October 13, 2026, 00:33:44 am
| | |-+  My >street/<strip '56
Pages: 1 ... 14 15 [16] 17 18 ... 28 Print
Author Topic: My >street/<strip '56  (Read 923825 times)
fahrvergnugen
« Reply #450 on: May 07, 2011, 20:22:53 pm »
my goal is to make the welds close to invisible.
If you do that then nobody can see them
That's the idea Wink
fahrvergnugen
« Reply #451 on: May 21, 2011, 20:01:50 pm »
Today I started on making the anti rollbar brackets, This Anti rollbar started it's live on a pink "killer Kitty" opel.
Paul.
fahrvergnugen
« Reply #452 on: May 25, 2011, 20:05:44 pm »
First fitment test of the anti-rollbar, I think it needs a little modifications.
Paul.
fahrvergnugen
« Reply #453 on: May 28, 2011, 20:40:54 pm »
Did some sway-bar work today
Welded the new sway-bar brackets to the upper front axle tube, narrowed the tube to the chassis head width and closed the end of the tube, this way I have some strenght in the brackets and still have the original body mounts.
Test with 90deg. turned uniball.
The 90deg. turned uniball works great, so I made a new bracket (needs some more welding).
Put the grommet in and did a new test. The movement I can make without hitting anything is much bigger as the movement the shockabsorber can make.
Paul.
fahrvergnugen
« Reply #454 on: May 29, 2011, 18:23:09 pm »
Bought myself a nice donor body, this '58 Will speed things up Cool
Paul.
fahrvergnugen
« Reply #455 on: June 03, 2011, 21:03:31 pm »
Right side of the sway bar is now ready too.
To make sure all the fittings of the fuel line are ok, I checked them with some air pressure.
On original oval has special floormat fasteners, so I welded these back on the floor.
Paul.
« Reply #456 on: June 03, 2011, 21:16:08 pm »
Is that a stock steering box? Wouldn't a rack & pinion be easier at this stage, and more benificial?
fahrvergnugen
« Reply #457 on: June 03, 2011, 21:34:01 pm »
Hi Zach,
I did this because i could not find a rack&pinion with the wright width. the points where the A-arms rotate are very close to eachother, so to avoid bumb steer I made this set-up.
On one side there is an original steering box and on the other side there's an extra arm (1303) that follows the moves of the steeringbox.
Do you still follow me.
Paul.
« Reply #458 on: June 03, 2011, 21:56:51 pm »
Got it Wink
Black Sheep
less is more
« Reply #459 on: June 04, 2011, 18:13:14 pm »
Paul.
The devils in the detail  Cool Cool
13.03 @ 98mph
fahrvergnugen
« Reply #460 on: June 04, 2011, 21:04:42 pm »
 Wink
fahrvergnugen
« Reply #461 on: June 05, 2011, 19:29:57 pm »
Picked up the '58 donor for the oval today.
Looking good.
And a bus full of rust free '58 goodies
It's almost a shame to cut this to pieces, but it will happen. :twisted:
Paul.
Wout
« Reply #462 on: June 05, 2011, 19:46:07 pm »
Was thinking the same  Tongue.
Good luck with the build!
gr
Wout
Aircooled vw's for life!
fahrvergnugen
« Reply #463 on: June 15, 2011, 19:49:32 pm »
Time to take out the old grinder again Shocked. I really need the parts for my oval, but still it was difficult to cut up this nice '58.
No way back now.
Paul.
« Reply #464 on: June 15, 2011, 19:57:52 pm »
 Cry sad to see that  Cry
fahrvergnugen
« Reply #465 on: June 15, 2011, 20:02:54 pm »
His soul will live on.
fahrvergnugen
« Reply #466 on: June 19, 2011, 19:32:17 pm »
After a lot of drilling, the dash is out.
Paul.
fahrvergnugen
« Reply #467 on: July 09, 2011, 21:31:18 pm »
the EBI weekend was superb, but now it is oval time again.
Al the old repairs are cut out of the donor front and today I started cleaning the underside of it.
This is a very good piece of German metal. Smiley
Paul.
kev d
« Reply #468 on: July 09, 2011, 22:05:39 pm »
Good work Paul Cool
Any more donor body's like that turn up can you give me a shout? Wink
Kev
mr horsepower
« Reply #469 on: July 09, 2011, 22:46:37 pm »
Paul are you stil feeling good ?
and is my oval save in my garage or should i put it behind bars  and lock it for the KASTANATOR??
I ll already sended  a sms alert to the near dub pre 67 owners  Wink
henri
fahrvergnugen
« Reply #470 on: July 10, 2011, 19:25:32 pm »
Good work Paul Cool
Kev
It's just a rust free '58, nothing special Grin
fahrvergnugen
« Reply #471 on: July 10, 2011, 19:27:58 pm »
henri
Better watch it, nothing pré '60 is save for my grinder Cheesy
Paul.
fahrvergnugen
« Reply #472 on: July 16, 2011, 15:05:49 pm »
Finally did something visible again.
Complete parafan removed.
Took a wile to find the currage, but it had to be done.
Both doorpillars removed :shock:  :shock:
Paul.
fahrvergnugen
« Reply #473 on: July 20, 2011, 20:11:04 pm »
a few holes.
Looked at an original , never welded body and then circled all the original holes. The rest has to be welded.
How it should be.
After storage for many years, this all original (only the exhaust cutouts are not original), rust free and never welded oval is my workshop neighbour. now i can check it if I need to know how things should be. (i am not aloud to touch it Grin)
Paul.
« Last Edit: July 20, 2011, 20:22:33 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #474 on: July 23, 2011, 20:19:32 pm »
Some times little things take so much time Angry
The frontshield corners and the fresh air vents where pretty bad.
After some drilling, grinding, hammering, cleaning and trail fitting. I am halve Way there.
Paul.
fahrvergnugen
« Reply #475 on: August 27, 2011, 21:03:25 pm »
Damn, i was on page 2. time for a little update Grin
Replaced the right windshield heater thing and repaired the left one.
In the past someone drilled a lot of holes in this car, today I fixed it. This is a difficult to reach area, so while I was in there I might as well bare metal it.
Paul.
« Last Edit: August 27, 2011, 21:06:26 pm by fahrvergnugen » Logged
kev d
« Reply #476 on: September 04, 2011, 18:57:43 pm »
Thats a load of work Paul but you're getting there!
Any more of those rust free oval shells going spare?? Grin
Kev
fahrvergnugen
« Reply #477 on: September 04, 2011, 19:45:09 pm »
Kev
Hi Kev, yes I have had better jobs before Tongue
If i find a shell laying around, I'll let you know.
Paul.
fahrvergnugen
« Reply #478 on: September 07, 2011, 20:32:37 pm »
Getting close Cool
Paul.
fahrvergnugen
« Reply #479 on: September 11, 2011, 18:44:07 pm »
Satrting to look good.
Right side is getting there as well.
Paul.
