September 19, 2026, 03:35:23 am
Latest Member: Bad Habit
| | |-+  55mm trottlebodies or larger.
Author Topic: 55mm trottlebodies or larger.  (Read 10470 times)
bang
« on: September 30, 2008, 20:50:29 pm »
hey. looking for some 55 mm trottlebodies or larger who fit on my ida manifold. anyone run with the trottlebodies they sell at gene berg? what options do i have.
they are going on a 2779 oxyboxer with jp heads and alot of other goodies.
big bang racing
denmark
« Reply #1 on: September 30, 2008, 20:58:23 pm »
Large than 55 ? I think 55 is bigger than a 62 carbutator . I have a customer that has Berg's TWM 54 mm on a 2,8 Type 4 works well
bang
« Reply #2 on: September 30, 2008, 21:05:33 pm »
hey udo what ecu is he using.  thinking about a omex or electromotive.
Martin
Cash Converter....
« Reply #3 on: September 30, 2008, 21:11:51 pm »
you can get the 55mm throttle bodies from Jenvey. there real nice. i ran them on my 2910 motor. I sold them to Matt Keene he may still have them.
Martin
Martin
www.taylormachine.co.uk
OFF/500
bang
« Reply #4 on: September 30, 2008, 21:14:44 pm »
martin..
is that the once with idf patton you did run with. how was the power/torq curve conpaired to caps? and can you remember the price on them
sorry my bad english.
haldex201
« Reply #5 on: September 30, 2008, 23:13:26 pm »
Hi Bang.
Just my opion.
Why not try the F1 JPM throttlebodies i have seen them in the flow bench, i am very impressed. I am sure that Johannes can make them big and just right for your projekt.
Why go for the next best, when you can have the best.
Feed forward Go a head. Flow is just what you need to get the right power out of your projekt. OMEX 600 or 700 wil be perfekt, im going in to it for my projekt, if you need some one to talk it over with.
Best Regards
Haldex201
bang
« Reply #6 on: October 01, 2008, 15:36:35 pm »
haldex..
yes i know they are wery good and i have thought it over.. but think they are a bit expensive.. but cool.
yes got jp heads on now, why not get the hole set.. ;o)
what engine are you putting them on?..
mine is a 2779 oxy boxer with jpm heads, fk89 cam. 2"header and alot of other stuff..
Airspeed
« Reply #7 on: October 01, 2008, 17:37:42 pm »
Martin
Martin,
Were they individual TB's? as I didn't think Jenvey had larger than 50 or 52 on an IDF pattern...
haldex201
« Reply #8 on: October 01, 2008, 18:03:08 pm »
Hi Bang
My motor is 1998 CCM with MS 230.
Best Regards
Haldex201
« Reply #9 on: October 01, 2008, 18:52:04 pm »
They have an older Box from Tech... ! You can use what ever you want and can tune .
58vw
« Reply #10 on: October 01, 2008, 20:30:26 pm »
i have a set of the TVM 50mm throttle bodies (ida) with fuel rails and the SDS e4 system with the coil packs etc etc complete system. This was going on a 2854cc type 1 and would supply more than enough fuel for the engine.
www.4inbore.com
Angleflows...order them now
bang
« Reply #11 on: October 02, 2008, 09:13:47 am »
we. my freind and i also hawe a set of 51mm trottle bodies with halltech ecu and was thinking about playing with it. but it is an old system and dont know any who can trim it in.
RMS Boxer Service
« Reply #12 on: October 02, 2008, 10:23:11 am »
Hi Bang  Smiley
The Haltech ecu you're refering to is a F7 unit and it's VERY simple to program and alter values when fine tuning the system. I have the software too.  As far as I can tell the throttlebodies are from Hilborn. Bought them from Leif Nyström YEARS ago.
/Rolf
bang
« Reply #13 on: October 02, 2008, 14:19:35 pm »
right..
are in uk now and if i have some days of i will find a place to see the 55mm jenvey.
see you rolle
