October 12, 2026, 08:44:10 am
| | |-+  My >street/<strip '56
Pages: 1 2 3 [4] 5 6 ... 28 Print
Author Topic: My >street/<strip '56  (Read 922010 times)
fahrvergnugen
« Reply #90 on: May 20, 2009, 21:45:26 pm »
Nice piece of work,good job!  Wink
Thanks, I am pretty pleased with it myself.
Paul.
fahrvergnugen
« Reply #91 on: May 23, 2009, 20:58:07 pm »
Not much of an update this time.
Mounted the gearbox and trailerarms to see how it all fits. the trunk floor will be raised by +/-2,5 inch, this way I have room for the gearbox, rollcage and coilovers.
Paul
fahrvergnugen
« Reply #92 on: May 27, 2009, 20:32:05 pm »
The rear is narrowed quit a bit, and I did not whant to fuck up the inner wings.
Here's the plan, widen the mounts where the inner wings are bolted to the pan.
Paul.
tikimadness
« Reply #93 on: May 27, 2009, 21:05:23 pm »
Hey dude you are making it way too heavy.Now you really need a big hairdryer Grin Tongue
Michael
NIDGAFWYT
fahrvergnugen
« Reply #94 on: May 28, 2009, 06:44:56 am »
Michael
It's getting pretty heavy indeed, first I am making it save and driveble then it's engine time. Wink
This is a STREET/strip car, 1/4 mile must be fast but first I have to drive 300KM's to get there Cool
Cheers, Paul.
fahrvergnugen
« Reply #95 on: May 31, 2009, 19:53:28 pm »
Here are a few pic's of yesterday morning.
1) Started with widening the right innerwing mount.
2) Then I had to make the inside of the rearshock mounts flat so that i could weld a pipe there.
Paul
« Last Edit: June 07, 2009, 14:44:29 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #96 on: May 31, 2009, 19:54:39 pm »
3) Bend a pipe to go over the gearbox an welded it in.
4) started to try an shock mount idea.
Paul.
fahrvergnugen
« Reply #97 on: June 03, 2009, 20:51:58 pm »
Worked on a new idea again. I do not have the framehorns anymore but I still need something to mount the gearbox to.
Under the gearbox is no space with the IRS points this close to eachother and over the gearbox is difficult with the starter and coilovers.
This new set-up combines the framehorn replacements and shock mounts. the framehorn replacements will be attached to the cage (in the trunk area)
I am still thinking about this set-up, not sure it will stay.
Paul.
« Last Edit: June 03, 2009, 20:55:35 pm by fahrvergnugen » Logged
tikimadness
« Reply #98 on: June 03, 2009, 21:00:26 pm »
I think the upper mounting point for the coilover is too much forward to be able to work properly. Wink
Why don't you get a hi-torq starter,they are shorter and lighter and leave you more room for the shocks.
Michael
NIDGAFWYT
fahrvergnugen
« Reply #99 on: June 03, 2009, 21:20:17 pm »
Michael
You could be wright Undecided, in a few minutes I am going to bed and think of this plan some more Grin.
Between pleasing the wife and a little sleep, the best palns are made Grin
Paul.
ESH
« Reply #100 on: June 05, 2009, 11:10:43 am »
... Between pleasing the wife and a little sleep, the best palns are made ...
Way too much information there!  Shocked
That said it's starting to take shape and's looking good for it.  Smiley
fahrvergnugen
« Reply #101 on: June 05, 2009, 11:32:04 am »
If this is too much, don't search you tube Grin
Thanks, Paul.
ESH
« Reply #102 on: June 05, 2009, 11:43:35 am »
... If this is too much, don't search you tube ...
 Shocked
 Grin
fahrvergnugen
« Reply #103 on: June 07, 2009, 14:33:42 pm »
Bin working on the gearbox mount some more. Made new upper pipes and changed the pipe that goes under de bellhouse, made some gearbox height adjusters with left & right thread and tacked it all together.
Paul.
« Last Edit: June 07, 2009, 14:40:20 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #104 on: June 08, 2009, 20:02:43 pm »
My MM special IRS bolts are in, thanks Marco.
