November 02, 2026, 18:12:48 pm
pix of breather boxes
Topic: pix of breather boxes (Read 33490 times)
Re: pix of breather boxes
Reply #30 on:
September 04, 2008, 16:28:51 pm »
Mine.. Made by USAF MSGT Mike Green. (R.I.P) Thanks Mike, You were the best...
airstuff
Reply #31 on:
September 05, 2008, 14:55:46 pm »
nice box
Reply #32 on:
September 14, 2008, 18:38:46 pm »
I still like this one
www.Udobeckertuning.de
sven
Reply #33 on:
September 14, 2008, 19:50:54 pm »
Talking about breather boxes, thats the only problem I have with my new Engine and Car, at the end off the track the Oil is coming trough the filter.
Maybe the breather box is to small or the diameter of the return to the engine is to small?
Anybody?
Last Edit: September 14, 2008, 19:53:15 pm by sven
Reply #34 on:
September 14, 2008, 20:24:48 pm »
Sven, are you running -6 or -8 lines to the box ? What about hose ends, they look hydraulic-pressed ones on the pic. (i.e limited flow).
Regards,
Harry
Last Edit: September 14, 2008, 20:29:08 pm by FDK/Hurry
ian c
Reply #35 on:
September 14, 2008, 21:05:18 pm »
mike lawless and muffler mike have both written about this ..
iirc , the crank spinning stops the oil draing back as fast as it goes up .
fit drains on your heads/covers back to the sump .
Last Edit: September 14, 2008, 22:01:02 pm by ian c
(o\ ! /o)
Reply #36 on:
September 14, 2008, 21:38:38 pm »
Quote from: sven on September 14, 2008, 19:50:54 pm
Anybody?
Box looks small , also the hoses . But may be you have a problem with your piston rings .
Stephan S
Reply #37 on:
September 15, 2008, 17:33:52 pm »
Posted before, but here we go again:
Box custom made by Mooneyes and later modified by Greg brinton due to lack of space behind the shroud...
More pics here:
http://cal-look.no/lounge/index.php/topic,5550.0.html
... and even more pictures in the latest issue of Ultra VW (Tech Article)
Roman
Reply #38 on:
September 15, 2008, 18:06:29 pm »
Anybody?
If the oil is coming thru the filters you have either:
-Not separated the oil from the mist coming from the filters or
-The oil level gets too high in the filter.
I have some cheapo stainless scrubbing dishing balls that I have filled the breather box with, and it seems to work.
If the level gets too high you either have to have a return line to the case or a bigger breather box.
The reason can also be bad rings, but that is easy to spot with a leak down test.
Hong Kong Syndicate
I'm not Db Cooper!
Reply #39 on:
September 17, 2008, 02:10:40 am »
I love this one, made whit a Fram f3p oil canister:
Seen on the beautiful blog of Florient:
Welcome in Lozerifornia
I know, I know my English is very poor
ian c
Reply #40 on:
September 17, 2008, 12:59:42 pm »
that is awesome !!!!
got any pics of the tailpipes on the car as well ??
(o\ ! /o)
jrice
Reply #41 on:
September 17, 2008, 15:56:22 pm »
Quote from: Udo on August 22, 2008, 06:49:34 am
Quote from: jrice on August 20, 2008, 18:20:15 pm
They have a very small diameter !
Last Edit: September 17, 2008, 16:02:03 pm by jrice
Jeff Rice
Portland,OR
