September 22, 2026, 04:34:02 am
Berg 5 mid mount question
Topic: Berg 5 mid mount question (Read 8604 times)
September 18, 2008, 17:07:32 pm »
A quick question for those that have installed a Berg 5. Is the mid mount located in the same location as the 4 speed mid mount? What I am getting at is can I use a regular 4 speed tranny to mock up the mid mount for welding to the chassis?
Re: Berg 5 mid mount question
September 18, 2008, 17:31:36 pm »
I thought the Berg 5 was slightly longer in overall length. Don't know if that will alter the mount location on the chassis.
John Rayburn
September 18, 2008, 23:31:25 pm »
Yes, the mount will hit in the same spot. Mark, it's longer from that spot, forward.
I also park at Nick's.
ian c
September 19, 2008, 00:35:19 am »
http://www.cal-look.com/forum/index.php?topic=21897.0
http://www.cal-look.com/forum/index.php?topic=23151.msg239547;topicseen#msg239547
(o\ ! /o)
September 19, 2008, 03:05:12 am »
Quote from: John Rayburn on September 18, 2008, 23:31:25 pm
That is what I was thinking but was not sure. Thanks John.
September 19, 2008, 05:15:49 am »
I will have to look, but I have genuine bus rubber mounts for my Berg 5 mid mount. I will try to get the PN off of them. They are much more solid (higher durometer) than the Berg rubber mounts. Steve Hollingsworth gave them to me. They are a VW PN, that I will have to look up. The Berg mounts are too soft. Ask just about anybody. If I can read the number on the mount I will post it here. Time to go to the junk yards and look. As near as I know they are no longer available.
John Rayburn
September 19, 2008, 05:53:12 am »
Louis, do yourself a favor and get a couple aluminum slugs the height of the rubber. Throw the rubber in the trash. The aluminum dampens sound amazingly well. Way better than urethane, in fact. When I went the 5 speed route, I had to do this to keep it from going from 2'nd to 5'th in a speed shift due to the trans blubbering around on the mid mount, even with the traction bar cranked way tight. Urethane helped and showed me I was on the right track, and the aluminum sollved it completely. It worked well enough for the Bergs to include the aluminum option with the mount. Simple little fix.
September 19, 2008, 08:52:03 am »
Quote from: John Rayburn on September 19, 2008, 05:53:12 am
Would adding a pad of rubber, say 3mm thick, on top of the aluminium block which would be shortened by the same amount, be a good idea to dampen noise further? There wouldn't be much deflection but just enough movement to dampen the sound.
John Rayburn
September 19, 2008, 09:03:40 am »
I actually did try that, but made no difference. The rubber deteriorated quickly from the tight squeeze,and made no difference in sound. The aluminum is actually very quiet , it's even quieter than the urethane I tried. Much quieter, and completely solved the movement issues.
September 19, 2008, 12:55:17 pm »
Good info on the rubber mounts. When I order the mount I will get the aluminum slugs instead. Thanks again guys.
