October 03, 2026, 00:37:36 am
tyre pressures
Topic: tyre pressures (Read 9692 times)
smurf67
tyre pressures
August 20, 2008, 11:56:10 am »
Not sure if this is really in the correct place but I have been looking at some of the cars on here and noticed that the majority seem to have more pressure in the rear tyres than me. I HAVE 205 65's and just wondered what everyone thought i should run at, many thanks Alex
benssp
www.callookvw.com
Re: tyre pressures
August 20, 2008, 12:02:37 pm »
19psi in the front and 26psi in the back on the street for me
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
smurf67
Re: tyre pressures
August 20, 2008, 12:07:34 pm »
Quote from: benssp on August 20, 2008, 12:02:37 pm
Brill thanks for that, i dont think im running much different to that best have a check mind
Re: tyre pressures
August 20, 2008, 12:27:37 pm »
tire size does not mean you change tire pressure. weight of car means you change tire pressure. run tire pressure as per manual for the street.
Re: tyre pressures
August 20, 2008, 14:45:29 pm »
There are no rules... but that sounds about right. Scwhimmer and I were just having this conversation at Nick's, earlier this month. My car handles and rides good, but I'm gonna take his advice and lower the pressure on the front tires.
Re: tyre pressures
August 20, 2008, 15:16:24 pm »
Quote from: DKK_Fred on August 20, 2008, 14:45:29 pm
Humm, I was running 30 psi in my 145s per the Muir book. Wonder if that may have contributed to the squirrelly handling at highway speeds.
Re: tyre pressures
August 20, 2008, 15:23:21 pm »
Quote from: louisb on August 20, 2008, 15:16:24 pm
Very much so, Louis. Try lowering the pressure in your front tires till you find the best handling. Our cars have no weight on the front wheels, so it makes sense. I'm gonna give it a try and see if there's any improvement.
Re: tyre pressures
August 20, 2008, 15:25:21 pm »
Quote from: DKK_Fred on August 20, 2008, 15:23:21 pm
I will give that a try once its back together.
Re: tyre pressures
August 20, 2008, 17:04:53 pm »
I run about 19, maybe 20 psi in my 145s, and feel that is why I have not had many scary moments with braking on my skinnies.
Martin
Cash Converter....
Re: tyre pressures
August 20, 2008, 17:32:23 pm »
22 in the fronts and 28 in the rears for street duty
22 in the front and 11 in the rears for track use.
Martin
www.taylormachine.co.uk
OFF/500
