September 21, 2026, 23:20:36 pm
|-+  Happenings
| |-+  Happenings
| | |-+  Chassis Dyno at dragday
Author Topic: Chassis Dyno at dragday  (Read 9684 times)
« on: July 22, 2008, 12:01:46 pm »
We confimed this last weekend , we have a Dyno at bitburg for testing hp and AFR . You can get an Diagraph of both . This is a very good dyno with no slip on the tires , i tested it some weeks ago with our black 67 and in 2 week i try my racecar on it . If you plan to do a pull i would recommend to do this with street tires , may be it is better .
Martin Greaves
10.88@128.58
« Reply #1 on: July 22, 2008, 21:25:32 pm »
Udo what will the cost of using the Dyno be.
« Reply #2 on: July 22, 2008, 21:51:53 pm »
I try to get a good price for all that want to use the dyno . Max. would be 50 euros but i think he can make it cheaper because i think there will be some who want to see how much power they have and see if the engine runs rich or lean
« Reply #3 on: August 10, 2008, 08:37:07 am »
The dyno works very well with short gear ratios . Before we only had dynos where i did not get any traction . This is perfect , only strap the car and messure . I only had 265 hp @ 8000 rpm and 280 nm torque  Sad . But i am working on it ... and i must say this dyno shows the real hp  not more than some others do .
« Last Edit: August 10, 2008, 08:40:16 am by Udo » Logged
Airspeed
« Reply #4 on: August 17, 2008, 21:30:44 pm »
Cool!
Will the operator have a separte fan that I can put onto my (rear placed) intercooler?
'Only' 265 hp?  Shocked  Grin
Thanks,
Walter
« Reply #5 on: August 18, 2008, 11:50:13 am »
They have a big fan , i tell them to bring it to Bitburg
Airspeed
« Reply #6 on: August 18, 2008, 17:35:03 pm »
Excellent, I am sure to have a go and am looking for more than 195 RW hp Roll Eyes
Oliver Frey
« Reply #7 on: August 21, 2008, 17:37:10 pm »
I only had 265 hp @ 8000 rpm and 280 nm torque  Sad.
Is that corrected HP or at the tires? At the tires would be quite high for N.A. type 1.
« Reply #8 on: August 21, 2008, 19:05:53 pm »
No it is the engine power . I changed some thinks and will see how it goes this weekend or the weekend after at Drachten ! But it looks good so far . I had a Type 4 engine with injection today with 250 hp and the tune up worked very well . this is the best dyno i ever worked with  Smiley
Oliver Frey
« Reply #9 on: August 21, 2008, 20:27:18 pm »
Very good numbers Udo. You're 265 HP engine , any specs?
« Reply #10 on: August 21, 2008, 21:21:45 pm »
88x94  Cheesy
