July 02, 2026, 18:34:18 pm
bigsiembowski
48mm intake, 48 IDA
Topic: 48mm intake, 48 IDA (Read 15226 times)
Mauro Cattan
Manovra So Cal
48mm intake, 48 IDA
November 02, 2006, 22:02:41 pm »
Ciao a tutti,
now my 2332cc motor setup is the following:
044 heads 44 x 37
1,1:4
FK87
48 IDA, welded and ported manifolds
I'm thinking to change these heads with the SuperFlow 48 x 38 but I have some doubts about its right working. My question is: are too large the 48mm intake valves for run with 48 IDA? Vice versa, are too small the 48IDA for the 48 valves?
Ciao
Mauro
Manovra So Cal
Re: 48mm intake, 48 IDA
November 03, 2006, 01:35:45 am »
Try it out. You can always bore your IDA's out to 51.5 or 52mm
Mauro Cattan
Manovra So Cal
November 03, 2006, 11:23:33 am »
Yeah I know, but I love the 48!!!!
Manovra So Cal
Roman
November 03, 2006, 16:35:12 pm »
If the super flows are unported you should have no problems running the 48's. The 48's are only limiting the HP above 220-230 hp and the 52:s should be good up to 270-280. I would recomend 46 mm venturis to get max power (the rule of thumb is 2 mm less than the intake valve).
Bad Junker
November 03, 2006, 19:17:24 pm »
48 mm intake valves in S/F heads and running "just" 48 IDAs NO PROBLEM !
My heads flow like....yiihaa
and along with 38mm exhaust works great ! On my girlie 2165cc !
www.stuka356.webblogg.se
Mauro Cattan
Manovra So Cal
November 03, 2006, 19:42:52 pm »
Thanks guys, your indications are really appreciated
What kind of retainers, springs and keepers are recommended for these heads? We are talking about a 220-230HP motor.....
Ciao grazie
Mauro
Manovra So Cal
Roman
November 03, 2006, 19:53:08 pm »
Bugpack 4046 springs and bugpack titanium retainers is a good and failrly cheap option.
Mauro Cattan
Manovra So Cal
November 05, 2006, 00:39:18 am »
It's true, seems a good solution. Thanks again Roman!!!
See ya
Mauro
Manovra So Cal
GreenTom
December 25, 2006, 11:20:19 am »
useing 10degree collets is a nice option but also conected with chcanging valves... as I know some CB heads have them i standard option (10degree collets, chromoly retainers and duals HD springs).
I agree with Roman about that Bug Pack stuff...
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
ugly duckling
January 14, 2007, 09:03:04 am »
jim is very right the 4046 part# is a regular vw dual valve spring that wont be near enoughf spring presiur for 48x38. if you have the buks this is the cool set up for your combo.if you want the ultimate lite steel valve instead of going to( PRICEY TIT VALVES) go with 7mm stem valves STEEL manley custom stainless way ligthter than your commen 8mm or 11/32. next use manley super 7 tit bead loc keppers with chev styl tit ret to match the super 7s. you need to run the k800 spring thers no way of getting around it. you need 180 lb seat preser and 400 nose presure to keep the steel valve from floating. if you are runing the bigger stem valves and the boat ankor keepers and retainers you will have to up the nose and seat presers. reg vw dual springs only have 130to150seat and 350nose thats a good set ther not all that way not engoghf for what you are doing. just trying to help good luck with your project. yours truly ugly duckling.
Last Edit: January 22, 2007, 05:04:43 am by ugly duckling
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
ugly duckling
January 14, 2007, 09:07:41 am »
and yes your reg 48s will work with the 48mm intake not a problem for now but if you wanted to step up later with the 51s it will make more power thats if the heads are fully done up as far as port work.
Last Edit: January 22, 2007, 05:06:19 am by ugly duckling
www.dprmachine.com
www.4inbore.com
