September 23, 2026, 00:30:29 am
| | |-+  New case, which machining options?
Author Topic: New case, which machining options?  (Read 7757 times)
« on: August 08, 2008, 19:24:43 pm »
Hi guys, I'm getting a new AS41 mag case for my 1915 engine. What machining options should I do?
Bore Engine Case to 94mm Pistons
Drill / Tap / Plug Oil Galleries
Full Flow (Drill and Tap Engine Case)
These above I sure of, but what about these:
Sand Seal Case w/Seal
Shuffle Pin Center Main
Sleeve Lifter Bores (Silicone Bronze)
Sleeve Lifter Bores w/Groove (Silicone Bronze)
Thanks!
Mike Lawless
« Reply #1 on: August 08, 2008, 19:34:21 pm »
The top items are a really good idea, with boring the case for 94mm jugs is necessary
The items below are probably unnecessary. Thousands of motors are in operation without the sand seal. Shuffle pins keep the case halves from walking around at really high rpm. If you're not going to hitting 8000rpm plus all the time, it's probably not needed. Sleeved lifter bores would only be necessary for a lifter bore problem that came from REALLY aggressive cams.
While my race motor case does have shuffle sleeves, it has none of the other lower options. Although the next time it is out and apart, I will do the pulley seal thing because I'm using a home brewed crankcase evac system that needs the case to be sealed.
« Last Edit: August 08, 2008, 19:36:23 pm by Mike Lawless » Logged
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
Greg G
« Reply #2 on: August 08, 2008, 19:39:43 pm »
If you are sending to a shop for boring for 94's, you should think about having them clearence it too. Then if you find a good deal on a stroker crank before its together, you will all ready have the work necessary to put the bigger stroke in.
Greg
Mike Lawless
« Reply #3 on: August 08, 2008, 20:02:10 pm »
That's a good point Greg.
(From one "real" (former professional, current hobbyist) machinist to another, who makes and reads paper blueprints, pulls handles and turns knobs.)
airstuff
« Reply #4 on: August 08, 2008, 20:12:45 pm »
I would  also deck the case.
« Reply #5 on: August 08, 2008, 21:01:25 pm »
Ok guys, thanks for your answers. I know enough now.
@ cal-look, decking is included when they bore the case.
Austin Larsen
« Reply #6 on: August 09, 2008, 02:39:57 am »
Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes
Mike Lawless
« Reply #7 on: August 09, 2008, 03:36:25 am »
Thought you might appreciate that Austin!
