August 12, 2026, 00:10:01 am
|-+  Happenings
| |-+  Happenings
| | |-+  Our trip to Das Drag Day #6
Pages: 1 2 3 [4] Print
Author Topic: Our trip to Das Drag Day #6  (Read 74578 times)
Tekken
www.proturbovw.com
« Reply #90 on: October 11, 2008, 11:45:31 am »
what brand of valves are you using?
Martin
Those are Manley valves.
Rune
SCC Crew
Screwdrivers #7
« Reply #91 on: October 11, 2008, 14:48:38 pm »
Hey Tekken
thank you very much for the help with your Tools.So I can modify my new Valve Covers.And thank you to Rune for the Translation!!!
Glad I could help Jürgen. See you around.
charlie
« Reply #92 on: October 14, 2008, 22:19:10 pm »
Hi
What a very (long) nice trip .
My favorite picture of your car ,at the end of the track
Others pics of your car on my blog :
http://charlie48ida.skynetblogs.be/post/6287833/split-turbo-ddd6#comments
http://charlie48ida.skynetblogs.be/post/6284473/split-turbo-#comments
Cheers.
Tekken
www.proturbovw.com
« Reply #93 on: November 07, 2008, 17:49:39 pm »
A few pictures of my engine,besides the strange looking valve it looks good.. Wink
Tekken
www.proturbovw.com
« Reply #94 on: November 07, 2008, 17:50:31 pm »
 Angry
« Reply #95 on: November 07, 2008, 20:10:52 pm »
Looks like you got really lucky with so little damage,good luck with the repairs & upgrades!!  You are doing upgrades while its apart arent you Wink Cheesy
Tekken
www.proturbovw.com
« Reply #96 on: November 07, 2008, 20:36:48 pm »
Hey Richie,how are you!!
Yes,of course I'm doing some upgrades,I know you have a new and bigger engine going on.. Wink
« Reply #97 on: November 07, 2008, 23:51:44 pm »
all good here Smiley   You have to keep going dont you?any breakage should be viewed as a chance to improve something,and yes I have a couple of new engines to try,need to get some advantage to help the heavy car Cheesy
Looked like you had a good time travelling south to Bitburg
Airspeed
« Reply #98 on: November 08, 2008, 23:04:05 pm »
Wow! Alu rods and roller cam  Shocked
Do the rods have no si-bronze bearing for the piston pin? If not, what do the pins run on?
So thats what it takes to do a low 9 sec huh  Roll Eyes
No roller guide wear after x passes?
« Reply #99 on: November 09, 2008, 09:34:17 am »
Hi Stian
You had realy luck with this demage !! But i never saw a valve breaking there . I would change the rods , may be Don can tell you how long it can be used .
Regards from Karin also
Tekken
www.proturbovw.com
« Reply #100 on: November 10, 2008, 19:30:13 pm »
Hey Airspeed,yes those rods make all the difference between a high 10 and low 9's.. Wink There are no bearing for the piston pin,alu rods on turbo are also more forgivable if you for instance get knock or detonations.I have to measure both ends and magna flux for cracks each time they are out.If that is okay,then they should be good as Don Pauter said.But I have no experience with them except two seasons in my engine now,so I considre to change them just to be on the safe side.The roller guides still look good after two seasons now,when they get worn I just change them.I also measure my roller lifters and look for cracks each time. Smiley
Airspeed
« Reply #101 on: November 10, 2008, 22:01:22 pm »
Yeah, I can understand the quicker revving of the very light rotating mass would make boost come on sooner.
Speaking of which and if your willing to tell us, whats the max boost you run at?
Tekken
www.proturbovw.com
« Reply #102 on: November 10, 2008, 22:14:12 pm »
At the end of the season we ran approx 25psi,but had a lot of back pressure because of a too small turbo.New and bigger ball bearing turbo from PT going in for next season,and some modifications on the Holley carb to get more fuel.Looking forward to see how it works,just have to take it step by step..
Airspeed
« Reply #103 on: November 13, 2008, 22:33:33 pm »
Thanks Stian, great to hear you went so fast already with those boost figures.
Amazing to learn that that big turbo was actually too small!
Hope to see you go even faster. Very curieus what the difference will be.
Tnx again for the candid infos,
Walter
« Reply #104 on: November 13, 2008, 23:05:32 pm »
I think Stian needs some lightweight lifters and smaller springs . For a turbo engine there is no need for a roller cam !? May be he got some valve float with these heavy lifters and this is why the valve broke !
« Reply #105 on: November 14, 2008, 17:52:40 pm »
This is a good example for my opinion    http://www.thesamba.com/vw/classifieds/detail.php?id=689767
And the CSP engine !!
Martin
Cash Converter....
« Reply #106 on: November 14, 2008, 18:17:27 pm »
arnt they going onto a roller cam next?
dont you think you can go wilder with the roller cam Udo? Ive been studying cams for ages now and the advantages and disavantages of the rollers.
i keep going wilder with my cam and the power is still climbing. dont know if a flat tappet cam would have the same control at 9000 rpm. Keep thinking about putting the motor on a Spintron machine and try out difernt cams and springs.
open to any idea's views on this subject...
Martin.
Martin
www.taylormachine.co.uk
OFF/500
« Reply #107 on: November 15, 2008, 09:03:45 am »
Hi Martin
I think the red baron and CSP 34 have good power  Wink
Tekken
www.proturbovw.com
« Reply #108 on: November 17, 2008, 11:45:55 am »
Yes,I'm sure a flat tapped cam would have worked more than enough for me.The thing is,I had already had the welded and reinforced Autocraft case, together with the rest of the engine parts to build a pro stock engine.Marty and I made a deal, and traded some parts that could'nt be used in the turbo application.
Martin
Cash Converter....
« Reply #109 on: November 17, 2008, 12:22:28 pm »
Hi Martin
thats why im so interested in the subject, im having to use 700lb springs to control my valves. The V8 prostock engine builders ive been talking to about the subject say my springs are a little soft for my cam spec !!!!  you should see the size of pushrods im having to use to cope with the loads.
I did have valve float with 500lb at 7200 rpm. now the motor is happy all the way to 9000 rpm, no float so far.
Thats why I'd like to compare both setups on a Spintron
This subject could have a thread of its own, sorry for the thread jack!
Martin
OFF/500
Tekken
www.proturbovw.com
« Reply #110 on: November 17, 2008, 13:31:40 pm »
[/quote]
I agree Martin,we should make one.As you know I'm also really interested in idea's views on this subject-thanks.
« Reply #111 on: November 17, 2008, 19:39:52 pm »
Martin can start a new thread , but i think it was part of Stians trip to take a look at my work and learn only to use lightweight valve train parts   Wink . and now it is too late for Stian to go back to a flat tappert cam and light lifters  Cheesy
mr horsepower
« Reply #112 on: January 06, 2009, 22:24:11 pm »
Hi Stian
Hi udo is it not so that alu rods size on higher rpm s an a hotter combustion and the copper head gasked shrinks when get hotter
to seal better ?
GREETS HENRI.
(PS owner of asmall green car also)
« Reply #113 on: January 26, 2009, 20:31:30 pm »
Hi Stian
to seal better ?
GREETS HENRI.
Hi
sorry i never used alu rods . Don't have any experience
PS (green cars are nice ) :-)
« Last Edit: January 26, 2009, 20:33:50 pm by Udo » Logged
