September 22, 2026, 03:39:21 am
| | |-+  82 mm Crank brand??
Author Topic: 82 mm Crank brand??  (Read 4739 times)
RMS Boxer Service
« on: September 28, 2008, 18:06:53 pm »
Hello fellow Loungers  Smiley
I got a old but never used 82 mm stroker crank dirt cheap with stock rods (cleared and balanced)
and the seller did'nt know anything about it. First I thought it was a cast crank, but it sure ping/ring
like a good old german stock crank. All jurnals are 0,010" under and  the crank have the numbers
010 stamped at a rod journal and at a main journal. The oil holes at the rod journals are not camfered
like on other cranks I have seen, but the main journals are. The oil plugs in the crank looks like lead.
I have attached a few pictures of the crank.  Does anybody got a clue what brand this crank is and
would it be ok for a 120-140hp 2110 cc street engine for a Oval bug??
/Rolf
« Last Edit: September 28, 2008, 18:09:28 pm by Callook_67 » Logged
Germanlkmanx
« Reply #1 on: September 28, 2008, 19:03:37 pm »
Seem to be a few of these turning up at the moment! I found one in a motor the other day too..
Take a look here:
http://www.cal-look.com/forum/index.php?topic=28042.0
tom.
2manytoys
« Reply #2 on: September 28, 2008, 19:32:07 pm »
Maybe an old Claudes Cracker? I had an 82 CB cast in the Green M&M back in the 80's early 90's.
Patrick Friel -..2manytoys, not enough time or money
Germanlkmanx
« Reply #3 on: September 28, 2008, 19:43:14 pm »
Haha, claudes cracker, I like it!
I'm going to put mine to 6500rpm nitrous abuse in the back of my Notchback. I wonder how many seconds of run time i'll get out of it? Cheesy
single oilway case, knock off stock rods, 92mm pistons...it's going to be a STF beast i'll tell you!
tom.
