October 04, 2026, 10:30:29 am
352313 Posts in 28957 Topics by 6925 Members
| | |-+  Wings/aerofoils Are they really needed? and if so when?
Pages: 1 ... 3 4 [5] 6 7 ... 13 Print
Author Topic: Wings/aerofoils Are they really needed? and if so when?  (Read 590753 times)
Prowagen
« Reply #120 on: September 05, 2008, 21:57:41 pm »
FFS John you have had me in stitches with a couple of your posts Grin What a grreat addition to the lounge!
John Maher
« Reply #121 on: September 05, 2008, 23:06:38 pm »
John, the car is actually quite heavy, but with the excitement of a days racing ahead, I normally loose a few pounds in the morning before getting in the car!
I figured 1584lb inc driver was pretty light for a street car....  unless you're the totally wasted, strung out junkie type  Wink
I know worshipping the weight God can be seriously addictive
John Maher
ESH
« Reply #122 on: September 05, 2008, 23:20:54 pm »
 Grin
John Maher
« Reply #123 on: September 05, 2008, 23:30:21 pm »
And the Audi A2 has a Cd of just 0.25 – how about racing one of those? Perfect for the VWDRC... Wink
Probably more in keeping if fitted with a Subaru engine  Wink
John Maher
John Maher
« Reply #124 on: September 05, 2008, 23:39:44 pm »
 Grin
Q.  What's black and yellow and full of shit?
A.  A Netto bag
   Grin
« Last Edit: September 05, 2008, 23:42:39 pm by John Maher » Logged
John Maher
Stephan S
« Reply #125 on: September 06, 2008, 00:07:41 am »
Hot Rod Magazine had some interesting articles about the subject:
http://www.hotrod.com/techarticles/body/hdrp_0609_aero_tricks_tips/index.html
... and...
http://www.hotrod.com/techarticles/body/113_0703_car_aerodynamics/index.html
« Reply #126 on: September 06, 2008, 00:25:57 am »
Thanks stephan,at last we are getting back on track Roll Eyes
cheers richie
John Maher
« Reply #127 on: September 06, 2008, 00:46:32 am »
<Serious head back on>
Great articles. Thanks for posting the links. Printing them off to add to the library.
Looks like they cover just about everything under discussion on this thread, and more.
Here's a link to the A2 wind tunnel mentioned in the feature
http://www.a2wt.com/Wind%20Tunnel%20Testing.htm
Shame we don't have such a facility in the UK: $345 per hour for the first 2 hours!
John Maher
beetletom
« Reply #128 on: September 06, 2008, 12:58:29 pm »
years ago,drag beetles uses to have the metal covers over the a post gutters?
was that for aerodynamics? Huh
« Reply #129 on: September 06, 2008, 14:50:43 pm »
See post on page 3...  Wink
beetletom
« Reply #130 on: September 06, 2008, 15:22:51 pm »
thanks!  Cool
« Reply #131 on: September 06, 2008, 19:54:21 pm »
When doubling speed, drag increases x 4 but the amount of horsepower required to overcome extra drag goes up by cube of speed - factor of 8
Beetle takes something in the region of 25hp to travel at steady 60mph on a perfectly flat road on a calm day.
Approx 200hp at 120mph
This is correct.
Working off that theory, aiming for 150mph terminal speed when you're used to maxing out at 140mph will require a 56% increase in horsepower  Shocked  Shocked
... assuming aero is the factor holding you back - not traction/handling/gearing etc
(140 to 150mph = 7% increase. 7% x 8 = 56%)
However, you haven't applied the math correctly here.
(150/140)cubed is the factor.  In this case it is 1.2299, or 23% more hp.
John Maher
« Reply #132 on: September 07, 2008, 00:29:03 am »
This is correct.
Thanks Bruce, you're absolutely right   Embarrassed
Maybe best not to inform Richie.... if he increases power by 56% we may yet see a full 1/4 on two wheels  Cheesy
JM
John Maher
« Reply #133 on: September 07, 2008, 02:35:46 am »
Oops, never thought of that!  If he did increase hp by 56%, he'd be up to 162mph.
« Reply #134 on: September 07, 2008, 10:33:56 am »
Mmmm,I will stick with the 56% extra just to make sure Cheesy   box is geared for 164mph@8000rpm in 4th so sounds about right,and all that without any hideous wings?
cheers richie
Martin
Cash Converter....
« Reply #135 on: September 07, 2008, 15:29:45 pm »
Now thats what I'm talking about! lol
Martin
www.taylormachine.co.uk
OFF/500
Martin
Cash Converter....
« Reply #136 on: September 09, 2008, 15:06:02 pm »
just found this.
