September 13, 2026, 07:14:15 am
352305 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  zx or xzx
Author Topic: zx or xzx  (Read 10312 times)
banditina
« on: November 04, 2008, 13:07:19 pm »
hi...
i have brm 5"
i would like mount michelin zx but there are only 135 sr 15...
is bettere michelin xzx 145 sr 15???
i love zx because xzx are different.... Cry
tnx
2manytoys
« Reply #1 on: November 04, 2008, 17:26:19 pm »
I would run the 145. More tire width and a more comfortable ride,..but not by much. It would be safer too. 135 is nice for a compact spare,..but that JMO
Patrick Friel -..2manytoys, not enough time or money
yvre
Der Autobahn Scrapers
« Reply #2 on: November 04, 2008, 18:35:01 pm »
ZX is for a 2CV... XZX is where it's at.
« Reply #3 on: November 05, 2008, 15:01:36 pm »
For me it's all about what you can find. I'd go for the XZX purely because I prefer the tread pattern, but if I couldn't find them then I'd get the ZX. Width-wise, it would have to be the 145 on a 5" rim - 135's should only go on a 3.5" Centerline or Erco IMHO.
« Reply #4 on: November 05, 2008, 15:13:05 pm »
XZX 145's for sure.... not much for handling, but they look right.
« Reply #5 on: November 05, 2008, 17:51:13 pm »
Chalk another one up for the XZX's
LuftsickTero
« Reply #6 on: November 06, 2008, 17:22:58 pm »
So what's better handling 135/145 sized front tyre then? Firestone? I've only run ZXZs due to easy availability..
« Reply #7 on: November 07, 2008, 13:48:35 pm »
I think we said about this a while ago - I prefer the Michelins over the F560 Firestones. I find the Michelins grip better, but I have only ever run them on balljoint cars (my '60 got written off before I fitted the wheels). Tim C said the opposite but he ran them on linkpin.
« Reply #8 on: November 07, 2008, 15:01:50 pm »
Neither of those sizes are what I'd call "handling" tires.... they're "Cal Look" tires Wink.  To get handling, you need tires with an aspec ratio (a percentage of the tires height is subtracted and added to it's width ie 155/50x15), but over here, these types of tires are hard to come by and if things aren't quite right with the front end set-up, may rub.  Then there's rim width... a 145 stretched out over a 5" wide Flat Four BRM looks um, stretched...the tread is narrower then the wheel width, so that would be even worse with a 135 on the same rim.  It's impossible to get a tire to "handle" in a situation like that.   As for the Michelin / Firestone debate, I'll take the Michelins.
« Reply #9 on: November 07, 2008, 16:46:56 pm »
Possibly because of the balljoint front end on your car, Sarge? Smiley
