September 22, 2026, 01:15:13 am
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  BATES: how does that 94 x 78mm run? It's done RIGHT?
Author Topic: BATES: how does that 94 x 78mm run? It's done RIGHT?  (Read 25089 times)
« on: July 25, 2008, 18:11:13 pm »
 Roll Eyes
Tony M
« Reply #1 on: July 25, 2008, 20:40:36 pm »
Just getting started on same size motor - let us know  Grin
« Reply #2 on: July 26, 2008, 05:22:29 am »
« Reply #3 on: July 28, 2008, 20:48:14 pm »
You can tell, Real Friends Grin
« Reply #4 on: August 01, 2008, 02:01:53 am »
stop goofing off looking up dumb images and get that car running.... WTF's the matter?
I don't have a lot of time and when I do have time, I'm drunker than hell  Grin I am so flippin close I can barely stand it. Just waiting for stupid stuff like valve springs, AN fittings and an alternator. I plan on pulling the warmed up stocker turn key and plugging it directly into my baja, so the 2165 will also have to be turn key as it is my daily driver and has to be running immediately. My ultimate plan is to drive it to the fall Sac Bug-O-Rama 900 miles round trip. We'll see.
« Reply #5 on: August 01, 2008, 12:19:55 pm »
Yeah, hurry up...you want to get yours running before Sheep, right?? Roll Eyes Grin
« Reply #6 on: August 01, 2008, 13:27:05 pm »
That's a memorable quote.   Cheesy
« Reply #7 on: August 02, 2008, 05:39:03 am »
Hell, mine runs right now. I drive it to work everyday.
« Reply #8 on: August 02, 2008, 22:18:24 pm »
  Shocked Shocked Shocked Sorry!! Grin
« Reply #9 on: September 18, 2008, 03:38:56 am »
Well I'm making some progress. All of the valve train is set up. 4046 Bugpack springs set up .650 to bind (thanks Rick Sadler) , CB 1.4 rockers (.566 valve lift), Berg pushrods are dialed in. Long block may be together this tweakend. I'm still debating in my head to go with either the OEM 36hp shroud and a big galley aluminum 356 oil cooler or the new Brazilian doghouse shroud and cooler I have.
sheep
« Reply #10 on: September 18, 2008, 04:13:00 am »
Its so dam cold there you dont even need a shroud Grin
unless it has wheels,tits or fins I dont care
« Reply #11 on: September 18, 2008, 04:16:30 am »
Yeah right. It's been near or over 100 since May. It was 47 this morning and 99 this afternoon.
sheep
« Reply #12 on: September 18, 2008, 04:23:29 am »
WTF do you live in some kind a weird desert Huh
BTW P.U.I Grin
« Reply #13 on: September 18, 2008, 23:36:33 pm »
Short block is together.  Shocked
Tony M
« Reply #14 on: September 19, 2008, 00:41:30 am »
What cam gears did you use ?
« Reply #15 on: September 19, 2008, 04:49:15 am »
POTL Magnums from Gene Berg. I bought them 9 years ago.
sheep
« Reply #16 on: September 19, 2008, 05:36:46 am »
Is Ken Butler helping you build that motor Wink
« Reply #17 on: September 19, 2008, 06:11:06 am »
Yeah, were going to put a progressive Weber on it, I can't afford to tow a gas station around with the IDAs getting 6 MPG. Grin
« Reply #18 on: September 19, 2008, 22:48:40 pm »
Maybe you should look into having Ken help you, too..., look at all the progress here Wink Grin
« Reply #19 on: September 19, 2008, 23:08:08 pm »
"can't be"
you didn't hear about the pushrod problem?!!!!!!!
« Last Edit: September 19, 2008, 23:14:09 pm by Jim Ratto » Logged
« Reply #20 on: September 20, 2008, 17:24:04 pm »
Pushrod problem??  What next??  So, where's the center two case half o-rings..., hopefully, they're not still layin' on the workbench!  Shocked Roll Eyes Wink
« Reply #21 on: September 20, 2008, 17:52:06 pm »
I leave those out on all my shuffle pinned cases.  Roll Eyes
« Reply #22 on: September 21, 2008, 04:32:48 am »
dude you forgot the cam plug
« Reply #23 on: September 21, 2008, 06:04:04 am »
That reminds me. Which way do you guys install the cam plug. I always install mine with the open side towards the cam. I've seen them both ways.
I didn't get squat done today. I took my kids on a 5 mile hike at Indian Mary Park in Galice, Oregon.
http://slackercodemonkey.no-ip.org/hikes/indian_mary/
« Reply #24 on: September 21, 2008, 06:25:16 am »
I think I'm going to build an 1835 to play with.
sheep
« Reply #25 on: September 21, 2008, 16:01:02 pm »
I thought Ratto was banned from this forum....
If he spent half the time working on my motor as he does rambling here, it would be done Angry
« Reply #26 on: September 21, 2008, 18:57:28 pm »
....if I had pistons....
« Reply #27 on: September 28, 2008, 04:18:09 am »
Long block is done. I'm just waiting on an oil cooler.
« Reply #28 on: September 28, 2008, 05:37:03 am »
where did you set cam up at?
« Reply #29 on: September 28, 2008, 20:26:46 pm »
I set it straight up since I couldn't find any retard washers for my Magnum gears. If I want to change it later it will be fairly easy.
