September 23, 2026, 19:11:55 pm
Some progress pics! New pics added
Topic: Some progress pics! New pics added (Read 22541 times)
Prowagen
Re: Some progress pics! New pics added
Reply #30 on:
July 18, 2008, 18:20:56 pm »
Is that a chopped oval in the foreground?? Another project your not telling us about keith?
Reply #31 on:
July 18, 2008, 19:03:55 pm »
Quote from: John Rayburn on July 18, 2008, 18:17:26 pm
I disagree with Mark about the plastic. I think it will be fine. Go ahead and run it.
Oh, okay. So, do you think the plastic on the muffler will survive... even though plastic rusts, over there? I'd be concerned.
John Rayburn
Reply #32 on:
July 18, 2008, 19:05:57 pm »
If the plastics been properly treated, yes.
I also park at Nick's.
Reply #33 on:
July 18, 2008, 19:17:36 pm »
Quote from: John Rayburn on July 18, 2008, 19:05:57 pm
Duly noted as such. I stand corrected.
Reply #34 on:
July 18, 2008, 22:28:02 pm »
So has that glass gone in yet dude
and I say run the spacers - get those front wheels out where they should be FILLING the fenders
Reply #35 on:
July 19, 2008, 13:01:57 pm »
Quote from: monkiboy on July 18, 2008, 22:28:02 pm
Nah, probably not gonna use it after all - a little bit too dark. Bought new rear stock quarter glass from Heritage instead! The inset of the wheels is such that I could run 3mm spacers at the front and the rims would still be well within the fenders. I like that idea the more I think about it! Narrow is for numpties!
Reply #36 on:
July 19, 2008, 13:13:24 pm »
Quote from: Fastbrit on July 19, 2008, 13:01:57 pm
Cool well I will take first refusal if you come to sell it - I have an idea
"narrowing is for numpties!"
too right dude - I say fit 6mm spacers, it looks like there is stiil plenty of length on the studs
Reply #37 on:
July 19, 2008, 13:29:19 pm »
Latest news! Got the motor fired up last night and it sounds great! Only one oil leak.... from an oil line I'd forgotten to tighten up (
). Now the pre-MOT list consists of bleeding brakes, adjusting clutch/handbrake cables, adjust one front wheel bearing and add some exhaust wrap. I think (but I may be wrong!) that this is all I need to do to get it MOT'd and then registered. Plenty of other (minor) sorting to do, such as making cover for gearbox cut-out under rear seat... and then try to get the five-speed to be just that! Should all be done in time to put the car away for winter...
Thanks to Matt at Air Kraft for the workshop space and cups of tea/coffee!
PS - gone back to running the CB Performance cross-bar linkage - the CSP one doesn't appear to work on an Autolinea case as the location of the mounting bolt moves the linkage too close to the fanshroud causing the central pivot to jam - but if I slot the mounting hole to move it away, the left-hand linkage rod fouls the MSD distributor. Bummer.
Last Edit: July 19, 2008, 13:37:10 pm by Fastbrit
Jason Foster
7.69 87mph 12.35 106 mph
Reply #38 on:
July 19, 2008, 14:18:12 pm »
looks real good Keith keep us posted.
Reply #39 on:
July 19, 2008, 18:17:50 pm »
looks good KS!
but a CB hex-bar has got to be the most hideous linkage of all
DVK ~
Rocket Ron
It's old school for a reason
Reply #40 on:
July 19, 2008, 18:59:17 pm »
Quote from: Fastbrit on July 19, 2008, 13:29:19 pm
looks like we'll be seeing you at 1/8TH mile Drag Racing in Devon in august then ?
13.12 @ 101.84
Grooving out on life
Reply #41 on:
July 19, 2008, 21:02:50 pm »
Quote from: 67-indeed/DVK on July 19, 2008, 18:17:50 pm
looks good KS!
Now back to work and get the CSP working.
Reply #42 on:
July 20, 2008, 01:17:30 am »
do ya have or can you use somebodys lathe keith just put the dust cap in chuck and use parting tool and get rid of the 3 mil you dont need and weld back together, just a though and the car is lookin good !
Russell
Reply #43 on:
July 20, 2008, 01:19:55 am »
Looks Shit keith !
Yes i will come down and have a go....
Step 1, Burnout in Reverse
Step 2, Ping the Clutch
Step 3, Run and 1/8 in 1st
step 4, Push it back
Sorted
Install new gearbox and then take its first run easy..... lift the wheels and get into the 12's
Yip i can do that in any car doesnt need to be a 70's bit of shit MARTIN "
Best Regards
Russell
Black Sheep
less is more
Reply #44 on:
July 20, 2008, 14:57:59 pm »
Quote from: Russell Ritchie on July 20, 2008, 01:19:55 am
Looks Shit keith !
Sorted
Fair's fair Keith
You could always try and run the 1/8th in reverse Russell not forgetting the burn out in that same gear
13.03 @ 98mph
