tyres on it.
i am also running the stock '67 gearbox so slightly longer geared but should it make a big diffrence if i use a shorter geared gearbox like on a '65or'66?Huh
« Reply #1 on: July 16, 2008, 00:40:20 am »
Is your 67 gearbox originally from a 1500cc car?  If it is, it has a 4.12 R&P.  Going to a 4.37 R&P from a 1200/1300 car will get you down the track faster.
Another way to go faster is to upgrade the heads/cam so your rpm range is increased.  Then make the run in 3 gears only.
Bewitched666
Bewitched
« Reply #2 on: July 16, 2008, 11:50:21 am »
Faster is a combo between engine and gearbox and driver Grin
Swapping for a 4.37 gearbox is an option and less costly then upgrading the engine.
I would do both for more 1/4 fun Grin
Fast vw beetle's rule
henk
« Reply #3 on: July 16, 2008, 18:57:18 pm »
the gearbox is the originele one from the 1300 engine
Bewitched666
Bewitched
« Reply #4 on: July 16, 2008, 19:48:06 pm »
Then you have the4.37 r&p gearbox i bet.
Put some money in the heads,decent header and carbs and cam Cool
henk
« Reply #5 on: July 17, 2008, 10:55:03 am »
hallo
carbs and cam should be ok all ready i think.
they are 44IDF and engle 120
i also have 1.25 rockers laying arond to put in place
« Last Edit: July 17, 2008, 22:48:42 pm by henk » Logged
« Reply #6 on: July 17, 2008, 21:09:27 pm »
You need bigger heads to run those carbs and cam.
henk
« Reply #7 on: July 17, 2008, 22:50:15 pm »
ok thanks maybe i invest my money in some new heads any idea wich ones should be best
for a 1776?
