November 02, 2026, 22:18:20 pm
| | |-+  old skool cams - any ideas?????
Author Topic: old skool cams - any ideas?????  (Read 36030 times)
« on: November 09, 2008, 18:53:20 pm »
Well guys as the title says - OLD SKOOL CAMS - Lets here your thoughts  Smiley
I am in the planning stages of my engine for PROJECT 66 which Mr Keene is putting together for me Smiley
Its based around an 82mm SPG Roller Crank with a set of 92's (2180cc) with an original Rimco case that was especially clearenced for an SPG crank, I have also lined up a COOL pair of real old skool 70's heads with 42x35.5 valves  Grin
So my question is: WHAT OLD SKOOL CAM WOULD YOU USE AND WHY  Huh
I look forward to hearing what you think  Smiley
P.S I DONT WANT A LOAD OF POST TELLING ME NOT TO USE THE SPG - I AM USING IT AND THAT IS THAT  Wink Smiley
Martin Greaves
10.88@128.58
« Reply #1 on: November 09, 2008, 18:54:59 pm »
No Lee don't use the SPG  Grin
« Reply #2 on: November 09, 2008, 19:08:07 pm »
Engle 130 or 140
« Reply #3 on: November 09, 2008, 19:18:51 pm »
Engle 130 with 1.25's - correct  Huh Smiley
A 140seems alittle hairy for a "street car"  Shocked Smiley
« Reply #4 on: November 10, 2008, 02:23:46 am »
E100
folkevogn
« Reply #5 on: November 10, 2008, 09:56:07 am »
What happened to the "WHY" part of Lee`s question? Wink
11.96 @ 180kmh - SCC 2013 Grin
« Reply #6 on: November 10, 2008, 10:05:35 am »
K-8 and i don't know why, but bergs engine was same CC and that cam. 12,?? on the strip.
« Reply #7 on: November 10, 2008, 12:45:59 pm »
Hi Nicolas
With that crank i would not use a bigger cam , if you make Rpm's it will not work . Sorry to say that but it is so . Old school is fine but don't use parts that do not work good .
« Reply #8 on: November 10, 2008, 13:11:48 pm »
Hi Nicolas
because off the SPG crank breaking?
Bewitched666
Bewitched
« Reply #9 on: November 10, 2008, 13:27:42 pm »
W120 with 1.25 rockers or w110 with standard rockers Cool
Fast vw beetle's rule
« Reply #10 on: November 10, 2008, 14:00:25 pm »
Hi Nicolas
Please explain  Huh Undecided Smiley
« Reply #11 on: November 10, 2008, 14:01:09 pm »
I was wondering that too  Wink
« Reply #12 on: November 10, 2008, 14:43:50 pm »
what about lil woper?
i think it turns some rpm Smiley
« Reply #13 on: November 10, 2008, 19:53:37 pm »
Isn't that the whole point of a roller crank? So it revs like there is no tomorrow??
« Reply #14 on: November 10, 2008, 20:37:48 pm »
These cranks are not strong enough for big motors . they bend , break ... ! The bearings are not good for this applications . I only did one engine with this and it did not last long  Sad
« Reply #15 on: November 10, 2008, 21:11:43 pm »
Going with super light JE pistons will give the crank a easier life... and perhaps a extremely light flywheel can be a good idea to avoid flexing of the crank?
« Reply #16 on: November 10, 2008, 21:53:57 pm »
THANKYOU Zach Wink Smiley
As I said before NO ONE is going to talk me out of this engine (Richie has tried his hardest trust me Wink) - its just something I have ALWAYS wanted to do, I know ALL the risks thats why the roller crank is being FULLY stripped and rebuilt with NEW needle rollers, it is also being PINNED and WELDED, as well as having an original GERMAN flywheel WEDGEMATED to it - I am only gonna be running 185's on the back of the 66 and I don't plan on launching it at 7k on a set of 7inch pheniox slicks Wink Smiley
Right now we have all that out the way lets get back to CAMS - Which would you run and why Huh
« Reply #17 on: November 10, 2008, 22:20:30 pm »
Before choose a cam, choose the use you will really have of the car.
If you plan to use it as a cruiser with some adrenalin shoot from time to time or a street warrior I think you will not have the same cam choice.
