September 22, 2026, 05:57:15 am
| | |-+  IRS rear ends......
Pages: [1] 2 3 Print
Author Topic: IRS rear ends......  (Read 54968 times)
« on: August 24, 2008, 22:50:04 pm »
I have been wondering about this for a while now - Does anyone out there Make the brackets to convert a swing axle pan to IRS Huh
Also any other info on what else is involved would be great - Thanks guys  Smiley
« Last Edit: August 24, 2008, 23:29:38 pm by monkiboy » Logged
« Reply #1 on: August 24, 2008, 23:36:44 pm »
its ok I found some - but any info on this conversion would be a great help  Smiley
karl h
« Reply #2 on: August 25, 2008, 07:33:57 am »
i have done a conversion like this in the past, carefull measuring is essential or you end up with non alignable rear end
best is to use a jig
Wout
« Reply #3 on: August 25, 2008, 08:09:11 am »
I think mine are from csp (not sure), and we used a homemade-system to put them correct onto my pan. Friends have made that system on an automatic-pan, so the maesurement is allways correct. The most difficult job is the cutting  Grin, cause you've to cut verry close to the handbrakecable.
Succes!!!
gr
Wout
Aircooled vw's for life!
« Reply #4 on: August 25, 2008, 17:45:49 pm »
Hi Lee, i wanted to do the same, but you NEED a jig. I just scored a automatic pan so i just have to weld in the clutch-cable pipe.
I know youre expensive problem. (shortened pan) Undecided
« Reply #5 on: August 25, 2008, 18:27:48 pm »
Who said this was for a "shortened" pan Wink Smiley
Black Sheep
less is more
« Reply #6 on: August 25, 2008, 19:00:48 pm »
I've got a pair of bracket's knocking about down the garage if you need them  Wink
13.03 @ 98mph
« Reply #7 on: August 25, 2008, 21:11:08 pm »
ohhhh I'll take those off your hands buddy - drop me a PM  Smiley
kev d
« Reply #8 on: August 25, 2008, 21:50:41 pm »
I`ve just made a jig for doing this on my oval`s new pan, easy to do if you have access to an irs pan to begin with.
I can take a pic for you to show how simple it is if that helps?
the `66 nearly done then??
« Reply #9 on: August 25, 2008, 22:00:04 pm »
Cool thanks dude - pic's would be AWSOME  Smiley I have seen several "jigs" on the www, you can even buy one on thesamba.com
http://www.thesamba.com/vw/classifieds/detail.php?id=281289
I was also wondering about 944 trailing arms - do they fit straight in  Huh Smiley
kev d
« Reply #10 on: August 25, 2008, 22:39:54 pm »
944 bits are pretty much a straight fit BUT you need to use the correct age / selection of bits.
I`m sure there will be a couple of loungers who can advise exacty what you need Cool
« Reply #11 on: August 25, 2008, 23:24:59 pm »
COOOL - anyone have some more info  Huh
« Reply #12 on: August 26, 2008, 00:41:56 am »
This is for the '66 I assume? If so, why?
« Reply #13 on: August 26, 2008, 01:17:40 am »
One answer - 901 5 speed  Grin Grin Grin
« Reply #14 on: August 26, 2008, 01:25:21 am »
Ahhh Smiley Have you driven a car with a dogleg 1st gear yet? You might want to give it a try first as it seems people either love them or hate them. I myself, am part of the former Smiley
« Reply #15 on: August 26, 2008, 02:09:14 am »
Thanks for the info dude - I was not aware of the dogleg 1st but I am sure I will be able to handle it  Wink Smiley
it just seems like a REALLY good idea to me - it looks like I will have a similar set up to S.Bleecher - 2110 and a 5 speed  Smiley
plus NO MORE crappy rear hub seals  Roll Eyes Smiley
karl h
« Reply #16 on: August 26, 2008, 06:46:23 am »
i have a 901 fivespeed in my oval with narrowed 944 rear arms/brakes (on an irs pan)
the steel arms fit without mods if you change the bushing to a type 1 bushing /the one that centers the bolt in the bracket)
the aluminum arms fit too, but the are wider (a lot, two differnet versions), you need wider fenders
SteveW
« Reply #17 on: August 26, 2008, 07:14:08 am »
For the most part even stock beetle IRS A Arms are wider than short swingaxle. I didn't realise this until recently so I need to get the arms narrowed and fit slightly wider wings in order for my slicks to have enough clearence!
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
71CALRIPPER
« Reply #18 on: August 26, 2008, 07:37:19 am »
Dude i have a Jig that i can lend out or was thinking of selling if anybody wants to take it of my hands !! Smiley
Only in south london and have done 4 conversions from SA to IRS Smiley
Rob
« Reply #19 on: August 26, 2008, 07:39:51 am »
Rob
Sounds good to me dude PM me your number and we'll sort something out  Smiley
Black Sheep
less is more
« Reply #20 on: August 26, 2008, 08:16:25 am »
Got a 901 in the back of mine , true the dog leg first can be a pain but once you've got used to it you will never go back  Wink
The 5th gear is just the best out on the motor way is just the best, cursing along at 2000 rpm just makes sense with ida's  Cool
Im yet to try it out on the quarter mile , but with enough grunt behind me I should be able to launch in second  Roll Eyes
13.03 @ 98mph
LuftsickTero
« Reply #21 on: August 26, 2008, 08:24:26 am »
I gave the IRS and narrowed rear arms some thought when I dismantled my 'Vert 5 years ago and was going to use 17" Torque Thrust IIs with it but then changed the whole layout for the car.
Got still this article in my bookmarks: http://www.germanlook.com/Html/Tech/Tech12NarrowingIRSArms.htm
« Reply #22 on: August 26, 2008, 09:27:08 am »
So Monkiboy's building a German Look car after all!  Here's me thinking he was building the archetypal 1970s Cal Looker. Grin
« Reply #23 on: August 26, 2008, 09:29:59 am »
 Cry Cry Cry don't be soooooo mean  Cry Cry Cry  at least I will be using a 70's 911 box  Wink Smiley
karl h
« Reply #24 on: August 26, 2008, 10:41:58 am »
i have narrowed a few sets of arms and have made a jig (morten aase runs my arms in his ghia)
Black Sheep
less is more
« Reply #25 on: August 26, 2008, 11:04:49 am »
Yepp narrowed A arms are the way to go , had to narrow mine to get the wheels to sit in right , also re-jigged the shock mounts in the arm's too , what a pain that was  Sad
13.03 @ 98mph
« Reply #26 on: August 26, 2008, 18:10:47 pm »
Yup, I love that 2-3, 3-2 gear change Smiley
« Reply #27 on: August 26, 2008, 18:23:59 pm »
I'll get used to it don't worry guys  Smiley
« Reply #28 on: August 26, 2008, 19:26:26 pm »
Cruising at 2000 rpm is lugging it.
« Reply #29 on: August 26, 2008, 20:35:10 pm »
I think he means for fuel consumpsion purposes - 3000rpm is low enough for me BUT 2000rpm is even better  Cool
