October 13, 2026, 21:29:41 pm
| | |-+  Jetting * please help
Author Topic: Jetting * please help  (Read 4699 times)
lowfastbus
WUNDERWAFFE
« on: September 02, 2008, 20:42:07 pm »
Hi guys,
After having my engine in the car for a few years I decided to try and make it a lil bit better.
When it was just finished I did a 13.5 on my first race meeting, year after 13.6, then 13.9 last year.
This year i changed the gearbox ( stock 1200 to stock 1600) because it broke on the 13.9 run. I also lowered it a bit in the rear to make it more stable.
I did several low 14s this year with a best off 14.04 at 97 mph.
All times where on street tires with a double quiet pack (13.6 run with A1 turbo muffler) and without belt.
To make it faster again I now cleaned the carbs, checked my jetting and gonna change or clean the plugs.
Jetting
155 main gas
180 air corr
F7 emulsion tubes
38 venturis
F10/70 idle
engine is a 2054 with FK10, wedge port heads and 9.5 compression
Any suggestions on the jetting or other tips to make it faster would be appreciated.
Thx
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
LGK
« Reply #1 on: September 03, 2008, 11:01:00 am »
1 way...get it on the dyno Jelle and go from there...
I'm in the south of france right now some 30° in the sun  Wink Wink
I  can help you out when i'm back,on the 15 september the shop will be open again!
Cheers Steve
« Reply #2 on: September 03, 2008, 22:22:59 pm »
38mm venturies? Don't you mean 37?
Roman
« Reply #3 on: September 03, 2008, 22:46:47 pm »
Try a 55 idle jet and adjust the mixture screws again.
