July 26, 2026, 01:17:33 am
zx or xzx
Topic: zx or xzx (Read 9955 times)
banditina
zx or xzx
November 04, 2008, 13:07:19 pm »
hi...
i have brm 5"
i would like mount michelin zx but there are only 135 sr 15...
is bettere michelin xzx 145 sr 15???
i love zx because xzx are different....
tnx
www.stinkingass.blogspot.com
http://die-kriegs-maschine.blogspot.com
http://www.oldclan.it
IF YOU THINK YOU'RE TOUGH INSULT A KAFERMAN!
2manytoys
Re: zx or xzx
November 04, 2008, 17:26:19 pm »
I would run the 145. More tire width and a more comfortable ride,..but not by much. It would be safer too. 135 is nice for a compact spare,..but that JMO
yvre
Der Autobahn Scrapers
Re: zx or xzx
November 04, 2008, 18:35:01 pm »
ZX is for a 2CV... XZX is where it's at.
Re: zx or xzx
November 05, 2008, 15:01:36 pm »
For me it's all about what you can find. I'd go for the XZX purely because I prefer the tread pattern, but if I couldn't find them then I'd get the ZX. Width-wise, it would have to be the 145 on a 5" rim - 135's should only go on a 3.5" Centerline or Erco IMHO.
Re: zx or xzx
November 05, 2008, 15:13:05 pm »
XZX 145's for sure.... not much for handling, but they look right.
Re: zx or xzx
November 05, 2008, 17:51:13 pm »
Chalk another one up for the XZX's
LuftsickTero
Re: zx or xzx
November 06, 2008, 17:22:58 pm »
Quote from: Sarge on November 05, 2008, 15:13:05 pm
So what's better handling 135/145 sized front tyre then? Firestone? I've only run ZXZs due to easy availability..
Cal&Resto
| Publishing own mediocre Cal Look photos since 1995 in interwebs.
Re: zx or xzx
November 07, 2008, 13:48:35 pm »
Quote from: LuftsickTero on November 06, 2008, 17:22:58 pm
I think we said about this a while ago - I prefer the Michelins over the F560 Firestones. I find the Michelins grip better, but I have only ever run them on balljoint cars (my '60 got written off before I fitted the wheels). Tim C said the opposite but he ran them on linkpin.
Re: zx or xzx
November 07, 2008, 15:01:50 pm »
Neither of those sizes are what I'd call "handling" tires.... they're "Cal Look" tires
. To get handling, you need tires with an aspec ratio (a percentage of the tires height is subtracted and added to it's width ie 155/50x15), but over here, these types of tires are hard to come by and if things aren't quite right with the front end set-up, may rub. Then there's rim width... a 145 stretched out over a 5" wide Flat Four BRM looks um, stretched...the tread is narrower then the wheel width, so that would be even worse with a 135 on the same rim. It's impossible to get a tire to "handle" in a situation like that. As for the Michelin / Firestone debate, I'll take the Michelins.
Re: zx or xzx
November 07, 2008, 16:46:56 pm »
Quote from: Sarge on November 07, 2008, 15:01:50 pm
Possibly because of the balljoint front end on your car, Sarge?
