November 02, 2026, 21:22:04 pm
| | |-+  Case cleaning
Author Topic: Case cleaning  (Read 10642 times)
airstuff
« on: October 08, 2008, 14:56:39 pm »
What do you guys reccomend for cleaning out the new case,which is full of debris and swarfs from machining??
Water+solvent,or??  Shocked
tikimadness
« Reply #1 on: October 08, 2008, 15:24:55 pm »
I would go to  machineshop and have them wash it in a washingmachine.I go to a local shop here in holland and they charge me 5 euro for 15 minutes.
Michael
NIDGAFWYT
« Reply #2 on: October 08, 2008, 15:47:05 pm »
Michael
Or put it in your dishwasher at home  Wink Smiley
« Reply #3 on: October 08, 2008, 16:17:58 pm »
deburr all the sharp edges and tangs out with a rotary file and a sanding roll, first. Then I wash it out with hot soap (dishwashing) and very hot water, then blast with compressed air, then spray with lacquer thinner, then blow with compressed air again.
« Reply #4 on: October 08, 2008, 16:21:44 pm »
I did the same as Jim,
but i have the galley plugs taken out and replaced
« Reply #5 on: October 08, 2008, 16:27:02 pm »
except Sheep's case. I just set it out side in the rain and then let the Santa Ana Winds blow it clean in my backyard.
« Reply #6 on: October 08, 2008, 18:10:34 pm »
that works, remember to turn it upside down once in a while. it adds 'panache' to the whole thing.
airstuff
« Reply #7 on: October 08, 2008, 18:29:35 pm »
why to use lacquer thinner,what does it help out? Huh
« Reply #8 on: October 08, 2008, 18:32:52 pm »
cuts any oils, residue, film left on case. if it is a previously run case, lacquer thinner will cut sealant on case halves too! It works well for a parts cleaner. Just make sure you have ventilation and wear gloves.
I typically wash all engine parts with hot water and strong dishwashing soap then blow dry thoroughly, then spray with lacquer thinner then blow again.
sheep
« Reply #9 on: October 09, 2008, 04:03:30 am »
 Angry Angry Angry Angry Angry Angry Angry Angry Angry Angry Angry
unless it has wheels,tits or fins I dont care
John Rayburn
« Reply #10 on: October 09, 2008, 06:32:29 am »
Jim, who's case was that you had suspended in the swimming pool? Some little girl kept sticking her chewing gum on it.
I also park at Nick's.
« Reply #11 on: October 12, 2008, 20:24:46 pm »
Do what Jim does... Then have it sonic cleaned, Then do again what Jim does. And clean it again.
