July 03, 2026, 03:19:41 am
352216 Posts in 28927 Topics by 6921 Members
Latest Member: bigsiembowski
| | |-+  check your pulleys
Author Topic: check your pulleys  (Read 10740 times)
Rocket Ron
It's old school for a reason
« on: October 24, 2008, 21:03:43 pm »
Check your pulleys guys. this happend the other day
Bit of a close one   Sad
13.12 @ 101.84
Grooving out on life
benssp
www.callookvw.com
« Reply #1 on: October 24, 2008, 21:19:44 pm »
find yourself a genuine one, the belt will flip before it will explode Sad
www.vwheritage.com  My Job
YMCA
« Reply #2 on: October 24, 2008, 21:29:58 pm »
OEM 043 903 109 = $61.05!! Shocked Shocked Shocked  Don't forget your 10 shims...
Rocket Ron
« Reply #3 on: October 24, 2008, 21:37:11 pm »
I've ordered an Aluminium one with a one piece back pulley so no spot wields
the one in the photo is a scat one I think, it was stamped USA.
counted the shims off, it had ten  Cry
13.12 @ 101.84
benssp
www.callookvw.com
« Reply #4 on: October 24, 2008, 21:40:09 pm »
We ran out about 6 months ago,think flat 4 had a load. we have the oem ones with the fan on the back, ok with an alternator, a killer on a dynamo!
YMCA
« Reply #5 on: October 24, 2008, 22:57:08 pm »
Just looked at VOA warehouse stock... there's 207 at the local depot and onesie twosie's at the the other five depots across the country.  Now you can see where all the "players" are... Wink Grin
benssp
www.callookvw.com
« Reply #6 on: October 24, 2008, 23:01:33 pm »
any 111-813-301/G's in group stock? Grin
YMCA
« Reply #7 on: October 24, 2008, 23:05:17 pm »
Yeah, they're next to those Ghia convertable variant bodies KS had me lookin' for last month  Roll Eyes Grin
« Reply #8 on: October 27, 2008, 14:45:10 pm »
Hi Ron,
Did it break while in use?
Hope it didnt do any damage.
Rocket Ron
« Reply #9 on: October 27, 2008, 15:26:21 pm »
Hi Ron,
Yep was driving at the time, managed to catch it in time before it went off.
I was lucky it didnt go off, it could have been alot more expensive. I've had to replace the alternator as well as the pulley   Sad
Are you going to Flame and thunder, I may go if I can sort out my oil filter leak / fillter splitting problem  Cry
13.12 @ 101.84
« Reply #10 on: October 27, 2008, 15:27:21 pm »
Have a CLOSE look at this pic of my friends 63 just after we pulled into EBI1 - notice anything funny Huh
The Pulley EXPLODED about 5 miles before this pic! Half of it was stiil stuck in the vent area above the engine bay!
« Reply #11 on: October 27, 2008, 15:35:43 pm »
Hi Ron,
Hi Ron,
These 2276cc motors are fun arent they Undecided
Im going to Flame and Thunder, had a small problem with one of my IDA's. The nut on the spindle had worked loose which then came off completely so awaiting bits to repair. God knows how it was still running 12's!
Chin up, as they say. Be good to see you and the bug again.
Rocket Ron
« Reply #12 on: October 27, 2008, 15:55:38 pm »
Hi Ron,
Hi Ron,
Be good to see you again and how far down the 12 you can get. Wink
I didnt realise that alternator pulleys were such a problem, I thought it was just fans that that went bang, but talking to a few people it seems quite common   Undecided
13.12 @ 101.84
benssp
www.callookvw.com
« Reply #13 on: October 27, 2008, 16:07:56 pm »
Paul Bate is another casualty of the exploded pulley, went through the lid on the way to Ebi Grin
YMCA
« Reply #14 on: October 27, 2008, 16:22:57 pm »
I was about to mention his one - By the way Ron the crack/break in your pulley looks IDENTICAL to my friends - a fault in manufacture maybe   Undecided Huh
I will try and post a couple of pic's  Smiley
Rocket Ron
« Reply #15 on: October 27, 2008, 17:32:11 pm »
just don’t think they’re up to 6000 pm plus, 4 small spot wields cant be enough to hold it on Embarrassed
13.12 @ 101.84
« Reply #16 on: October 27, 2008, 17:39:36 pm »
4 spot welds Huh ours was a volkswagen item and as far as I know Pauls was a Porsche item  Undecided Smiley
Rocket Ron
« Reply #17 on: October 27, 2008, 17:46:54 pm »
I think my pulley was a scat item, the front half had USA stamped on it
13.12 @ 101.84
benssp
www.callookvw.com
« Reply #18 on: October 27, 2008, 18:11:53 pm »
Turn your back on Taiwan will you Grin
YMCA
Rocket Ron
« Reply #19 on: October 28, 2008, 13:38:17 pm »
you know I wouldnt do that
I just cant stop buying from SSP Kiss
13.12 @ 101.84
airstuff
« Reply #20 on: October 28, 2008, 14:05:15 pm »
o good,I will surely use an old Oem pulley on my 2276
H67bug
« Reply #21 on: October 29, 2008, 22:42:56 pm »
I had a porsche one from KK as well and it cracked. Also had signs of wear on a normal sized aftermarket one. Switched to genuine one and so far so good.
« Reply #22 on: November 01, 2008, 01:13:35 am »
Ron
That is a Bugpack one with USA stamped into it,not Scat,
it really looks like there was another issue there,why is the edge so damaged where you would hold it to stop it turning when tightening? or is that a shadow in the picture? it looks like you had a problem tightening it maybe?
i have an aftermarket one on my car of unknown origin and its seen plenty of 8000+rpm over the last 8 years with out any problems so they can work ok Smiley
« Reply #23 on: November 01, 2008, 01:56:04 am »
Ron
Like you say its very much luck of the draw - ours looked like it all ready had a crack and rust had got in and caused it to fail (Stand offs fitted Roll Eyes) I think as long as you know the "history" of the pulley you are using and don't damage it when you fit it - I think you should be ok - I have several original stashed away  Wink Smiley
Rocket Ron
« Reply #24 on: November 01, 2008, 13:24:39 pm »
Ron
Hi Richie
not sure about the damage to the pulley on the corners as I've only tightened it once since putting the engine in as it been running sweet as a nut, but when it did go, it pretty much took out the front of the alternator and the trailing egde on the pulley really dug in.
I havent got it now as it went in the bin but I think the crack started on one of the spot welds and ran in between the two notches
I've now bought an billet pulley so no spot welds as the whole back pulley is one piece and I'll give that a go. what do you think of these Huh
It looks like its not that rare a failure ,like monkiboy said just been unlucky I guess.
Ron
13.12 @ 101.84
« Reply #25 on: November 01, 2008, 18:41:24 pm »
Sometimes sh*t happens,hopefully it will all be good now Smiley
