November 02, 2026, 20:09:34 pm
Would I be overclutched?
Topic: Would I be overclutched? (Read 18094 times)
airstuff
August 29, 2008, 21:08:26 pm »
I'm still deciding on which cam to run in my 2276,but cam choice isn't my question right now.I see a topic about this which is just active
My problem is,that I want to know whether I would have too much clutch with my Kennedy Stage 2 in my 72.street car if I chooce to run something like Engle 125 or other milder cams,milder then FK45 ??
I meen if I have 160hp,is it too much clutch?
airstuff
Re: Would I be overclutched?
August 29, 2008, 21:57:26 pm »
will bw using Daikin disc
just need suggestion,should I sell Stage II and get Stage I,or.......
deanosvws
OFF 24
August 29, 2008, 23:03:54 pm »
i would say a stg 1with a hi-po daiken center, it will be alot easier for street driving and easier to control. cheers dean
OUTLAW FLAT FOUR
August 30, 2008, 02:20:06 am »
Quote from: cal-look on August 29, 2008, 21:08:26 pm
got slicks?
John Rayburn
August 30, 2008, 06:08:44 am »
Stage one is good to about 180 HP. Daiken is always my first and only choice.
I also park at Nick's.
airstuff
August 30, 2008, 08:22:46 am »
Quote from: Bruce on August 30, 2008, 02:20:06 am
got slicks?
no,I don't have slicks
I got this stage 2 balanced with the flywheel,and with the hole combo,and now it would be a shame to have to balance a new clutch again,but If this Stage 2 is a no no for street,then I wil swap it for Stage 1
airstuff
August 30, 2008, 08:23:35 am »
Quote from: John Rayburn on August 30, 2008, 06:08:44 am
But If I already have the Stage 2,would it hurt?Or do I really really need the stage 1
August 30, 2008, 10:26:29 am »
i have a stage 2,
i ll tell you how it works when the car is driving...
i am just going to make a longer "clutch arm" by welding a second one on another one..
you can also buy a 100 mm version i think, i just dont know where...
August 30, 2008, 10:29:09 am »
as far as i know you should be asked how strong is your left upper leg? i have felt a stage 2 and it made me wonder how enjoyable it would be on the street... it's 2100lbs vs 1700lbs, right?
DVK ~
Roman
August 30, 2008, 12:09:43 pm »
I am not big or strong, but I don't think the stage 2 is hard on your leg. If you are waiting at a traffic light you can always put it in neutral until it's green.
I have had cars with a stock clutch that has been harder. I can assure you that my friends Big Block Impala with manual trans, wire clutch and a harder cluch plate gives you a gym session every time he uses it... That's what I call a hard clutch...
airstuff
August 30, 2008, 13:10:24 pm »
Quote from: 67-indeed/DVK on August 30, 2008, 10:29:09 am
for this problem there is a Saco hydraulic clutch kit
airstuff
August 30, 2008, 13:11:51 pm »
Quote from: Roman on August 30, 2008, 12:09:43 pm
Only thing which bothers me,is it to harsh for the engine and the disc in everyday street driving...
August 30, 2008, 17:20:16 pm »
Quote from: cal-look on August 30, 2008, 08:23:35 am
That kind of thinking will make you hate your car when it's done.
With only street tires, they don't have the grip necessary to provide the load that a Stage 2 can counteract.
Last Edit: August 30, 2008, 17:27:21 pm by Bruce
August 30, 2008, 17:23:47 pm »
Quote from: ruff on August 30, 2008, 10:26:29 am
I've "heard" this guy is good to deal with:
http://www.thesamba.com/vw/classifieds/detail.php?id=473781
August 30, 2008, 18:20:47 pm »
I tried a stage 1 pressure plate with the 100mm clutch arm and the pedal felt like a stocker, but obviously gripped much better. I'll be getting 2 or 3 of those from you Bruce, as soon as I get around to measuring some cross shafts.
John Rayburn
August 31, 2008, 01:52:42 am »
You should have no problem with the stage 2 on the street. When all is set up nicely, it is fairly easy to push.
