July 01, 2026, 20:17:57 pm
Latest Member: bigsiembowski
| | |-+  SPG Roller Bearing Cranks? Good for the Street?
Author Topic: SPG Roller Bearing Cranks? Good for the Street?  (Read 17144 times)
Fasterbrit
« on: August 10, 2008, 15:06:51 pm »
I have an 82 mm SPG crank that is in very good condition with zero twist etc. I am thinking of using it in a hot street motor that will not see strip action. I realise there are issues of the crank twisting when heavily loaded on slicks. What about using them on the street? Anyone have any info or stories to share? Ratto? Thanks, matt
www.air-kraft.com
www.marcomansiperformance.com
Tony M
« Reply #1 on: August 10, 2008, 18:04:00 pm »
Has the crank been pin'd - as each layer gets pressed, all the newer ones were pin'd at each layer - if it has you will have no problems with it. I twisted on old 69mm crank after a 8000rpm pull, but it wasent pin'd. Have built 3 or 4 with these cranks and have had no problems. The only draw back, Heavy.
RMS Boxer Service
« Reply #2 on: August 11, 2008, 09:50:03 am »
This might be a little bit OT, but how to or who can pin a SPG crank ??
I also have a very fine 82 mm SPG crank without pins in each layer and
would like to get it pin'd, any pictures or link would be very much appriciated  Smiley
/R
Martin
Cash Converter....
« Reply #3 on: August 11, 2008, 12:14:56 pm »
Nah there Rubbish!,
what you need to do with it is sell it to me so ive got a spaire for woper Wink
 Wink Wink Cheesy Grin
Martin
www.taylormachine.co.uk
OFF/500
« Reply #4 on: August 11, 2008, 13:12:58 pm »
Funny you guys should ask cos Rob (bronze manx+deano van) is having an 82mm SPG rebuilt AND pinned by Gary Holznecht - the original builder of lil Snort  Smiley
I have his email address if anyone wants it  Smiley
I also have a NOS 82mm SPG linned up that I will be sending over to Gary soon - I have heard that once you drive a roller crank its hard to go back cos they are soooooooo smooth   Wink Smiley
Martin
Cash Converter....
« Reply #5 on: August 11, 2008, 13:17:54 pm »
Could you send it over........   volksman@btinternet.com
Ta in advance.
Martin
OFF/500
« Reply #6 on: August 11, 2008, 13:23:21 pm »
Ta in advance.
Cool dude I will forward you over an email of his including prices - he sure know his stuff   Smiley
« Last Edit: August 11, 2008, 13:25:04 pm by monkiboy » Logged
dave greiner
« Reply #7 on: August 11, 2008, 18:42:10 pm »
  SURE you do!!  LOL
ian c
« Reply #8 on: August 11, 2008, 18:45:26 pm »
you have to put them in neutral when waiting at lights etc Huh
or have i got the wrong end of the stick again ??  Roll Eyes
(o\ ! /o)
« Reply #9 on: August 11, 2008, 19:11:35 pm »
There's a roller-crank motor running around near me, in the most unlikely-est of cars.  Got to drive it once, its a pretty good time!
Tiny pulley and Solexes on "GENE'S" manifolds.   Cool
« Reply #10 on: August 11, 2008, 19:34:36 pm »
That's what aluminium flywheels are for Wink
« Reply #11 on: August 11, 2008, 20:22:20 pm »
  SURE you do!!  LOL
Like I said dude Aug 30/31st - I PROMISE  Wink Smiley
boxertje
« Reply #12 on: August 11, 2008, 20:55:27 pm »
Last year I bought 2 of these beautifull cranks,brand new!!!!!!!!(I think)They have a litle surface rust.I would like to use one in a futur project and sell maybe one.The problem is the same,......nobody can check these cranks (or pin them)Somebody in Holland,germany or belgium???
GreenBeetleDave
« Reply #13 on: August 11, 2008, 21:22:12 pm »
I'm running an 82 SPG roller in my bug and had no problems whatsoever!!
I did get told when I built the engine though to never use it with slicks. (It's a street car so no problems there)
I also got advised to not run a compression ratio of over 8:1
The advice was from Geoff Thomas (from Autocavan) who was the sole person to import them into the UK back in the day apparently.
Java Green 2110cc '67 Bug
63 1200cc Italian Spec Split Microbus
Best ET = 14.32 @ 93mph (in 3rd) - Big Bang 2007 - (in the Bug)
« Reply #14 on: August 11, 2008, 21:26:02 pm »
Your right about the slicks/track thing BUT I was think more like 10/11:1 for my 2180 monster Wink Smiley
GreenBeetleDave
« Reply #15 on: August 11, 2008, 21:40:23 pm »
Well I just played it safe to be honest as it was originally a 2nd hand chuck together job from an old VWDRC car but with better heads and bigger carbs.
Long term plan was to eventually build a proper engine with a forged 82 and higher ratios but I thought I'd start mild and build up to mental when I was richer! (Hasn't happened yet)  Embarrassed
