October 12, 2026, 09:14:35 am
Pages: 1 2 [3] 4 5 ... 28 Print
Author Topic: My >street/<strip '56  (Read 922120 times)
fahrvergnugen
« Reply #60 on: April 15, 2009, 16:04:25 pm »
Yesterday I started cleaning the barn I was renting for 20 years.
I found a lot of nice (porsche) goodies for my project oval Cool
Yesterday evening I started fitting the gearbox, to have a measurement point i welded the horns back in place.
Tha plan is to mount the gearbox a bit lower and further in the car.
fahrvergnugen
« Reply #61 on: April 15, 2009, 19:50:34 pm »
Just won a pedal assembly on ebay Grin
tikimadness
« Reply #62 on: April 15, 2009, 19:57:40 pm »
Hey did you see that you have to hang them in order to operate them?
Michael
NIDGAFWYT
fahrvergnugen
« Reply #63 on: April 15, 2009, 20:05:48 pm »
Michael
Yes i did, but I will fix it Wink
Paul.
fahrvergnugen
« Reply #64 on: April 18, 2009, 21:15:27 pm »
Today I started where I left off the last time "fitting the gaerbox", after I took out half the axle tube, a piece of the IRS mounting point and grinding some unused gearbox ribs, the gearbox is in it's final place.
de framehorns are gone again and the gearbox is fixed with some temporary supports.
Then I started fixing a support that goes under the bellhouse, I used original rubbers for measuring but in the future they will be replaced for the strong yellow type.
The last picture shows how I plan to mount it to the cage, this way I can do some small hight adjustments.
Paul.
« Last Edit: April 18, 2009, 21:16:58 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #65 on: April 25, 2009, 19:50:50 pm »
After I was happy with the angle of the IRS brackets, I started welding the back.
To make the gearbox fit I had to cut a piece of the right IRS bracket. In the first, second and third pic. I am closing the piece that I earlier cut out.
This pic. also shows that the torsiontube is cut in half and the holes where the the frame horn use to be.
The fourt pic. shows that the torsiontube is welded shut.
Paul.
fahrvergnugen
« Reply #66 on: April 25, 2009, 19:53:57 pm »
In this last pic's you can see that the holes where the frame horn use to be are shut.
Paul.
fahrvergnugen
« Reply #67 on: April 29, 2009, 20:18:48 pm »
Turned the pan yesterday to do some welding on the underside.
I welded the IRS brackets on the inside, welded the middle of the torsion tube, welded the torsion tubes where they were narrowed and welded the holes where the framehorns use to be.
I had some T2a motorrubbers laying around, so I thought wy not use them to mount the gearbox.
First I made a cardboard bracket.
Paul.
fahrvergnugen
« Reply #68 on: April 29, 2009, 20:28:28 pm »
Made the brackets for the gearboxrubbers out of steel and tackwelded one of them.
Paul
fahrvergnugen
« Reply #69 on: May 02, 2009, 18:42:26 pm »
Today I finished the brackets for the gearbox rubbers and welded them to the torsion tube.
Then started to fabricate the bracket that goes on the gearbox, but that's not ready for pictures yet.
Paul.
fahrvergnugen
« Reply #70 on: May 02, 2009, 18:47:10 pm »
The US of A pakage is finally arived Cool
thehanz DVK
« Reply #71 on: May 02, 2009, 19:04:53 pm »
looking good paul....nice plans... Grin i like to see all those mod's
fahrvergnugen
« Reply #72 on: May 02, 2009, 19:42:09 pm »
Thanks Hans,
I will show you mine, if you show me yours? Grin
Paul.
« Last Edit: May 03, 2009, 11:43:06 am by fahrvergnugen » Logged
fahrvergnugen
« Reply #73 on: May 03, 2009, 11:47:59 am »
Good help is hard to find now a day's, but help is on it's way. Cool
Black Sheep
less is more
« Reply #74 on: May 03, 2009, 12:24:10 pm »
A work in progress then  Cheesy
13.03 @ 98mph
tikimadness
« Reply #75 on: May 03, 2009, 12:27:56 pm »
I hope he won't be jinxing your stuff,he looks pretty mean Grin Grin
Michael
NIDGAFWYT
fahrvergnugen
« Reply #76 on: May 03, 2009, 15:27:16 pm »
Quote
Michael
He is now at the chapter; how can I brake it before my dad can fix it. Grin I must say, he is pretty good at it. Cheesy
Paul.
fahrvergnugen
« Reply #77 on: May 06, 2009, 19:43:19 pm »
The left side of the new gearbox nose bracket is finished, next on the list is the right side and then weld L+R together into one bracket.
Paul.
fahrvergnugen
« Reply #78 on: May 09, 2009, 20:56:05 pm »
The leftside of the gearbox bracket was ready but I still wasn't happy with it. today I gave it some weight saving treatment Grin, now it's finished.
Then i took out an extra little peice of the right IRS mount, now the gearbox is clear.
ALso started with the rightside of the gearbox bracket. When this is ready I will weld Left and right together and also fix it to the top of the gearbox, this way I have one bracket that is fixed to the gearbox with 6 bolts and I finaly get rit of the rustet bracket.
Paul
cal-look 56
« Reply #79 on: May 09, 2009, 21:13:51 pm »
Are you not going to use framehorns Paul?  What will support the weight of motor/trans?
fahrvergnugen
« Reply #80 on: May 09, 2009, 21:20:58 pm »
No framehorns, the gearbox will be hanging on the rollcage, and the motor will have an extra mount to the rear bumper bolts.
Paul.
« Last Edit: May 09, 2009, 21:23:26 pm by fahrvergnugen » Logged
cal-look 56
« Reply #81 on: May 09, 2009, 21:33:40 pm »
OH, is that what thats for. I must have missed some of this thread. Lips Sealed
fahrvergnugen
« Reply #82 on: May 13, 2009, 19:25:11 pm »
Again someone at the door with a package Cool
A plastic batterybox and a main/safety switch.
Paul.
fahrvergnugen
« Reply #83 on: May 17, 2009, 07:26:32 am »
Did some work on the gearbox mount again yesterday.
I was not satisfied with the rubbers I used, so I had to modify the mounts to make the new rubbers fit.
Also welded the left and rightside together and removed the rusty bracket. Just need to fix the top of the gearbox mount and then it's finaly ready Tongue
Time for the next step. Cool
mychatype3
« Reply #84 on: May 17, 2009, 21:12:59 pm »
looking good, very nice bracket "profi"  Wink
1968 fastback "in resto"
fahrvergnugen
« Reply #85 on: May 18, 2009, 06:40:46 am »
Thanx It's almost ready and with a bit of powder coat it will look like it left the factory with this bracket Cool
Paul.
mychatype3
« Reply #86 on: May 19, 2009, 11:38:35 am »
Paul.
I love power coating  Grin
fahrvergnugen
« Reply #87 on: May 20, 2009, 20:21:38 pm »
Paul.
I can use all the power I can find Cheesy Grin
fahrvergnugen
« Reply #88 on: May 20, 2009, 20:22:54 pm »
Finaly the gearbox mount is ready, now I can move to the next step (cage and coilovers)
Cheers Paul.
« Last Edit: May 20, 2009, 20:24:56 pm by fahrvergnugen » Logged
« Reply #89 on: May 20, 2009, 21:39:10 pm »
Nice piece of work,good job!  Wink
