September 24, 2026, 05:43:15 am
| | |-+  IRS vs Swing
Author Topic: IRS vs Swing  (Read 11229 times)
« on: September 17, 2008, 02:46:05 am »
Other than strength and lower cost, is there any real advantage to swing vs IRS in a hipo VW? I am kicking the idea around of converting the '67 to IRS. (Using an IRS pan that is in better shape than my SA pan.) If I did this I could either go with a Type 1 5 speed or maybe even one of the new berg Type 2 5 speed conversions. Mike Gagen's red car had a bus five speed in it if I remember correctly. Do they make a limited slip for the bus box? Then the weak link would be the CVs and stub axles. Any thoughts?
« Reply #1 on: September 17, 2008, 03:15:00 am »
There's nothing weak about IRS.
« Reply #2 on: September 17, 2008, 03:59:41 am »
As far as I know there is no LSD avaliable for the T2 trans. I hear the "hot" setup is using a locking diff from a Syncro Vanagon.
IRS will always ride and handle better (at the cost of added weight, and more parts that may fail), but a properly set up swingaxle isnt anything to sneeze at. You'll have to figure out what is important for you.
Sam K
« Reply #3 on: September 17, 2008, 04:45:22 am »
The only thing I like about IRS over swing is the ease of chaging transmissions. After destroying 12 swingaxle transmissions in my '67, I decided that the race bug I'm building will be an IRS car with a bus gearbox from the start.
stealth67vw
« Reply #4 on: September 17, 2008, 05:19:19 am »
ZFs were available for T2 gearboxes. These are 091 ZFs from Bruce's gallery on the samba
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
karl h
« Reply #5 on: September 17, 2008, 07:03:30 am »
in germany (and austria for that matter) all the ambulances had LSDs, T1 and T2
« Reply #6 on: September 17, 2008, 07:15:36 am »
Sweet. That's good to know!
« Reply #7 on: September 17, 2008, 10:02:15 am »
so, what's stronger about a bus tranny?
the reduction boxes?  Wink
Bewitched666
Bewitched
« Reply #8 on: September 17, 2008, 12:19:33 pm »
I use a mendeola in my pro stocker Wink
Fast vw beetle's rule
benssp
www.callookvw.com
« Reply #9 on: September 17, 2008, 13:27:50 pm »
Think they are referring to a bay bus box(091 6 rib case), lots of the outlaw flat four use them and manage to break anything but the box! Grin
www.vwheritage.com  My Job
YMCA
« Reply #10 on: September 17, 2008, 14:20:26 pm »
After sleeping on it I think I will stick with the SA pan. Its was just one of those ideas that come to you late at night. Thanks for the input thought.
« Reply #11 on: September 17, 2008, 15:59:37 pm »
I.R.S. transmission with Porsche 930 constant velocity joints.
Germanlkmanx
« Reply #12 on: September 17, 2008, 20:11:49 pm »
Quaife make a LSD for the 091 trans. 091 (and the IRS that goes with it) is the only way to go IMO if you're gonna get serious about going quick.
tom.
« Reply #13 on: September 18, 2008, 08:29:28 am »
You sure about that?
http://www.quaife.co.uk/shop_category.cfm/category_id/1274/category_id/1274
Look at the product code for the Combi diff then compare it to the one for the Beetle diff with Bus spline.  Pic is the same too.
Peloquin makes an LSD for the Bus 'box.
ZF made 2 completely different LSDs for Bus 'boxes.  002 and 091/094