AERODYNAMICS
The Cx of the Beetle, measured in the wind tunnel of the Polytechnic of Stoccarda on the final prototype, measured just 0,385. This datum increased to 0,41 in the mass-production, but in any case it remained an exceptionally low value for the epoch (we were in '38!); you have to think that the aerodynamic Lancia Aprilia hardly reached the 0,47 (0,44 a Fiat127 and 0,41 the first model of the Golf). The datum was also confirmed by the particularly low value of the absorbed power to travel to 100 km/h: only 15 CV. To make a comparison you have to think that a modern Volkswagen Pole first series absorbs 17,2 CV at the same speed. Anyway, you have to notice that the aesthetic modifications introduced in the '67 (squared bumpers and vertical headlights) made the Cd of the Beetle meaningfully worse and in the last models it appeared to be equal to 0,48.
http://www.maggiolinoweb.it/technique.html#cx
Just some more ifo to throw into the pot.
Bit more info...
Found this site with a Aerodynamics database, shame the beetle isnt on it. but take a look and you can see the lift at speed created .
http://www.mulsannescorner.com/data.html
Martin
OFF/500
JamieL
« Reply #137 on: September 10, 2008, 13:12:32 pm »
Wasn't the "beetle" originally designed to have lift in order to allow a "high" top speed with a low power requirement by reducing the rolling resistance/friction - along with the whole "maximum speed is cruising speed" thing...?
Martin
Cash Converter....
« Reply #138 on: September 29, 2008, 20:32:22 pm »
I was at the track this weekend and only managed one high speed run the others were in the 130's more findings for you from the data logs
over the finish line 145.68 mph the suspention logs say that the car is at the same ride hight as 130, its a little higer than normal ride hight. but it felt diferant. All i can put this down to is as the tires have gotten taller the castor has reduced making the car feel a little less directed. Im going to try and increase the caster to see if this cures this little odd feeling.
going to put the suspention sensors on the front next to see what the ride hight of the car is at the top end. might try and inclanometer, but i think the G's will confuse it.
Other than thats it felt fine, but man the breaks are rubbish!! lol
Martin
OFF/500
« Reply #139 on: September 30, 2008, 04:08:50 am »
Doubtful.  Any change in the friction in the bearings and tires is microscopic compared to the wind resistance at 60mph.
benssp
www.callookvw.com
« Reply #140 on: September 30, 2008, 07:57:24 am »
145! what times were you running?
www.vwheritage.com  My Job
YMCA
Martin
Cash Converter....
« Reply #141 on: September 30, 2008, 09:27:10 am »
10.10 with a 1.68 60ft, going to be working real hard on the 60 ft at night of fire
Martin
OFF/500
benssp
www.callookvw.com
« Reply #142 on: September 30, 2008, 09:39:18 am »
the axles stayed together then!
YMCA
« Reply #143 on: September 30, 2008, 12:56:40 pm »
Has Boom Boom been teaching you how to launch? Cheesy
Seriously, what sort of 60ft times are you expecting out of the car eventually? I know street tyres are a limiting factor, but 1.40's can't be far off? Smiley
Martin Greaves
10.88@128.58
« Reply #144 on: September 30, 2008, 17:51:23 pm »
See you don't need low 60ft's to go quick. Grin
Martin
Cash Converter....
« Reply #145 on: September 30, 2008, 18:53:09 pm »
yeah but there nice!
Martin
OFF/500
Airspeed
« Reply #146 on: October 01, 2008, 18:00:36 pm »
1.68 60 ft is still very quick by my standards  Cheesy
What tires do you use Martin?
Martin
Cash Converter....
« Reply #147 on: October 02, 2008, 07:56:28 am »
micky Thompson sportsman pro's, its about the only option for street eliminator as i feel the drag radials are far too heavy for my axles to cope with.
there no problem with traction
Martin
OFF/500
« Reply #148 on: October 04, 2008, 22:46:45 pm »
OK i think along all the pages it has been said that if you fit a way it should be done with the aid off a windtunnel as there are too many things to consider. however i want to put my damn heavy car at your disposal Richie if you bring the trans and engine and see what happens. i'll let you even drive once in a while to continue your studies and observations.
But on a more serious note i do think that aerodynamics are a strange thing when you look at dragrace cars covering the 1/4mile. your car Richie does wheelies and catches a LOT off air and wind on the first gears and still manages to go fast. it isn't lowered that much so i guess it takes a lot off wind under the car as well. so i believe there are a few ways around the problem and depending on the car different solutions will be found. and indeed on most cars the wing is a teacup stand and not much else.
« Reply #149 on: October 05, 2008, 21:22:38 pm »
... Richie does wheelies and catches a LOT off air and wind on the first gears and still manages to go fast.
Wind resistance is trivial at the speeds where Richie is showing off.
