September 24, 2026, 01:29:46 am
| | |-+  Talking about gauges
Author Topic: Talking about gauges  (Read 6229 times)
« on: August 30, 2008, 19:42:54 pm »
I will maybe soon buy a set of gauges for my vw, and I'm wondering what do I need ? A tachometer of course, and I will add it 3 others gauges. I was thinking about oil pressure, oil temp, and voltmeter or ampermeter. Is that ok to look for a vw engine ?
For the moment I have an og engine but I will put a bigger one one day, and I'd like to buy the full set of gauges at the same time, in case that they change the design of them.
Thx Wink.
« Last Edit: August 30, 2008, 19:50:43 pm by Nico86 » Logged
wolfswest
« Reply #1 on: August 30, 2008, 20:05:58 pm »
I have the same setup and it does the job on a 2179 IDA engine...  I have a voltgauge.
Oil temp and pressure are the most important I guess.
« Reply #2 on: August 30, 2008, 23:19:07 pm »
Thanks for your reply, I was not so wrong  Cheesy.
Some choose amperemeter instead of voltmeter, I always heard that it's better to keep an eye on amps than on volts, what do you think ?
« Last Edit: August 30, 2008, 23:27:49 pm by Nico86 » Logged
youngnstudly
« Reply #3 on: August 31, 2008, 04:06:09 am »
I'd say cylinder head temp is more important than volts or Amps....If you have charging issues, you'll know it without needing the gauge to tell you!
« Reply #4 on: August 31, 2008, 08:07:51 am »
I agree with that.  The indicator light on the speedo is all you need for the electrical system.
« Reply #5 on: August 31, 2008, 20:02:14 pm »
Thanks guys, I'll maybe find a place for a 4th gauge.
