June 10, 2026, 02:06:51 am
Latest Member: mvptkfjb
| | |-+  UN1 gearbox for drag...
Author Topic: UN1 gearbox for drag...  (Read 9447 times)
JLaw
« on: November 03, 2008, 21:13:39 pm »
Hi im looking for some information about fitting the renault un1 gearbox to a bug. I have heard that there in a green european bug that used to run type 4 turbo i think now runs subaru engine that has a UN1 box. It runs nines if im correct. anyone got any info about this subject?
Cheers John.
tikimadness
« Reply #1 on: November 03, 2008, 21:34:59 pm »
Cheers John.
Hi John,
The guy you mean is Robert Jongen www.rojoracing.com
He was running a UN1 with the diff welded to use as a spool.I am using a UN1 now in my oval.
It is a lot of work to get one to fit but it works .
You have to cut up the torsionbar in the middle because of the length of the UN1 and make custom brackets.You also need an adaptorplate to mount a T25 bellhousing to the UN1.
The rest is straight forward.
If you want I can post some pics of my car.
Michael
NIDGAFWYT
JLaw
« Reply #2 on: November 03, 2008, 22:32:42 pm »
Michael,
Thanks for the info and I'd love to see any pics of your build up! I have a very solid original 63 that I am planning the work for, I have a few of the un1 boxes available too, which did you decide to use as there are a few different ratios available. I am thinking the renault 25 turbo or atmo gta alpine final drives maybe be best, what are your thoughts?
I know the boxes are very strong but have you found any weaknesses in the design? I am hoping to drag race with the box and I dont want to have to keep rebuilding boxes. what have you done about axles etc? I would be very appriciative of any advice.
How did you go about the adaptor plate, did you machine something up yourself?
Cheers, John.
tikimadness
« Reply #3 on: November 05, 2008, 22:31:10 pm »
I will post pictures tomorow Wink
Michael
NIDGAFWYT
mychatype3
« Reply #4 on: November 06, 2008, 13:41:05 pm »
Michael,
Cheers, John.
Hello John,
Send a e-mail to info@deboxer.nl he can help you with a adaptor plate (he has them in stock  Wink)
Greetings mycha
1968 fastback "in resto"
Airspeed
« Reply #5 on: November 06, 2008, 19:41:28 pm »
Cheers John.
He runs the 9's with a porsche 930 box FYI. That 930 tranny is converted to sequential shifting and has straight gears. i think his box is more expensive then his engine, which also had a lot of work done to it...
fahrvergnugen
« Reply #6 on: November 14, 2008, 12:51:47 pm »
Michael
10 day's later Angry PICTURES
