November 02, 2026, 23:22:35 pm
Case cleaning
Topic: Case cleaning (Read 10645 times)
airstuff
Case cleaning
October 08, 2008, 14:56:39 pm »
What do you guys reccomend for cleaning out the new case,which is full of debris and swarfs from machining??
Water+solvent,or??
tikimadness
Re: Case cleaning
October 08, 2008, 15:24:55 pm »
I would go to machineshop and have them wash it in a washingmachine.I go to a local shop here in holland and they charge me 5 euro for 15 minutes.
Michael
NIDGAFWYT
Re: Case cleaning
October 08, 2008, 15:47:05 pm »
Quote from: tikimadness on October 08, 2008, 15:24:55 pm
Michael
Or put it in your dishwasher at home
Re: Case cleaning
October 08, 2008, 16:17:58 pm »
deburr all the sharp edges and tangs out with a rotary file and a sanding roll, first. Then I wash it out with hot soap (dishwashing) and very hot water, then blast with compressed air, then spray with lacquer thinner, then blow with compressed air again.
Re: Case cleaning
October 08, 2008, 16:21:44 pm »
I did the same as Jim,
but i have the galley plugs taken out and replaced
Re: Case cleaning
October 08, 2008, 16:27:02 pm »
Quote from: Jim Ratto on October 08, 2008, 16:17:58 pm
except Sheep's case. I just set it out side in the rain and then let the Santa Ana Winds blow it clean in my backyard.
Re: Case cleaning
October 08, 2008, 18:10:34 pm »
Quote from: Jim Ratto on October 08, 2008, 16:27:02 pm
that works, remember to turn it upside down once in a while. it adds 'panache' to the whole thing.
airstuff
Re: Case cleaning
October 08, 2008, 18:29:35 pm »
why to use lacquer thinner,what does it help out?
Re: Case cleaning
October 08, 2008, 18:32:52 pm »
Quote from: cal-look on October 08, 2008, 18:29:35 pm
cuts any oils, residue, film left on case. if it is a previously run case, lacquer thinner will cut sealant on case halves too! It works well for a parts cleaner. Just make sure you have ventilation and wear gloves.
I typically wash all engine parts with hot water and strong dishwashing soap then blow dry thoroughly, then spray with lacquer thinner then blow again.
sheep
Re: Case cleaning
October 09, 2008, 04:03:30 am »
unless it has wheels,tits or fins I dont care
John Rayburn
Re: Case cleaning
October 09, 2008, 06:32:29 am »
Jim, who's case was that you had suspended in the swimming pool? Some little girl kept sticking her chewing gum on it.
I also park at Nick's.
Re: Case cleaning
October 12, 2008, 20:24:46 pm »
Do what Jim does... Then have it sonic cleaned, Then do again what Jim does. And clean it again.
