September 22, 2026, 14:56:43 pm
| | |-+  Body to pan sealant - what do you use?
Author Topic: Body to pan sealant - what do you use?  (Read 8391 times)
« on: September 23, 2008, 09:59:36 am »
Well, tonight's the night - the body SHOULD be going onto the floorpan in just under 12 hours time! I've got a new floorpan gasket but I was wondering - do you guys use any sort of sealant with the gasket, and if so, what? Huh
« Reply #1 on: September 23, 2008, 10:04:00 am »
i only used some car rubber window glue to hold it down in places.
Matty c
« Reply #2 on: September 23, 2008, 20:35:39 pm »
i used tiger seal, works a treat Cool
67heaven
« Reply #3 on: September 23, 2008, 21:59:43 pm »
The factory used nails to hold the gasket in place !
 Shocked
« Reply #4 on: September 24, 2008, 03:16:53 am »
At the end they were using really sticky close cell foam tape.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #5 on: September 24, 2008, 05:17:31 am »
I nailed my gasket back to the original holes.
benssp
www.callookvw.com
« Reply #6 on: September 24, 2008, 08:53:57 am »
where can you get the nails from? Grin
www.vwheritage.com  My Job
YMCA
« Reply #7 on: September 24, 2008, 09:30:14 am »
I saved a couple of mine - they're the twisted ones that drive round when you hammer them in, same as the carpet ones. Most were well rotten tho! Cheesy
Didn't get the body on so got another couple of days for any more suggestions.
My main concern is that the replacement pan halves and replacement heater channels are both repro bits so the fit might not be too good. My other bug (replacement channels, original floorpans) leaks in the footwells slightly in really heavy rain with just the pan gasket and no sealant, so I want to avoid this if possible. There was what felt like a sticky grease on front and rear bulkheads, so i'm guessing that the factory didn't just rely on the rubber.
benssp
www.callookvw.com
« Reply #8 on: September 24, 2008, 09:31:58 am »
maybe some red rubber grease, i don't think it sets
YMCA
69Stu
« Reply #9 on: September 24, 2008, 12:50:21 pm »
I have used Sikaflex on the past two floorpan gaskets that I have done. This stuff is an adhesive and sealant, so you can stick the gasket to your floorpan, and then it doesn't move when you put the body on.
http://www.merlinmotorsport.co.uk/TRIM-Adhesive/c516_517/p6080/BLACK-SIKAFLEX-221/product_info.html?osCsid=d01b7608541e1345284d91e9412cceaf
