October 06, 2026, 13:59:22 pm
Latest Member: Chakalives
| |-+  Wanted
| | |-+  transparts
Author Topic: transparts  (Read 4880 times)
« on: July 21, 2008, 15:02:53 pm »
OK
i am looking for a couple off parts to make the trans complete. i have the gearbox and brakes. but what i may need are:
- fulcrum plates (4)
- superdiff (treaded or circlips are both good)
- onepiece rubber booths
- some stronger axles, all types are welcome; long shaft long splines OR short shaft, short splines OR long shaft, short splines.
SPIDERGEARS!!!
« Last Edit: July 23, 2008, 17:56:21 pm by nicolas » Logged
« Reply #1 on: July 22, 2008, 12:10:38 pm »
found a good basis with plates and satelites in the case; circlips and all were there. now i just need the rest to swap the diff and make this baby work.
« Reply #2 on: July 23, 2008, 17:55:14 pm »
so i got the diff sorted, but now they are delivered without any spidergears in them...  Angry Angry
so big bummer as i have two diff but with different spiders... so basically i am after a set of spiders, i prefer the ones with 10 tooth over the ones that have 11, but i am open for all suggestions. i also have no idea which are stonger. the 10 tooth look beefier, but other than that i have no clue.
thanks for helping.
LGK
« Reply #3 on: July 24, 2008, 00:40:40 am »
Nicolas,
The 10 tooth spidergears are the ones you need.(strongest) but be carefull you're sure this is a correct superdiff for the 10 tooth's gears...there are different ones on the market...good ones and bad ones.If you install the 10 tooth's and they lock up when putting together the 2 halves of the IRS-dif with the satelites+spidergears,then you are in trouble...
Regards Steve
Btw; always take 4 brand news spidergears when installing a superdiff !!!!
