September 21, 2026, 18:25:01 pm
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  oil pressure and temp sender size
Author Topic: oil pressure and temp sender size  (Read 7714 times)
wolfswest
« on: September 26, 2008, 07:56:22 am »
Hi,
I'm planning to order my vdo temp and pressure senders but I have one last question.
I'm going to fit these with the "Tee" fitting so I can use two senders in one place.  The hole near the distributor on the left side where the original idiot light sender is...
Is this 1/8 27 npt  or m10 x 1  ?  I have an autolinea case if this helps...
thx
Dem
benssp
www.callookvw.com
« Reply #1 on: September 26, 2008, 08:50:41 am »
M10 x 1 VDO#v240850 Smiley
www.vwheritage.com  My Job
YMCA
wolfswest
« Reply #2 on: September 26, 2008, 09:24:53 am »
yeah,
but when you look in the books and most internetshops (aircooled ones) they sell the 1/8 npt models...  Huh
So I'm a little bit confused here?  I already have a "Tee" part that I used with my autometersenders so I guess this is 1/8 npt because autometer supplies standard the 1/8 npt models...  Correct me if I'm wrong
Dem
benssp
www.callookvw.com
« Reply #3 on: September 26, 2008, 09:31:41 am »
You will find most autometer senders are Imperial, VDO do senders in metric, your just not checking the right shop Grin
senders
http://vwheritage.com/ssp/Gauges-Senders/VDO-Senders/?srchPart=V240850
gauges
http://www.vwheritage.com/ssp/Gauges-Senders/VDO-Gauges/?templateID=ssp
YMCA
wolfswest
« Reply #4 on: September 26, 2008, 09:43:25 am »
 Grin  My mate has a tool to check which wire is on it...  I will test it first before I order parts.
my "Tee" part that I already used with my autometersenders is from vdo...
Tony M
« Reply #5 on: September 26, 2008, 21:00:31 pm »
I use a double " T " autometer pressure sender only for the guage, wanted the idiot light too.
