September 22, 2026, 14:56:40 pm
How much castor??
Topic: How much castor?? (Read 7569 times)
kev d
How much castor??
October 27, 2008, 22:08:28 pm »
How much castor is the ideal amount to aim for when setting up a front end on a drag car?
How many deg. do you get with a set of shims?
Cheers,
Kev
Re: How much castor??
October 28, 2008, 09:59:29 am »
Depending heavily on top speed. But begin with 5 to 5,5
November 06, 2008, 13:11:18 pm »
Kev, I ran 2 sets of shims on my car, with 13" front wheels. Always felt very stable. It's probably better to have too much than not enought!
kev d
November 06, 2008, 17:43:39 pm »
Cheers Neil
Martin
Cash Converter....
November 06, 2008, 17:44:53 pm »
Hi Kev,
Depends on the rake your running, the more rake, the more castor you have to run to correct the rake (to get it back to stock).
I look to get 7deg's total. lovely and stable at 145 mph.
Set your car up how you want to run then use a castor gauge to measure the castor and shim to suite.
Martin
Martin
www.taylormachine.co.uk
OFF/500
kev d
November 06, 2008, 23:21:15 pm »
Cheers for the advice again
Sweet67
November 13, 2008, 05:50:07 am »
In my chassis car, Ron at RLR put on 6 degrees. 6-8 degrees was a mentioned as a good setting.
November 13, 2008, 08:40:56 am »
90 degrees works – makes the car very stable. Slow, but very stable, and a bitch to turn.
November 13, 2008, 09:40:54 am »
Quote from: Fastbrit on November 13, 2008, 08:40:56 am
Take every word he says with a pinch of salt... he just want to make sure no one is faster than him when he gets his new car done.
kev d
November 15, 2008, 10:03:42 am »
Quote from: BeetleBug on November 13, 2008, 09:40:54 am
Surely its more `if` than `when`...
November 15, 2008, 10:30:44 am »
Quote from: kev d on November 15, 2008, 10:03:42 am
How true...
