September 22, 2026, 01:30:15 am
| | |-+  Berg 5 mid mount question
Author Topic: Berg 5 mid mount question  (Read 8593 times)
« on: September 18, 2008, 17:07:32 pm »
A quick question for those that have installed a Berg 5. Is the mid mount located in the same location as the 4 speed mid mount? What I am getting at is can I use a regular 4 speed tranny to mock up the mid mount for welding to the chassis?
Thanks,
« Reply #1 on: September 18, 2008, 17:31:36 pm »
I thought the Berg 5 was slightly longer in overall length. Don't know if that will alter the mount location on the chassis.
John Rayburn
« Reply #2 on: September 18, 2008, 23:31:25 pm »
Yes, the mount will hit in the same spot. Mark, it's longer from that spot, forward.
I also park at Nick's.
ian c
« Reply #3 on: September 19, 2008, 00:35:19 am »
http://www.cal-look.com/forum/index.php?topic=21897.0
http://www.cal-look.com/forum/index.php?topic=23151.msg239547;topicseen#msg239547
(o\ ! /o)
« Reply #4 on: September 19, 2008, 03:05:12 am »
That is what I was thinking but was not sure. Thanks John.
« Reply #5 on: September 19, 2008, 05:15:49 am »
I will have to look, but I have genuine bus rubber mounts for my Berg 5 mid mount.  I will try to get the PN off of them.  They are much more solid (higher durometer) than the Berg rubber mounts.  Steve Hollingsworth gave them to me.  They are a VW PN, that I will have to look up.  The Berg mounts are too soft.  Ask just about anybody.  If I can read the number on the mount I will post it here.  Time to go to the junk yards and look.  As near as I know they are no longer available.
John Rayburn
« Reply #6 on: September 19, 2008, 05:53:12 am »
Louis, do yourself a favor and get a couple aluminum slugs the height of the rubber. Throw the rubber in the trash. The aluminum dampens sound amazingly well. Way better than urethane, in fact. When I went the 5 speed route, I had to do this to keep it from going from 2'nd to 5'th in a speed shift due to the trans blubbering around on the mid mount, even with  the traction bar cranked way tight. Urethane helped and showed me I was on the right track, and the aluminum sollved it completely. It worked well enough for the Bergs to include the aluminum option with the mount. Simple little fix.
« Reply #7 on: September 19, 2008, 08:52:03 am »
Would adding a pad of rubber, say 3mm thick, on top of the aluminium block which would be shortened by the same amount, be a good idea to dampen noise further? There wouldn't be much deflection but just enough movement to dampen the sound. Huh
John Rayburn
« Reply #8 on: September 19, 2008, 09:03:40 am »
I actually did try that, but made no difference. The rubber deteriorated quickly from the tight squeeze,and made no difference in sound. The aluminum is actually very quiet , it's even quieter than the urethane I tried. Much quieter, and completely solved the movement issues.
« Reply #9 on: September 19, 2008, 12:55:17 pm »
Good info on the rubber mounts. When I order the mount I will get the aluminum slugs instead. Thanks again guys.
