June 10, 2026, 08:45:03 am
352170 Posts in 28909 Topics by 6919 Members
Latest Member: mvptkfjb
| | |-+  autometer temp and pressure sender.
Author Topic: autometer temp and pressure sender.  (Read 13418 times)
67worshipper
« on: October 18, 2008, 13:03:34 pm »
im looking to install oil temp and oil pressure gauges from autometer.im looking for a sender that does both off the same sender.ive looked but cant find one.ive seen people running both and the engine bay suggests its coming from the same sender.any help would be good cheers guys.
vw hot rod heaven
benssp
www.callookvw.com
« Reply #1 on: October 18, 2008, 15:23:28 pm »
I have the two seperate senders on a T-piece, don't think they do a sender that accomodates both. Grin
www.vwheritage.com  My Job
YMCA
67worshipper
« Reply #2 on: October 18, 2008, 19:42:02 pm »
what bits have you got then ben and where did you get them?
vw hot rod heaven
Roman
« Reply #3 on: October 18, 2008, 20:36:10 pm »
Drill and tap the sump for the temp sender and take a T-piece from the stock pressure switch for the pressure sender.
I have a cheap "biltema" T-piece, but you should be able to get it from ang hi perf store.
bang
« Reply #4 on: October 18, 2008, 20:49:17 pm »
try demon tweeks uk they got the stuff..  Roll Eyes
Rocket Ron
It's old school for a reason
« Reply #5 on: October 19, 2008, 08:56:02 am »
I've got my pressure sender on a tee piece withe the oil light and and the temp tapped on the fillter mount
hope this helps
13.12 @ 101.84
Grooving out on life
67worshipper
« Reply #6 on: October 19, 2008, 20:50:53 pm »
got any pics ron?
vw hot rod heaven
LuftsickTero
« Reply #7 on: October 20, 2008, 06:44:33 am »
I've got pretty much the same setup including the "bilhelvete" Grin t-piece but I am not sure how accurate the temp gauge readings are as the wind beneath the car must cool the sump and the sender Huh (even that the sender is facing to rear of the car)
« Last Edit: October 20, 2008, 06:46:10 am by LuftsickTero » Logged
benssp
www.callookvw.com
« Reply #8 on: October 20, 2008, 08:06:17 am »
I've got an Autometer temp and pressure gauge, If you've got a deep sump you could probably drill and tap it to fit the temp sender Grin
YMCA
Rocket Ron
« Reply #9 on: October 20, 2008, 10:29:25 am »
got any pics ron?
try to get some tonight
13.12 @ 101.84
benssp
www.callookvw.com
« Reply #10 on: October 20, 2008, 10:49:55 am »
you could use this http://www.jegs.com/p/Moroso/746564/10002/-1 the black one. you could fit this where your full flow comes out of the case and fit the temp sender Grin
YMCA
wolfswest
« Reply #11 on: October 20, 2008, 13:07:46 pm »
http://cgi.ebay.com/ebaymotors/VDO-Oil-Pressure-Temp-Sender-Tee-Fitting_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem370098721535QQitemZ370098721535
this is what I used with my autometer senders, worked perfect, I still use it today with my vdo senders, same way, simple and effective...
Rocket Ron
« Reply #12 on: October 20, 2008, 14:51:32 pm »
Thats what i'm using for the pressure sender
Then for the temp, just drill and tap the fillter mount, making sure the tip of the sender is in the oil.
13.12 @ 101.84
67worshipper
« Reply #13 on: October 21, 2008, 21:31:57 pm »
thanks boys for all the input.food for thought Wink
vw hot rod heaven
