October 13, 2026, 06:11:54 am
Vacuum pumps
Topic: Vacuum pumps (Read 13062 times)
andy M.
Vacuum pumps
August 11, 2008, 20:19:29 pm »
ok, who knows everything I need to about vacuum pumps for street/strip use, is there an off the shelf kit available, either belt driven or electric? Looking for something that will work with the standard generator stand still in place,
regards
andy
L.B.C.R.
ian c
Re: Vacuum pumps
August 11, 2008, 20:23:14 pm »
i was looking at the moroso one on samba .
decided against it , mainly due to looks ... yes , i'm vain
electric one can be had for about the same as a moroso from jegs etc.
not sure they'll pump enough though . (will check for you)
for all-out street use i wouldnt bother .....
you know you have to build the engine to suit ?? its not just a bolt on mod
(o\ ! /o)
ian c
Re: Vacuum pumps
August 11, 2008, 20:24:23 pm »
and before the wiseguys come on board .... this is NOT a thread about penile dysfunction devices !!!
(o\ ! /o)
Re: Vacuum pumps
August 11, 2008, 20:27:28 pm »
Quote from: andy M. on August 11, 2008, 20:19:29 pm
regards
andy
Dave Dinnings got one from Shawn geers,its costly and i am not sure it will fit around cooling/charging systems,you need low tension rings and to re jig you crankcase breathing to suit
SteveW
Re: Vacuum pumps
August 11, 2008, 21:33:35 pm »
Quote from: richie,uk on August 11, 2008, 20:27:28 pm
regards
andy
On Shawn's 'street' car he does have a pump fitted but with a central mounted fan housing/alternator..
I love that engine, apart from the chrome tinware!! The idea is great though as I'm all for keeping cooling on a motor hence why I have with ours. Thats definately a set-up i'd be looking into if we ever upgrade our motor!
Jaycee also makes a vacuum pump set-up and I 'think' he uses a Product Engineering pump same as Shawns..??
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
ian c
Re: Vacuum pumps
August 11, 2008, 21:37:14 pm »
i think shawn gets em from jack , or is that something else .
the reason the moroso looked good was the inlet and outlet are somethink like 90 degrees , so it COULD fit aside the alt stand , and have both hoses facing upwards ....
Last Edit: August 11, 2008, 21:54:08 pm by ian c
(o\ ! /o)
andy M.
Re: Vacuum pumps
August 11, 2008, 21:42:36 pm »
I've done a bit of reading up on these devices, and was aware of the advantages of low tension rings (although a few people seem to think that you can use them without l/t rings but you gain more power with them) but what do you have to do to re-configure the breathing system? I'm just looking for ways to make more power from a given displacement.
cheers for the input
andy
L.B.C.R.
ian c
Re: Vacuum pumps
August 11, 2008, 21:45:04 pm »
you need to seal the case for them to work
pump 1/2 to baffled tank , pressure equalize 3/4 . iirc
(o\ ! /o)
ian c
Re: Vacuum pumps
August 11, 2008, 21:52:59 pm »
look here ....
http://www.cal-look.com/forum/index.php?topic=15714.0
http://www.thesamba.com/vw/classifieds/detail.php?id=567101
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&N=0&Ntt=vacuum+pump&Ntk=all&Nty=1&D=vacuum+pump&Ntx=mode%2Bmatchallany&Dx=mode%2Bmatchallany&searchTerm=vacuum+pump
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&N=0&Ntt=electric+vacuum+pump&Ntk=all&Nty=1&D=electric+vacuum+pump&Ntx=mode%2Bmatchallany&Dx=mode%2Bmatchallany&searchTerm=electric+vacuum+pump
Last Edit: August 11, 2008, 21:59:49 pm by ian c
(o\ ! /o)
andy M.
Re: Vacuum pumps
August 11, 2008, 22:05:35 pm »
The recommended vacuum "pull" seems to be around 15" of mercury, but this is for american V8's with big pistons and lots of them! Do you need as much vacuum with less crankcase volume? Less vacuum means a smaller pump and less weight and even the possibility of using an electric pump with no draw on engine horsepower although i am a bit dubious as to the vacuum available from the currently available electric pumps, apart from the mega expensive $1600 24v version out there. Small motorcycle pumps are available too.
cheers
andy
L.B.C.R.
ian c
Re: Vacuum pumps
August 11, 2008, 22:12:20 pm »
go for 12" and adjust from there .
(o\ ! /o)
SHAWN GEERS
Re: Vacuum pumps
August 25, 2008, 20:12:33 pm »
Andy, Ill sell you the one I have on my street car! With the new cal-look challenge rules, I dont need it anymore. BTW Ian, its made by Geers Engineering!
SteveW
Re: Vacuum pumps
August 25, 2008, 21:42:31 pm »
Hey Shawn, welcome to the lounge!
Steve
1970 Stock Beetle.
ian c
Re: Vacuum pumps
August 26, 2008, 08:09:29 am »
Quote from: SHAWN GEERS on August 25, 2008, 20:12:33 pm
hey shawn
how you doin .
sorry bout that !!
dont forget to give us details of your new venting set-up ...
any other changes ??
(o\ ! /o)
andy M.
Re: Vacuum pumps
August 26, 2008, 18:52:47 pm »
Hi Shawn, how much?
andy
L.B.C.R.
SHAWN GEERS
Re: Vacuum pumps
September 03, 2008, 20:03:10 pm »
Thanks Steve!