And  I think that the W serie from Engle is use since the 70's. A w125 seems to be a good all around cam if you read what the guru write on this forum.  Cool
« Reply #18 on: November 10, 2008, 23:17:43 pm »
"a street warrior" you know me dude thats EXACTLY what she's gonna be  Wink Smiley
Matt did sugest the W120 with 1.25 rockers - you see to be real old skool i can only use 1.25's  Undecided Smiley
« Reply #19 on: November 10, 2008, 23:22:52 pm »
I'd run stock rockers. I don't think many street cars from the old days were running ratio rockers, though Sarge could answer for sure. I think Mahaffey had a W130 in his split.
Carlos has an Engle 140 in his car and it idles and pulls like silk.
Or to be real old "skool" modify up some Porsche 356 or GLAS rockers, like Gene Berg did.  Grin
are you going to run close gears?
« Last Edit: November 10, 2008, 23:35:58 pm by Jim Ratto » Logged
« Reply #20 on: November 10, 2008, 23:44:13 pm »
Hmmm interesting...... I see what yourr saying about ratio'd rockers BUT don't you "need" them with certain cams Undecided Huh
And yes it will have pretty close gears but I am toying with a 5 speed but I am building the engine first then build a box to suit the power curves etc  Smiley
« Reply #21 on: November 10, 2008, 23:55:04 pm »
FK series cams are made to run 1.4 or 1.5
W-series were for stock rockers, although later, 1.25's were added in some cases.
Is a 5 speed old 'skool' though Lee? Not trying to start anything, but if you are trying to build a car that would allow you to travel back in time...very cool....  you'd want to run short-geared 4 speed and Crown solid mounts and go deaf!  Grin
« Reply #22 on: November 11, 2008, 00:07:33 am »
this would be cool, Lee
92 DDS big bores
82 SPG
AH or AE or older case (but not an H or F)
Engle W130 stock VW lifters
311 stock heads, welded with square intakes, 40mm x 35.5mm, dual Norris springs and aluminum retainers
Stock rockers on modified stock shafts (full circle circlips instead of stock hairpins)
Porsche adjusters
10.0:1
Autostick pump
Berg magnesium sump
EMPI IDA manifolds, 48IDAs (stud type), 37mm venturies, 155main, 130 air, F2 emulsion, 70 idle jet
Four Tuned competition 1-1/2” header with glasspack
Vertex magneto locked up by Cirelllo’s
40hp stale air shroud
6v generator
Early Berg linkage or Speedwell (with brace down generator plate)
« Reply #23 on: November 11, 2008, 00:43:56 am »
92 DDS big bores
82 SPG
Porsche adjusters
10.0:1
Autostick pump
Berg magnesium sump
6v generator
Hmm interesting but........
" Its based around an 82mm SPG Roller Crank with a set of 92's (2180cc) with an original Rimco case that was especially clearenced for an SPG crank, I have also lined up a COOL pair of real old skool 70's heads with 42x35.5 valves"
The 92's are also "old skool" but of unknown make - most of these parts come from an old drag/racing engine built back in the late 70's/early 80's but was never run/used
I have also lined up an original Thunderbird 1 1/2" header and original dual quiet packs  Shocked Smiley
I'll also be running a modified/custom "brazilian" Fanhousing with chrome backing plate........
I'm giving away way too much here - anyway here is a sneeky peek at the COOOOOOOOOOOL heads  Wink Smiley
« Last Edit: November 11, 2008, 00:47:05 am by monkiboy » Logged
« Reply #24 on: November 14, 2008, 23:41:09 pm »
So any more thoughts on a Cam  Huh Smiley
« Reply #25 on: November 14, 2008, 23:50:13 pm »
130. Lets hear that motor sing!! Grin
« Reply #26 on: November 14, 2008, 23:52:57 pm »
I agree.
How is car geared Lee?
Martin Greaves
10.88@128.58
« Reply #27 on: November 14, 2008, 23:54:56 pm »
Just been think about this i had a 2180cc with a W125 in my old 66bug. 1st time out i run a 14.6 and by the time i took out my tent and the rest of my camping gear i got a 13.9 1/4. Grin
« Reply #28 on: November 15, 2008, 01:21:53 am »
I agree.
I am gearing the car to the motor - I thought it was best  Undecided Smiley
Hmmmm interesting  Wink Smiley
What about rockers though guys  Huh
« Reply #29 on: November 15, 2008, 01:26:31 am »
yes gears and motor should ideally match
I still say use stock rocker arms, Lee.
