April 24, 2024, 11:08:11 am
chicochemxli
Off Topic
* non-VW fest *
54
55
56
57
58
Topic: * non-VW fest * (Read 577350 times)
mg
Re: * non-VW fest *
Reply #1620 on:
October 17, 2020, 21:01:38 pm »
intimidator
Catbox
Slave to internal combustion.
Re: * non-VW fest *
Reply #1621 on:
February 25, 2021, 04:07:46 am »
Nothing super exciting.
Just took my old truck to the grocery store.
Because you need a big block Chevy to haul the groceries home.
This one is just about smiles per gallon...
mg
Re: * non-VW fest *
Reply #1622 on:
April 28, 2021, 15:57:36 pm »
The 5 car was digitized for a future video game.
They paid $500 for 2 days access to the car.
That tops the $400 I got paid for winning Bracket 1 with my VW bug at Bakersfield way back in '89.
Last Edit: April 28, 2021, 15:59:08 pm by mg
mg
Re: * non-VW fest *
Reply #1623 on:
June 02, 2021, 15:14:17 pm »
20 years ago I made an easy switch from VW to AC Porsches.
Easy as in affordable back then.
This was my work car for many years.
Last week at the Porsche dealer getting the numbers matching certificate.
After getting a nice offer it leaves Sunday with it's new owner.
It will be my first time with nothing AC in a long time.
Last Edit: June 02, 2021, 15:16:12 pm by mg
andrewlandon67
Re: * non-VW fest *
Reply #1624 on:
June 02, 2021, 16:29:27 pm »
A few months back I finally bought a "grown up" car in the words of some friends of mine...
It's an '06 2.3t with the one-year-only "Sport Package" replacement for the Aero trim, it's got some cosmetic issues such as peeling clearcoat and a torn up front bumper cover, but there's no rust and no dents anywhere, not bad for 182k miles...
I'm just glad I finally got to scratch my Saab itch, but it figures the guy with a '67 Bug would accidentally buy his way into another weird transition year bastard car.
14.877 @ 88.85 mph
My car is what it is, maybe not Cal Look per the books, but it's more than most.
spoolin70
Re: * non-VW fest *
Reply #1625 on:
July 08, 2021, 17:44:53 pm »
Saw this parked near Canary Wharf (posh place in London)
Could image it with a rotary or 20v black top with throttle bodies.
Made a nice change from the usual pointless Range Rovers and low spec white BMWs with stick on M badges
brewsy
Re: * non-VW fest *
Reply #1626 on:
July 09, 2021, 17:37:45 pm »
Quote from: spoolin70 on July 08, 2021, 17:44:53 pm
A Cherry?
spoolin70
Re: * non-VW fest *
Reply #1627 on:
July 13, 2021, 22:37:37 pm »
I think your right
Thanks for giving me something extra to do over the weekend at work.
Images - 80's cherry
Images - Datsun Sunny
Modified cherry/sunny
Cherry/Sunny for sale
brewsy
Re: * non-VW fest *
Reply #1628 on:
July 14, 2021, 10:17:18 am »
Your images didnt show up Spool...
spoolin70
Re: * non-VW fest *
Reply #1629 on:
July 14, 2021, 14:57:51 pm »
Sorry to disappoint you but there are no images.
It was what I was typing in with G and oogle before
mg
Re: * non-VW fest *
Reply #1630 on:
November 10, 2021, 15:54:57 pm »
New suspension set up working great.
Jacking down the front end with more rebound and softer springs all around.
Best car I've ever raced.
Got 2nd out of 42 cars Saturday at big willow.
730hp 2500lbs, big tires big engine big deal lol.
Last Edit: November 10, 2021, 15:58:15 pm by mg
brewsy
Re: * non-VW fest *
Reply #1631 on:
November 11, 2021, 11:44:57 am »
Quote from: mg on November 10, 2021, 15:54:57 pm
Congratulations and that beast looks awesome. Corvette right?
Marc
mg
Re: * non-VW fest *
Reply #1632 on:
November 11, 2021, 14:54:39 pm »
Quote from: brewsy on November 11, 2021, 11:44:57 am
Marc
Thank you.
Close it's a mid 90s Chevy Camaro shape, only the tail lights are off the production car.
Tube chassis, Ford 9 inch, 4.10 with a locker, 4 link with a Watts link.
Dog ring H pattern gear box, no clutch up shifts.
18 degree V8 with a 5 stage dry sump oil pump.
Last Edit: November 11, 2021, 14:58:25 pm by mg
mg
Re: * non-VW fest *
Reply #1633 on:
November 11, 2021, 16:19:11 pm »
brewsy
Re: * non-VW fest *
Reply #1634 on:
November 12, 2021, 10:58:03 am »
Quote from: mg on November 11, 2021, 14:54:39 pm
Is that a 180 degree meaning 'flat plane' crank?
Didnt know you could get them for Chevys? Must sound amazing!
Marc
mg
Re: * non-VW fest *
Reply #1635 on:
November 12, 2021, 14:33:29 pm »
Quote from: brewsy on November 12, 2021, 10:58:03 am
Marc
18 Degree engines became available in racing back in the late 80s early 90s.
c&p
18 refers to the angle of the valves in relation to the piston centerline. The 18 degree generally flow more than the 23, and the 15 more than that.
Your standard V8 23 degree cylinder heads , even better ones available, normally an intake flow numbers in the 270 -310 CFM range.
