September 24, 2026, 01:36:42 am
blaster coil 2
Topic: blaster coil 2 (Read 7946 times)
davvide
blaster coil 2
August 22, 2008, 18:50:29 pm »
Anybody has mounted blaster coil 2 with stock distributor?
Have you also mounted the ballast resistor?
tnx
www.bollatecounty.blogspot.com
davvide
Re: blaster coil 2
August 24, 2008, 18:27:02 pm »
Nothing?!?
John Rayburn
Re: blaster coil 2
August 25, 2008, 06:23:47 am »
Personally I wouldn't run a Blaster coil. I've run the same Bosch Red coil for 25 years or so with no problems. I have heard of alot of problems of Blaster coils going bad. Regardless, you will need a ballast resister when running points with a Blaster or Bosch Red coil.
I also park at Nick's.
Greg G
Re: blaster coil 2
August 30, 2008, 23:30:30 pm »
I just removed my blaster 2 coil because my perlux went bad and when I put regular points in, they just burt up. I put a stock blue coil in with the stock bosch black and white wire points.
If I put a balast resister in on the hot side of the coild, could I run the blaster 2 coil with the points?
Greg G
John Rayburn
Re: blaster coil 2
August 31, 2008, 00:23:20 am »
Yes, you can run the Blaster coil with points, with a ballast resister inline.
Greg G
Re: blaster coil 2
August 31, 2008, 05:49:13 am »
Quote from: John Rayburn on August 31, 2008, 00:23:20 am
Thanks, I'll put a set of cheap points in with the ballast and see how long they last. I don't want to mess up the new set of white stripe bosch points I just bought. I am having a hard time finding places that carry them. I bought both sets a little shop in chino had a couple weeks ago. At $12.00 a set, they said they don't sell very many and might not order any more. I asked them to get another two sets and I would pick them up, but they havn't called me saying they got them yet.
Greg
John Rayburn
Re: blaster coil 2
August 31, 2008, 06:18:50 am »
Quote from: Greg G on August 31, 2008, 05:49:13 am
Greg
PM Jim Ratto. He may be able to order the white stripe point sets, or steer you to a vendor that buys from him.
Last Edit: August 31, 2008, 06:26:28 am by John Rayburn
rebel
Re: blaster coil 2
February 24, 2009, 23:43:26 pm »
I have a Mallory distributor and I'm thinking about putting some extra kiloVolts to bump up the spark.
Thing is... What is a 'ballast resister'?
And where should I look for it?
Hot VWs RULE!
my site:
http://cal-look.pl
my club:
http://cal-look.pl/ssvwf.htm
my blog:
http://www.california-look.blog.pl
my car:
http://cal-look.no/lounge/index.php/topic,6104.0.html
stealth67vw
Re: blaster coil 2
February 25, 2009, 04:00:08 am »
I've been running an MSD Blaster 2 coil, MSD 6AL and a Bosch 010 with an Pertronix Ignitor and resistor less rotor for 3 years of daily driving with no ballast resistor. It came set up like this when I bought the car. .
Do I need one?
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
wolfswest
Re: blaster coil 2
February 25, 2009, 16:23:15 pm »
I tried a blaster coil with a 009 and a compufire in it. Fried 2 compufires...
For me it was a no go.