Paul.
Wout
« Reply #105 on: June 08, 2009, 23:12:13 pm »
Nice!
Couldn't you use the Porsche ones? We did and it works fine.
Good luck with the project!!!
gr
Wout
Aircooled vw's for life!
fahrvergnugen
« Reply #106 on: June 09, 2009, 09:00:47 am »
Nice!
gr
Wout
Don't know wich porsche bolts you mean, I don't think that porsche had an eccentric set-up like this.
Paul.
Wout
« Reply #107 on: June 09, 2009, 23:42:05 pm »
They look like regular ones (not with the extra disc on it), but they're exentric. As far as I know they're from a 944.
I'll try to take a picture tomorow.
gr
Wout
fahrvergnugen
« Reply #108 on: June 14, 2009, 14:05:32 pm »
Started on the upper shock mounts, there will be several mounting points so that i can choose wich one is the best set-up.
When i am completly satisfied I will weld them in there final position.
Also fitted the IRS bolts that I bought from Marco, Never tought that there was this much adjustment possible with these bolts Cool
Paul.
fahrvergnugen
« Reply #109 on: June 17, 2009, 20:56:48 pm »
And again I worked on the rear shocks, it's almost getting boring Tongue
Drilled holes to mount the top with bolts, I will drill some more holes to choose the right set-up.
Then made a bracket to mount the bottom of the shocks in the right angle.
Don't mind the temporary bolts Embarrassed
Paul.
fahrvergnugen
« Reply #110 on: July 08, 2009, 20:33:56 pm »
After a 2 week holiday in the south of France and an even more exhaustive weekend at EBI#3, I found a little time for the car again.
First fitted the hi-tork starter that i ordered i the USA.
Made the lower shock mount for the right coilover and picked-up a piece for the new front suspension.
Paul.
« Last Edit: July 08, 2009, 20:41:44 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #111 on: July 10, 2009, 20:36:50 pm »
Today I finnished welding the rear construction on all the reachable points, took out the gearbox and trailing arms, fliped the pan and welded the rest.
Time for the next project; Porsche 914 frontsuspension with 944 brakes mounted on a '56 pan Shocked.
Paul
Black Sheep
less is more
« Reply #112 on: July 13, 2009, 20:20:37 pm »
Now this I want to see
13.03 @ 98mph
fahrvergnugen
« Reply #113 on: July 13, 2009, 20:50:11 pm »
Stay tuned and you'll see  Wink.
Already did some measurements and it does looks better as I thought.
First I have to machine the 944 hubs to fit the 914 spindles. (it seems that the spindles have the same measurements as my type1 1300 spindles)
Here's how to modify the spindles to accept bug beerings. Cool sorry, it's dutch Embarrassed
Paul.
Black Sheep
less is more
« Reply #114 on: July 13, 2009, 20:58:32 pm »
Cool , Im looking forward to seeing how your gonna get the Mcfearson stuts to work on the oval inner wing's .
13.03 @ 98mph
fahrvergnugen
« Reply #115 on: July 13, 2009, 21:11:33 pm »
They are not Mcphearson stuts, that are the shocks, the tubes pointing forewards are the torsion bars (in the lenght of the car) Same as early 911's Cool.
I use the original front of the 914 to check measurements.
Black Sheep
less is more
« Reply #116 on: July 13, 2009, 21:56:23 pm »
Sorry my mistake forgive my ignorance  Roll Eyes
13.03 @ 98mph
jamiep_jamiep
« Reply #117 on: July 15, 2009, 08:33:07 am »
Wow!
You're crazy.... in a good way!!! Nice work....
 Cool Shocked Grin
smurf67
« Reply #118 on: July 15, 2009, 09:07:15 am »
Amazing work awsome looking project, Alex
fahrvergnugen
« Reply #119 on: July 16, 2009, 11:26:06 am »
Wow!
 Cool Shocked Grin
I'll take that as a compliment Wink Thanks.
I like to do things different and I had an almost complete 914 laying around Cool
Paul.
