October 12, 2026, 16:12:13 pm
| | |-+  some work
Pages: 1 2 [3] 4 5 ... 7 Print
Author Topic: some work  (Read 140033 times)
« Reply #60 on: November 30, 2008, 19:54:20 pm »
next step go to the sandblaster to clean and remove the grease on the gearbox   Wink
I have industrial detergent and high pressure cleaner that will make some miracle to remove all the dirt on your gearbox.  Wink
If there is too much grease and dirt on, the sandblaster will have some problems because sand will stick in the grease.
« Reply #61 on: November 30, 2008, 19:57:55 pm »
j-f i will call you  Wink
« Reply #62 on: November 30, 2008, 20:34:41 pm »
Ok,
« Reply #63 on: December 10, 2008, 18:44:10 pm »
saturday, j-f & i  , have cleaning my gearbox with very good product to remove the grease  and yesterday the gearbox went to the sandblaster to be sanded and painted  aluminium color
pict follow tomorrow
« Reply #64 on: December 11, 2008, 19:36:28 pm »
today i pick up my gearbox at the sandblaster
« Reply #65 on: December 11, 2008, 19:54:29 pm »
someone can be help me with those number Huh
thx
fabs
roland
lates are the new splits...
« Reply #66 on: December 11, 2008, 22:25:12 pm »
AB    4.375 (8x35)    Trompettes    3.80/2.06/1.26/0.89    Jusqu'au 08/70   Wink
« Reply #67 on: December 11, 2008, 22:47:44 pm »
Fabs, You ARE going to have the gearbox taken apart don't you ? (Because no matter how much maskingtape you put on it, the blasting medium WILL be IN your gearbox).
« Reply #68 on: December 11, 2008, 22:50:15 pm »
I was thinking the same thing...
« Reply #69 on: December 11, 2008, 22:58:38 pm »
hurry i will remove the nose  to cleaning the inside  and I put 2 wooden slices squeezed(tightened) well against the flask of trumpets before the sanding and the water cleaning with j-f and furthermore I had to move the diffl and to fill the inside with rags and has the first one sight there was no sand  Wink
it's not the first time i do that job  Grin Grin
thx for the words   and thx roland Wink
fabs
« Last Edit: December 11, 2008, 23:11:41 pm by speedwell » Logged
« Reply #70 on: December 11, 2008, 23:14:31 pm »
Fabs, i'm not underestimating your work (heaven forbid) Just to make sure......
« Reply #71 on: December 11, 2008, 23:26:09 pm »
Grin Grin....... Wink
« Reply #72 on: December 11, 2008, 23:33:59 pm »
fabs
Fabs, maybe i sound stupid, but when you have the cover off i would water/chemical clean it again from the inside. It's the grit/sand you DON'T see..... Again, just to make sure. Cool
« Reply #73 on: December 12, 2008, 10:59:25 am »
fabs
thx harry
« Reply #74 on: December 12, 2008, 11:34:18 am »
Did you block the small breather hole in the intermediate case, too?
« Reply #75 on: December 12, 2008, 12:57:50 pm »
the small hole on the nose  yes
Type1/DVK
« Reply #76 on: December 12, 2008, 13:29:45 pm »
replaced the driveshaft oil seal? btw, i'm with hurry about the sand, it will go everywhere!
Germanlkmanx
« Reply #77 on: December 12, 2008, 15:23:14 pm »
Hey Fabs,
Unrelated to your gearbox stuff, can you tell me where you got the speedwell horn push setup from?
thanks,
tom.
« Reply #78 on: December 12, 2008, 15:56:06 pm »
i bought the steering wheels like this i just added the stickers speedwell on the hub , this one is in plastic
« Reply #79 on: December 12, 2008, 15:58:35 pm »
i bought this one in 97 in a local swap meet (all marks) just for 75€  Shocked Shocked Shocked
« Reply #80 on: December 21, 2008, 19:39:54 pm »
today  i work on the gearbox , new mainshaft seal  and put back the plate around the mainshaft
« Reply #81 on: December 21, 2008, 20:48:34 pm »
and after put the new the cross shaft and the new throw out bearing
 I had hard to put back the new spring for the arm control lever for the  clutch cable
And in the story a piece of aluminium it is just broken behind the control lever or the spring comes to put itself above ( Red arrow) Roll Eyes Roll Eyes
« Reply #82 on: December 21, 2008, 20:57:30 pm »
i had cleaning the nose , no sand  inside, and no sand inside the gearbox  Wink
« Reply #83 on: December 24, 2008, 17:53:18 pm »
guys i need help i don't remember on wich side the diff is mount
does goes by the right or the left of the gearbox Huh.................. Roll Eyes Roll Eyes i forgot  Roll Eyes Roll Eyes Sad
help thx
« Reply #84 on: December 24, 2008, 18:06:13 pm »
Depends if you want 4 forwaed gears or 4 reverse gear  Grin Grin Grin
« Reply #85 on: December 24, 2008, 18:07:30 pm »
  Angry Angry ...........funny gary................... Roll Eyes............4 forward gears  Shocked
« Reply #86 on: December 24, 2008, 18:24:18 pm »
by the left  Roll Eyes  is that correct  Roll Eyes
« Reply #87 on: December 27, 2008, 17:44:46 pm »
yes
« Reply #88 on: December 27, 2008, 18:26:43 pm »
thx nico Wink  i was thinking that nobody want to help me here  Cry
monday i will working on  the gearbox again  put the diff inside and the short axle
« Reply #89 on: December 27, 2008, 18:49:57 pm »
Hey buddy there is another cool little trick you can do - you should replace ALL the gearbox case nuts and washers with brand new items (maybe stainless Undecided) it just gives the gearbox a really nice detailed finish  Smiley
