October 12, 2026, 17:17:29 pm
some work
5
6
7
Topic: some work (Read 140052 times)
Jakke
Re: some work
Reply #150 on:
March 08, 2009, 09:03:41 am »
wow, that's a very cool car
cheers
jan
Last Edit: March 08, 2009, 09:07:45 am by Jakke
Re: some work
Reply #151 on:
March 08, 2009, 09:42:07 am »
Quote from: Shubee2 (DSK) on March 08, 2009, 02:24:32 am
Quote from: speedwell on March 07, 2009, 21:14:06 pm
today nicolas and i have purged the brake line , now the brake drums work well ,
we go for a ride in the 61 to test the brake , the engine turn well , but when we go on the street no power/boost , the engine sound like on 3 cylinders , we return to the house , to check the plugs wires , but no problem , we have check the ignition , nothing , may be the carbs
nicolas can you explain to the other the problem may be You will better know how to explain that I
here're some pictures of the car with his news shoes
Hi Fabs Car Looks Great With The Torkers
But those Caps have to Go!! The Knock Offs Look Good talk To Rayburn He put them on His Car?
yes but john 've disc brake at the front and maybe the hub on the disc are machined one , mine are original one and i need one for the speedo cable
Re: some work
Reply #152 on:
March 08, 2009, 09:56:20 am »
I love the wheels!
WCB Hitler's Hot Rod
Re: some work
Reply #153 on:
March 08, 2009, 10:34:06 am »
Looks and sounds good sir!
Re: some work
Reply #154 on:
March 08, 2009, 10:53:55 am »
thx for the words guys
i hope that we are going to find the problem of the loss of power when we drive
no one 've an idea about that
iginition is good , plugs wires give the power to the spark plugs , the engine turn well when he does'nt drive and we're on the road he sound like of an engine which turns on 3 cylinders
When I moved the engine, I moved the linkage without touching the regulation of this one, nor in regulations of carburettors
keith can you help me
i suppose that you know the sprintkit , you're mr speedwell in england
thx
fabs
dirk zeyen
Re: some work
Reply #155 on:
March 08, 2009, 11:58:39 am »
looks great with the new wheels!!!
will take some pictures in spa, chimay, drag day...
dirk zeyen
back again!!!
Rocket Ron
It's old school for a reason
Re: some work
Reply #156 on:
March 08, 2009, 15:39:12 pm »
just got back from Austria and managed to pick up a copy of the super vw s on the way home , must say what a great spread
13.12 @ 101.84
Grooving out on life
Re: some work
Reply #157 on:
March 08, 2009, 19:29:42 pm »
The wheels are lookin' good Fabs,but sorry can't help with the problem.
I hope someone can.
C.U @ freddyfiles
Re: some work
Reply #158 on:
March 08, 2009, 19:35:57 pm »
With those tires, it wouldn´t hurt with a 2-3cm lowering in the rear. IMVHO.
Re: some work
Reply #159 on:
March 08, 2009, 19:39:12 pm »
yes johnny but i will see if the car will down a little after driving the car some kms
the front is good for me but the rear will be better a little bit lower
Last Edit: March 08, 2009, 19:41:21 pm by speedwell
Re: some work
Reply #160 on:
March 08, 2009, 20:56:11 pm »
allright, so i have been asked to help out with the brakes and that went good. JS is right it will need to be a bit lower at the rear, but the car has to settle first, allthough i doubt it will drop enough to get the stance just right.
but the biggest issue was indeed the engine.
i am not sure how sensitive these sprintkits are, but the engine wasn't happy, that is for sure. like fabs said the engine was turning OK at idle but as soon as you got going the car bogged and lost all power. it felt like a plugged idle jet or a distributor that was incorrectly set, but i havent any clue on how to adjust those britisch carbs. i have got some info from Fabs but part off it was missing (speedwell fitting instructions and they refer to pamlphlet G 66/SB211 which i haven't found and makes things even worse. so any help on these carbs is welcome)
we tried to set the distributor right, but that didn't change anything the lack off power under load stayed. i wish i could have worked on the engine longer, but i had other things to do, so hopefully your input can help Fabs out.
