June 16, 2026, 12:06:50 pm
352188 Posts in 28914 Topics by 6920 Members
Latest Member: chris41
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  * non-VW fest *
Pages: 1 ... 56 57 [58] Print
Author Topic: * non-VW fest *  (Read 2065199 times)
spoolin70
« Reply #1710 on: April 10, 2023, 02:49:53 am »
spoolin70
« Reply #1711 on: April 10, 2023, 02:50:58 am »
spoolin70
« Reply #1712 on: April 10, 2023, 02:52:26 am »
spoolin70
« Reply #1713 on: April 10, 2023, 02:53:27 am »
spoolin70
« Reply #1714 on: April 10, 2023, 02:54:42 am »
spoolin70
« Reply #1715 on: April 10, 2023, 03:02:06 am »
This was just a small selection, loads of different styles.
Have been going for many years now and the only thing we miss is the burnouts/fast exits from years ago. I understand a rolling burnout on a public road isn’t the right image or message but there’s enough private road to have a little display of power before leaving the grounds.
Disappointing to see a lumpy cam V8 leaving and barely making it past idle.
Darren
mg
« Reply #1716 on: April 22, 2023, 16:23:12 pm »
BBQ this afternoon, garden and pool are ready for spring.
Pool is 86, outside temp 82, this weekend is the first swim of the season.
« Last Edit: April 26, 2023, 01:07:47 am by mg » Logged
mg
« Reply #1717 on: July 11, 2023, 01:35:19 am »
New engine on the Westec dyno soon then back to racing the 10.
mg
« Reply #1718 on: July 12, 2023, 17:11:28 pm »
New 10 engine is scheduled for the Westec engine dyno Monday.
Loaded the 10 early to beat the summer heat, headed to the race shop tomorrow.
mg
« Reply #1719 on: September 13, 2023, 17:14:18 pm »
Well it is finally time to go racing at Buttonwillow with VARA next weekend.
First time towing the 24 foot trailer with the slide in camper installed.
Looking forward to camping at the track and hanging out with my racer friends.
We have 3 V8 cars out of Bryans racing sharing a 4 car garage.
Should be fun with plenty of smack talking all weekend long.
Time to get some sim time and warm up on my left foot braking.
The 10 car is in tip top shape, best condition its been in during my 12 years of ownership.  Cool
mg
« Reply #1720 on: March 07, 2024, 19:37:46 pm »
progress, first test day, next race big willow with Vara middle of March...
starting with the 4th gen on an awesome 92 Pancho Weaver chassis.
Replace the vintage 4 piston fronts with new 6 piston brakes and rotors.
Biggest I can fit in a 16 inch diameter wheel.
Should help slowing at faster speeds.
Project Mu pads.
Carbon fiber driveshaft that uses less power and less inertia that can help with braking too.
It is a steel Ford 9 inch third member with lightened ring and pinion.
Wavetrac diff so you can get on it sooner.
https://youtu.be/XuqdWkYiO-M?feature=shared
mg
« Reply #1721 on: March 07, 2024, 19:42:56 pm »
Replaced the awesome old 5 speed Weissman with a Nascar style GSR 4 speed dog box.
Both are rated to 1000hp.
This should give me added shifting confidence.
We had to raise the engine 5/8 of an inch for new GSR ground clearance, so Bryans CNC made a new firewall transmission plate.
Look  how excited this guy is about the transmission. Cheesy
https://youtu.be/Zlj3Ypy_7hQ?feature=shared
Similar transmissions except different front bell housing, and the new GSR stack is vertical, it has a little less ground clearance.
So here is the raised 5/8 inch front firewall transmission mount.
A big tube allows a 10 inch rear ward input shaft extension.
Moves the trans weight to the middle of the car and off the front axle.
Thin Gold firewall rated for higher temperatures.
The new CNC front engine plate, should make the chassis stiffer.
Mocking up alternator mount, belts and gears.
New gold firewall but left the chassis in OG patina grey.
mg
« Reply #1722 on: March 07, 2024, 19:48:45 pm »
New front alternator mount, the old Alternator was driveshaft mounted and would only charge at high speeds.
Car is always on a battery charger at the track, small car battery, and I use a cool shirt and helmet blower.
5 stage dry sump oil pump, always prime the oil pump. Take off the belt and spin the pump with a drill every morning.
New 4 gallon oil tank with heater holds a case of oil. All swedged pressure tested fittings new lines, new breathers too.
Ran the engine on the Westec honest engine dyno.
Used 18 degree engine that had an ok leakdown, new valve springs.
Ran it on an 850 and a 750 carb.
Made 15 more hp with the 850 but less drivability.
So it has a 750 carb for more drivability out of the corners.
