September 22, 2026, 12:50:54 pm
| | |-+  after the autometer gasgauge, now the vdo gasgauge topic :-)
Author Topic: after the autometer gasgauge, now the vdo gasgauge topic :-)  (Read 4067 times)
wolfswest
« on: October 11, 2008, 19:03:06 pm »
I tried to hook up some gauges tonight and also tried to connect the vdo gas gauge of the jet cockpit series.  My sender is an original vw sender for a 72 model.  It works but it works otherwise.  my tank is for 1/4 filled and the vdo gauge tells me it is 3/4 filled...  Huh  Any clues how I can fix this or what do I need to buy?
thx
Dem
« Reply #1 on: October 12, 2008, 00:58:17 am »
Hmm good topic dude   Wink Smiley
wolfswest
« Reply #2 on: October 12, 2008, 13:14:34 pm »
 Cheesy  I connected all the gauges yesterday just to see if they worked...  everything looks okay and I finetuned the tacho.  The rpm's where 300 rpm lower that it should be, but I found the problem.  If you want more info Lee send me a pb, because there is A LOT to do if you want the tacho to work fine!
Nobody that can help Lee and me out with this gasgauge problem?  Undecided
