September 22, 2026, 05:19:02 am
carb
Topic: carb (Read 6459 times)
Tom G.
carb
August 27, 2008, 22:16:21 pm »
Delete
Last Edit: September 29, 2008, 20:03:53 pm by Tom G.
Re: Nearly new IDAs with throttle shaft play??Bad!!
August 28, 2008, 03:56:19 am »
Those are the bearings that will work.
You could also go down to your local bearing store and buy some 607-2RS bearings.
7mm ID, 19mm OD, 6mm wide.
Tom G.
carb
August 28, 2008, 13:25:44 pm »
delete
Last Edit: September 29, 2008, 20:04:10 pm by Tom G.
August 28, 2008, 21:08:13 pm »
What brand were they? German FAG? Or SKF?
Tom G.
August 28, 2008, 22:16:41 pm »
delete
Last Edit: September 29, 2008, 19:59:55 pm by Tom G.
Tom G.
September 21, 2008, 15:39:25 pm »
delete
Last Edit: September 29, 2008, 19:58:34 pm by Tom G.