« Last Edit: March 07, 2024, 20:03:11 pm by mg » Logged
mg
« Reply #1723 on: March 22, 2024, 21:44:05 pm »
1.21 at Big Willow, fun and fast racecar.
In car video.
https://youtu.be/gTRFdNbXhMo?feature=shared
mg
« Reply #1724 on: June 12, 2024, 01:49:36 am »
Dennis Gray photo, T 9 Laguna Seca exiting the corkscrew.  Smiley
mg
« Reply #1725 on: January 12, 2025, 19:39:03 pm »
Getting the 10 ready for some spring races.
New engine, new Brodix heads should be on the dyno soon, 650+ hopefully.
« Last Edit: January 12, 2025, 19:45:57 pm by mg » Logged
mg
« Reply #1726 on: January 12, 2025, 19:41:22 pm »
5 car on a rolling chassis dolly, all clean waiting for a new engine 18 degree in June.
mg
« Reply #1727 on: January 30, 2025, 02:29:43 am »
2 races planned.
VARA Big Willow in March.
https://www.vararacing.com/events
SVRA Laguna Seca in May.
https://svra.com/news/svra-announces-2025-schedule/
The 10 is at Bryans racing enterprises getting some attention.
https://www.bryansracing.com/engines
So new Brodix Heads flow well and were tuned on the Westec dyno.
On the dyno Carb actually was a Holley 750cfm.
Found a cracked ignition pick up magnet in the distributor.
Timing was jumping from 24 to 44, difficult to diagnose when driving, would of just felt down on power on track.
Good torque for getting off corners.
Needed some clutch parts, small rock got jammed in it.
Ordered new slicks. Cool
https://youtube.com/shorts/jScm-Td5TTk?feature=shared
« Last Edit: January 30, 2025, 02:36:31 am by mg » Logged
mg
« Reply #1728 on: April 19, 2025, 03:10:40 am »
10 car had a good test at a new track called the Circuit at Buttonwillow.
10 car and my 3 race buddies in the photo all were accepted to the 2025 August Reunion at Laguna Seca.
https://youtu.be/8UGwZZrdPqc?feature=shared
Past Reunion race.
https://youtu.be/FWHQnvijZf4?feature=shared
« Last Edit: April 19, 2025, 03:14:36 am by mg » Logged
mg
« Reply #1729 on: September 02, 2025, 16:03:33 pm »
video...
https://youtu.be/RSwYBIIOiEc?feature=shared
mg
« Reply #1730 on: November 01, 2025, 16:52:34 pm »
5 car is ready.
Check out this video a friend made of the 10 car.
https://youtu.be/dLJflS8Fnhg?si=Ryb1sxeEiQo-M2eu
« Last Edit: November 01, 2025, 16:55:15 pm by mg » Logged
mg
« Reply #1731 on: November 15, 2025, 16:15:45 pm »
Fun sunny weekend last race of the year.
Slowing from 160mph for T1.
https://youtu.be/O2d990AQ508?si=DCQRchdg9lpKCucG
Backing up.
https://youtu.be/r99SK8JF9es?si=MpWZbRJADccoYbbR
« Last Edit: November 15, 2025, 16:17:27 pm by mg » Logged
mg
« Reply #1732 on: November 24, 2025, 17:48:08 pm »
We raced the 5 at Big Willow with VARA a couple weeks ago.
New engine and got the gearing perfect with a new lightweight 3.90 ring and pinion.
Chased hard to detect minor oil leaks Friday and Saturday.
Ran 1.22 during both qualifiers.
Having fun vintage racing and enjoying the challenge of maintaining and racing these old race cars.
5 is scheduled for 2 races at Big Willow and 1 race at Laguna Seca in 2026.
The 10 car will be raced at the Long Beach Grand Prix and the Rolex Reunion in 2026.
Video of the 5 at Big Willow.
Lap time of 1.22 provides an average speed of 110mph on the 2.5 mile lap.
https://youtu.be/7IE7D_l_26Q?si=Kp4RDkIfglm1Wlx_
mg
« Reply #1733 on: January 04, 2026, 17:26:39 pm »
mg
« Reply #1734 on: January 06, 2026, 16:34:33 pm »
always keep one tire on the track. Smiley
« Last Edit: January 06, 2026, 16:40:19 pm by mg » Logged
mg
« Reply #1735 on: February 08, 2026, 21:10:31 pm »
On the chassis dolly easy to push out of the way with one hand.
mg
« Reply #1736 on: March 26, 2026, 05:37:23 am »
Old Vettes are a bargain.
« Last Edit: March 26, 2026, 05:40:31 am by mg » Logged
mg
« Reply #1737 on: April 07, 2026, 17:35:27 pm »
Excited next weekend 2nd time on the Streets of Long Beach for me in the 10, 3rd time for this race car.
mg
« Reply #1738 on: April 29, 2026, 23:01:32 pm »
 Cool
