September 22, 2026, 18:15:45 pm
| | |-+  1776ccm oldschool motor
Author Topic: 1776ccm oldschool motor  (Read 15320 times)
Doktor
« on: August 08, 2008, 09:05:53 am »
Hello to everyone,
I plan to build an oldschool 1776ccm, but have some questions and would like to hear some opinions...
Connfiguration:
90,5 P&C
69mm stock crankshaft (non counterweight)
Engle 120 camshaft (9:1 compresion for European 95 octane gasoline)
stock 1:1.1 rockers
HD springs (titanium ?)
Equalizer pulley (Gene Berg or CB Performance)
DRD L3 or DRD L5 heads, single HD springs
AC.NET alu pushrods
lightweight valvetrain
full flow
stock heaters (only with DRD L3 heads)
Dell'Orto DRLA 40 carbs
Mallory Unilite with vacuum
A1 Sidewinder exhaust
Have somebody done something similar recently ?
A few month ago I had opportunity to try 1835ccm with Engle 130 cam and Dell'Orto DRLA 40, that engine hauled ass and idled smooth and had good torque from 2500 rpm to about 7000 rpm...
After that, a know that I don't want Engle 110, a little more duration is more fun !
Opinions (crank, camshaft & pulley) ?
P.S. Of course, all rotation parts will be balanced !
dr.aircooled
« Reply #1 on: August 08, 2008, 09:52:10 am »
The heater boxes will kill it.
Crank will be fine,but its worth the extra money for counterweighted version if you want to regularly turn high rpm,I have only used the berg pulley,they are well made and fit unlike some of the black copies
cheers richie
« Reply #2 on: August 08, 2008, 10:15:40 am »
I second Ritchie. Use a counterweighted crank, if you go anymore than W110 on the cam. Be sure to use light lifters too in that set up. Otherwise normal HD single springs will not handle the rpm.
Stock heaterboxes dont nescessarily kill the pakage with LS3 heads. Just dont yank the CR to the limit. -  9 - 1 is OK.
« Last Edit: August 08, 2008, 10:18:13 am by Torben Alstrup » Logged
Bewitched666
Bewitched
« Reply #3 on: August 08, 2008, 12:12:47 pm »
I agree with Richie and Torben.
I would choose the DRD L5 heads,ban the heaters run a 1 3/8 header system,c/w crank,w120 and run 1.25 rocker.
Am building something similar oldskool but a 1700cc engine
Almost the same with scat mini wedge heads 40x35 ported and polished
 Cool
Fast vw beetle's rule
Doktor
« Reply #4 on: August 08, 2008, 13:31:46 pm »
Thnx for your answers !
I plan to keep the heater boxes in either stock form or modified (for DRD L5 heads), but I have many engine configurations on my mind in range from 1776ccm to 2007ccm. Wink  Undecided
The most critical thing is the non-counterweight crank, but I wouldn't use it with W120 without equalizer pulley, just to ballance things a little bit !
Other option is to buy a Web cam 163 and build a less rewing engine... Smiley
dr.aircooled
Bewitched666
Bewitched
« Reply #5 on: August 08, 2008, 15:36:22 pm »
Goodluck with the building doktor Cool
« Reply #6 on: August 08, 2008, 18:22:23 pm »
why the non counterweight crank?
what's your #  1 priority with this future motor?
I would seriously consider counterweighting and balancing a good orig VW x-drilled crank, and balance rest of motor too.
Do you already have the 40mm carburetors?
airstuff
« Reply #7 on: August 08, 2008, 19:10:01 pm »
Hello my friend Doktor,
With this NOS original VW 69mm crankshaft you have,it is a shame not to use it  Smiley
airstuff
« Reply #8 on: August 08, 2008, 19:11:54 pm »
I think he has a nice set of Dellortos 40 DRLA ex Alfa 33 carbs which do need the right venturies,jets and proper rebuilding.
Doktor
« Reply #9 on: August 09, 2008, 12:39:38 pm »
Hello,
I consider non-counterweiht crank because I allready have it in the box, it's a NOS item...ballance work is a not excluded option... Cool
O yes, i have several sets - including Dell'Orto DRLA 36, 40, Weber 40 IDF and Solex 40 PII  Cool Cool Cool
For that odlschool motor I consider using Dell'Orto 40's...
@Cal-Look: don't have to explain you...you know everything... Grin
dr.aircooled
« Reply #10 on: August 10, 2008, 00:01:08 am »
Then stay with the LS3 heads and use a Web 163. And keep 9 -1 CR. Better overall combo, that will pull where the engine likes to be.
Hotrodvw
« Reply #11 on: August 10, 2008, 07:20:27 am »
This is gonna be great...........keep us posted!  Going to Dyno it by chance?Huh
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Doktor
« Reply #12 on: August 10, 2008, 10:15:20 am »
I would like to go to dyno, but first i have to build that motor !  Roll Eyes Cool
dr.aircooled