Stock Chevrolet heads rarely surpassed 240 cfm, most of the 23 degree heads use the stock components like rocker arms, push rods, etc.
in the 12-18 degree heads normally cannot use any of the stock components, require special push rods, special rocker arms, and of course the different cylinder heads themselves, many if not most require offset roller lifter cams, special machine work, special headers, special pistons, and they are designed to work best only at high rpm (above 5000rpm) and high valve lifts (above .600 lift) port size can run 235-290cc, cost of the complete setup , including the heads, cam,rockers, pushrods, intake, and special machine work seldom come in under $4500 and frequently much higher, but you do get the increased air flow that allows a 358-410 cid displacement to make 650hp- plus in a correctly set up engine, short answer, there great if you have very deep pockets, but they are not to be thought of as a standard or a cheap upgrade.
brewsy
Re: * non-VW fest *
Reply #1636 on:
November 12, 2021, 15:35:27 pm »
Quote from: mg on November 12, 2021, 14:33:29 pm
c&p
Awesome. Thanks for that. Love learning new stuff
mg
Re: * non-VW fest *
Reply #1637 on:
November 26, 2021, 20:25:26 pm »
Cleaning and checking.
Last Edit: November 26, 2021, 20:27:29 pm by mg
mg
Re: * non-VW fest *
Reply #1638 on:
December 19, 2021, 18:29:15 pm »
mg
Re: * non-VW fest *
Reply #1639 on:
December 20, 2021, 00:26:24 am »
Camarow!
https://youtu.be/_2Z4PHH1Mzo
Last Edit: December 20, 2021, 00:29:49 am by mg
Joe Hullett
Re: * non-VW fest *
Reply #1640 on:
December 20, 2021, 13:15:50 pm »
Quote from: mg on November 26, 2021, 20:25:26 pm
Looks like a Tony Ave chassis?
The older I get... The faster I was... No Fear
mg
Re: * non-VW fest *
Reply #1641 on:
December 21, 2021, 15:19:42 pm »
Quote from: Joe Hullett on December 20, 2021, 13:15:50 pm
Hey Joe like your Ghias.
This is a 92 Pancho Weaver Trans Am spec chassis.
Pancho has a very cool history of building many race cars.
Boris Said was driving a Weaver Challenger TA car recently.
https://gotransam.com/news/Weaver-Racing-Concepts-in-Competition-Mode-Out-West-for-Laguna-Seca-Trans-Am-Speedfest/71297
Last Edit: December 21, 2021, 15:26:36 pm by mg
Joe Hullett
Re: * non-VW fest *
Reply #1642 on:
December 21, 2021, 18:16:24 pm »
Pancho makes a good car. Boris did beat our car at the stripe in Laguna Seca this year in the press release you linked but his bouncing off Chris Dyson "driving style" gave him a 40 second penalty so we ended up with the win. We have finished the last 3 years as Bride's Maids in the TA Championship. One year I might get there. SMDH
https://gotransam.com/news/Dramatic-Finish-in-Trans-Am-Gives-Tomy-Drissi-the-Win-at-WeatherTech-Raceway-Laguna-Seca/71300
mg
Re: * non-VW fest *
Reply #1643 on:
December 21, 2021, 18:41:47 pm »
Cool stuff Joe.
I like that Pancho is still building them and Boris can still drive them with an H pattern shifter.
Do you help on Tommy's team?
Drissi has had some contact before too.
https://us.motorsport.com/transam/news/tomy-drissi-banned-from-trans-am-for-one-full-year-640360/2948119/
Joe Hullett
Re: * non-VW fest *
Reply #1644 on:
December 21, 2021, 19:01:42 pm »
LOL, yeah Tomy is a wild man behind the wheel. His incident at Mid-O with Amy Ruman was before he came over to us at Burtin Racing, he was with Tony Ave then. He's off to Gentilozzi for 2022. So weird to see Gentilozzi coming back...
Yeah, I do all the electronic data and video acquisition for Burtin racing and all the TV in-car camera broadcasts for the series. Been a good gig for 5 years now.
Last Edit: December 21, 2021, 19:03:56 pm by Joe Hullett
mg
Re: * non-VW fest *
Reply #1645 on:
December 21, 2021, 22:22:17 pm »
Quote from: Joe Hullett on December 21, 2021, 19:01:42 pm
Cool job, data is so important, expensive and complex.
I've enjoyed the TA races on TV and U-Tube, keep up the great work.
mg
Re: * non-VW fest *
Reply #1646 on:
January 22, 2022, 02:07:51 am »
Entered 2022 Monterey Reunion,
late 80s IMSA GTO Camaro just before the 18 degree engine.
Period correct 23 degree 358 fresh with only dyno time.
630hp, intake to oil pan, 5 stage oil dry sump pump, power steering pump, water pump, distributor for $7k.
V8 HP is cheap compared to almost anything else.
mg
Re: * non-VW fest *
Reply #1647 on:
February 26, 2022, 15:09:41 pm »
VW bump drafting
Re: * non-VW fest *
Reply #1648 on:
March 11, 2022, 14:45:20 pm »
Those are great pictures Mike! We know what happened to the red one (up to a point in the early 70s, anyway!), but I wonder what became of the blue AJ Foyt one?
spoolin70
Re: * non-VW fest *
Reply #1649 on:
April 16, 2022, 10:26:32 am »
A few from yesterday at wheels day
Felt good to be at a show again, just like old times
Last Edit: April 16, 2022, 10:28:04 am by spoolin70
54
55
56
57
58
