November 02, 2026, 16:09:48 pm
| | |-+  Chevy or VW journals ?
Author Topic: Chevy or VW journals ?  (Read 19492 times)
69Stu
« on: October 01, 2008, 12:54:51 pm »
I am starting to collect parts for a new engine, most likely 2332.
Are there any benefits in using Chevy sized journals over VW size ones?
Does it make the crank stronger, or weaker?
I am planning on using a raised roof case, so I don't think that clearance will be too much of an issue inside the case.
Opinions please.
« Reply #1 on: October 01, 2008, 16:58:21 pm »
Larger jounals make the crank stronger because the main and rod journals share a larger cross section.
Airspeed
« Reply #2 on: October 01, 2008, 17:39:25 pm »
Opinions please.
With 84mm crank, the VW journals probably weaken the cam too much because you still to clearence the base circle of that.
« Reply #3 on: October 01, 2008, 17:47:01 pm »
Opinions please.
True, but how often does a cam snap? Usually a busted cam is the result of a thrown rod. Not being a smartass, just asking Wink
69Stu
« Reply #4 on: October 01, 2008, 19:46:24 pm »
I have allready got a pre-clearanced cam, am I likely to need to increase the clearance further if I use an VW rod journal?
And what about case clearance?
Paul Bate
« Reply #5 on: October 01, 2008, 20:32:45 pm »
Hello Stu,
I would recomend Chevy Journal it makes life a little easier go for a 5.500" rod and shoot for 60 thow rod to case clearence.
I hope this helps Kind regards Paul  Smiley
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
69Stu
« Reply #6 on: October 01, 2008, 21:48:19 pm »
Thanks for the advice. Smiley
« Reply #7 on: October 02, 2008, 16:55:34 pm »
If your H-beam rods have 3/8" bolts, it is unlikely you will be able to make a VW journal crank fit.  5/16" bolt rods can work.
69Stu
« Reply #8 on: October 02, 2008, 17:07:06 pm »
I was planning on using 3/8" bolts, so it looks like Chevy journals are my best option.
So to another question. At what point would you recomend going up to a Type 4 Centre main bearing?
Mike Lawless
« Reply #9 on: October 02, 2008, 17:38:04 pm »
Shouldn't need the type 4 center main until or unless you will be consistently above 7500 rpm or over 225 hp. At that point, you might as well go with all type 4 mains.
I don't think anyone offers a type 4 center main crank anymore do they? I know Bugpack's new stuff is all type one, and their new flanged crank is all type 4 (used to be type 4 center), and CB's have always been all type 1.
To have one welded to type 4 just doesn't make any sense in my mind.
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
69Stu
« Reply #10 on: October 03, 2008, 14:03:10 pm »
Scat's web site does actualy list their pro comp cranks as being available with a type 4 centre main.
But, this is for a street engine with occasional strip use, so I won't be turning 7500rpm that often, or producing that much power.
« Reply #11 on: October 03, 2008, 14:33:05 pm »
DPR can do a welded crank with Type 4 center main.
NoBars
« Reply #12 on: October 03, 2008, 22:45:30 pm »
Yeah, DPR just built me an all type 4 86 mm
John Rayburn
« Reply #13 on: October 04, 2008, 09:14:08 am »
My 84 / VW journal crank and H beam 5.5 rods take the same space as my old 78.4 stock rod combo. VW journal is much stronger and clearance on the cam is no problem for longevity.
I also park at Nick's.
« Reply #14 on: October 04, 2008, 22:07:33 pm »
i am taking notes here.
what rods do you use now?
John Rayburn
« Reply #15 on: October 05, 2008, 08:12:06 am »
They're 5.5 Eagle's.
69Stu
« Reply #16 on: October 05, 2008, 15:57:52 pm »
So how would the clearance of Eagle rod compaire with other brands of rod?
« Reply #17 on: October 05, 2008, 21:15:05 pm »
Depends on the bolts in the rods.  John's Eagle rods have 5/16" bolts.  Try to fit Scat rods with 3/8" bolts, not gonna fit.
