June 10, 2026, 02:15:17 am
mvptkfjb
problem with mouse engine
Topic: problem with mouse engine (Read 10544 times)
Christoph
September 30, 2008, 13:28:49 pm »
hi guys,
i finished to build my first 1600cc engine, have rebuild a 30hp before, but never done a huge monster like this
specs:
1300 AB case
69 stock crank, lighten flywheel
85,5 mahle p/c
engle w110
74g scat lifters
heads with stock 35/32 valves, 9,5:1 compression and slightly worked inlet ports, rockers stock
full flow
weber 36 idf
hoped to get something between 70-80 hp, what would more than double my hp.
but now the problem:
-when i try to start the engine it only turned barely, it sounds like the piston(s) scraped in the cylinders, so i oiled them a little (what i´ve done before), but with no result.
-when there´re no plugs in the heads, the engine turns ok, but i think it should not be a compression problem
-had another starter checked.
-i had the engine runing (don´t know how) for about 2 minutes , after turning off (it was noon and my neighbours had killed me if i had run it longer) it wont start again.
maybe someone have an idea, before i take it apart, i don´t know where to search.
thanks
christoph
Rasser
Re: problem with mouse engine
September 30, 2008, 14:47:46 pm »
To little "end-play" on crank ?
1955 type1
1966 type2 13w deluxe
alex d
September 30, 2008, 15:13:10 pm »
can you turn it over by hand with a wrench?
in any case 9,5:1 sounds like a lot of CR for a W110
Rasser
September 30, 2008, 18:45:18 pm »
Quote from: alex d on September 30, 2008, 15:13:10 pm
sounds just about right to me (maybe 9:1 would be better ?)
Anyway - too high compression won´t have anything to do with the problems mentioned here.
Last Edit: September 30, 2008, 18:47:15 pm by Rasser DK
1955 type1
Christoph
September 30, 2008, 23:03:53 pm »
can turn it with a wrench and when the plugs are out it goes easy except of one or two areas.
i thought i could hear a quiet scraping on second cylinder. had the heads and cylinders removed, and on cylinder 2 i could see minor scarpings, all cylinders where dry like the desert, oiled them and put the pistons back in, when i turned the crank everything seems to work. cylinderheads back on and tried to start, but nothing happends.
when i try to fire the engine with the starter it seems that after some turns it goes heavier.
maybe no oil film between pistons/cylinders? but if so, how can i fix it?
Quote from: Rasser DK on September 30, 2008, 14:47:46 pm
you mean the axial clearance of the crank? i have rather to much as to less. had to find it out by trial and error(yeah, sounds really professionell
) but when i measured it out and put the 3 washers in the right dimension between crank/flywheel i had
no
clearance, the crank is stuck, normally i should have the needed 0,10mm. i had tried it many times and i know its technically impossible, but so it is. the crank is from an AB case, the flywheel 200mm 12v, so i think this should work together.
thought 9,5:1 would be ok, i will try to lower the compression maybe this wil work, but it ran in this combination, even if it was for 2 minutes.
christoph
Last Edit: September 30, 2008, 23:09:09 pm by Christoph
Wünderwolff
aka Dr. Jeckill
October 01, 2008, 06:44:44 am »
This might be a stupid comment. But then again I have been so stupid before to have appreciated this sort of comment several times. (imagine being an apprentice car mechanic, tinkering on your moped because it stalls, only to go in to a dealers workshop for them to fill the gastank and go
So, as your cranking speed is going down after a few turns, is your battery any good?
Wünderwaffe are Go!
October 01, 2008, 08:30:57 am »
Do you have the ground strap that comes from the chassis to the gearbox?
Christoph
October 01, 2008, 12:14:39 pm »
@ dr.jekill: batterie is ok. it´s not a stupid comment, i´m thankful for every thought, mostly it´s the easiest things you forget.
@j-f: the engine is on a selfbuild stand with an old bellhousing put on. both are connected so i thing i don´t need an extra ground strap?
christoph
Rasser
October 01, 2008, 16:11:58 pm »
Maybe your pressure plate/flywheel hits the inside of the bellhousing ?
Last Edit: October 01, 2008, 16:17:31 pm by Rasser DK
1955 type1
Christoph
October 01, 2008, 19:02:59 pm »
coming home from the garage and what should i say?
it´s alive!
i lowered the compression with 1mm rings between cylinder/heads and now it turns fast enough to get it started.
Thank you for your help guys!!!
christoph
October 02, 2008, 12:42:20 pm »
Was it a mis-calculation with the compression?
I did that once - worked the compression out afterwards as something like 13.4:1 instead of the intended 10.5:1!
Melted through a barrel and pushrod tube!
Christoph
October 02, 2008, 13:06:06 pm »
Quote from: Neil Davies on October 02, 2008, 12:42:20 pm
don´t know, but it seem so. maybe i should check the calculation for mistakes (if i can find it), but at the moment i´m really happy that it runs.
today afternoon i will try to syncronise the carbs and prepare everything for lifting the engine in the bug. damn i´m exited like a child on christmaseve
Silversoar
36 IDF's are they hard to work with?
October 06, 2008, 20:47:38 pm »
I've just put my allmost identcal 1600 in my bug but have som problems with my 36 idf.
Idle jets are now 52 but still missfire/popping on the low rpm, I like to call it lean but what do you guys think?
It drives wonderful over 3000rpm - strong and easy to handle and pulls to 6000+
Have you fitted the engine now?
What jets do you use?
Any problems
Christoph
October 06, 2008, 23:03:20 pm »
jets are:
main= 125
emulsion tube= f11
air= 175
idle= 50
fitted the engine this morning, there was more work then i expected and still some work to do. hope to run the car tomorrow or at lastest wedesday, can´t wait
October 09, 2008, 23:45:57 pm »
Assuming you had 9,5 before, then you have just lowered the CR to 8,5.
At 9,5 - 1 with a W110 cam it takes a stout starter to turn the engine, eventhough its "just" a 1600. But there are other variables.
Christoph
October 12, 2008, 23:16:40 pm »
finally the engine is in my car
and runs
the car runs better than i expected and its fun to drive. today we had 20°C and sunny weather so i had a real blast this afternoon and still can´t get the smile out of my face. now i´m hungry for more!
Christoph
October 12, 2008, 23:18:39 pm »
67worshipper
October 12, 2008, 23:27:04 pm »
nice little motor christoph.should be fun
vw hot rod heaven