Re: some work
Reply #161 on:
March 08, 2009, 21:00:00 pm »
thx for the help nico
Re: some work
Reply #162 on:
March 08, 2009, 21:16:29 pm »
I have a progressive carb if you want Fab
Re: some work
Reply #163 on:
March 08, 2009, 21:20:39 pm »
Quote from: j-f on March 08, 2009, 21:16:29 pm
no thx j-f
Re: some work
Reply #164 on:
March 08, 2009, 23:37:56 pm »
Quote from: nicolas on March 08, 2009, 20:56:11 pm
Sounds very much like an air leak guys - I know there are a number of "sealing" surfaces involved in these kits/manifolds - Just a thought guys
Re: some work
Reply #165 on:
March 09, 2009, 08:41:22 am »
I also have think about air leaks and try to locate it by spraying "start Pilote" where the carbs seals on the manifold and don't notice an idle variation.
Engine start easily and idle well but revs lazily.
Last Edit: March 10, 2009, 14:03:40 pm by j-f
Re: some work
Reply #166 on:
March 10, 2009, 09:58:08 am »
sorry to hear about your problems fabs.
perhaps shooting a small video clip would help for people here to help you?
good luck!
DVK ~
Re: some work
Reply #167 on:
March 14, 2009, 22:20:34 pm »
Quote from: 67-indeed/DVK on March 10, 2009, 09:58:08 am
good luck!
died here's a video from today
http://www.youtube.com/v/xP5PrXGlAGs
Re: some work
Reply #168 on:
March 14, 2009, 22:47:00 pm »
today i change the 4 spark plugs , and the spark plugs wire , the belt , I adjusted again valves and ignition
and With j-f we defused(unsettled) a stromberg (the right one) to blow him with the compressed air, then we went back up him and there....... no difference
except that the carbs on the right (the one we defused) seems to work correctly , and now the problem seems to come from the left carbs , of or I am going to defuse him and to blow him with the compressed air and to go back up him and if it does not work, I shall appeal to a knowledge which is specialized in the English cars and the English carburators
no one have a idea
Re: some work
Reply #169 on:
March 14, 2009, 23:13:06 pm »
Quote from: speedwell on March 14, 2009, 22:47:00 pm
no one have a idea
Why only "service" or "defuse" ONE carb
I would have just serviced the PAIR just to be on the safe side
I still think it sounds like an air leak
OR it might be worth checking the fuel pump - your one can be disassembled and "serviced" OR "defused"
Re: some work
Reply #170 on:
March 15, 2009, 09:24:16 am »
Fuel comes correctly, there is a clear filter and you see that it flows regularly.
We serviced just one because it became late and were hopping for an improvement. Bad luck
I'm also more thinking about an air leak. The right carb makes a "good" noise, but the left carb makes a different one.
Re: some work
Reply #171 on:
March 15, 2009, 14:21:30 pm »
Quote from: j-f on March 15, 2009, 09:24:16 am
I would suggest removing both carbs, manifolds, balance tube etc - Clean ALL sealing surfaces (also clean out the left carb properly) then refit everything with a SMALL amount of silicon sealant
Re: some work
Reply #172 on:
March 15, 2009, 19:41:36 pm »
That's the way we will take.
Today, some people also suggest to check a leak at the fuel pump.
I also wonder how to check the float level on this carbs? Needle valves are 1.5 but I don't know how to check if the carbs have the same float level? Same method as weber? And which height?
For the sealant I normally use a stick, like that.
Re: some work
Reply #173 on:
March 15, 2009, 20:36:23 pm »
i don't know if it help someone , but here's the fitting instruction from the sprintkit
and thx for the help guys i hope after cleaning the second carbs the problem will be resolved
fabs
Re: some work
Reply #174 on:
March 15, 2009, 20:37:07 pm »
Re: some work
Reply #175 on:
March 15, 2009, 20:41:40 pm »
i know that i don't have the right needles on my carbs , i need the 9x needle , this needle is for the 1200cc
Re: some work
Reply #176 on:
March 15, 2009, 20:42:49 pm »
Re: some work
Reply #177 on:
March 15, 2009, 20:47:31 pm »
Last Edit: March 15, 2009, 20:49:51 pm by speedwell
Re: some work
Reply #178 on:
March 15, 2009, 20:51:19 pm »
Re: some work
Reply #179 on:
March 16, 2009, 12:33:04 pm »
COOL old instruction dude
5
6
7
