October 12, 2026, 15:30:46 pm
My >street/<strip '56
6
7
8
9
28
Topic: My >street/<strip '56 (Read 922839 times)
fahrvergnugen
Re: My >street/<strip '56
Reply #180 on:
September 06, 2009, 12:45:23 pm »
Quote from: Josef on September 06, 2009, 10:33:01 am
Nice project!!
When I look at your work and your innovations it motivates me to go on with my plan för my car.
/Josef
Thanks Jozef,
Sometimes you need some motivation, I usualy get it at DDD, EBI etc.
Can we see your project somewhere, Always nice to see other projects
Cheers Paul.
http://fast-air.skynetblogs.be/
Josef
Reply #181 on:
September 06, 2009, 13:08:09 pm »
I have som photos from my project but they are taken before the digital era.
If I got the time i will try to make them digital.
New pics will be posted under my "Sleeping beauty" thread.
/Josef
fahrvergnugen
Reply #182 on:
September 06, 2009, 19:18:02 pm »
Quote from: Josef on September 06, 2009, 13:08:09 pm
/Josef
Oh, Is that your trhead.
I will keep my eye on that one.
fahrvergnugen
Reply #183 on:
September 12, 2009, 20:39:25 pm »
Today it was time to start with the steering.
The plan is to use a 1303 pivot to avoid bumbsteer. First I had to make a steeringbox arm fit the pivot, to do this I used a piece of an old steeringbox axle.
Last Edit: September 12, 2009, 20:41:13 pm by fahrvergnugen
fahrvergnugen
Reply #184 on:
September 12, 2009, 20:50:30 pm »
Time to try some things
Welded a piece of pipe to the framehead and bolted the steering box, the steering rod is exactly horizontal and perpendicular to the chassis.
Also tacked the pivot in place, the plan is to connect the pivot with the steeringbox, and have a smal rod to the spindles.
Paul.
Reply #185 on:
September 13, 2009, 05:22:28 am »
Quote from: fahrvergnugen on September 12, 2009, 20:50:30 pm
Paul.
Why not use a Rack & Pinion instead of a stock steering box?
fahrvergnugen
Reply #186 on:
September 13, 2009, 10:02:16 am »
Quote from: Shubee2 (DSK) on September 13, 2009, 05:22:28 am
This way I can make the width exactly as I want it to be, an original rack&pinion will be to big, I want the place where the rods are attached to the steering box exactly above the center of the circle that the wheels make when they move up and down.
Paul.
Sven/DFL
Reply #187 on:
September 20, 2009, 13:32:08 pm »
Hey Paul,
Realy nice work! Very impressiv! I´m looking forward to see some more pictures!!!
Sven
fahrvergnugen
Reply #188 on:
September 21, 2009, 11:34:37 am »
Quote from: Sven/DFL on September 20, 2009, 13:32:08 pm
Hey Paul,
Sven
Thanks Sven,
As soon as I have time to work on it, I will post again.
Paul.
fahrvergnugen
Reply #189 on:
September 23, 2009, 20:27:29 pm »
between drinking beer, smoking sigarets en talking about DDD#7 (couldn't be there this year
), I found a little time for the oval.
Made a longer pipe to mount the steering box at one side and the pivot on the other side, and welded it in place.
It needs some more work, but it's a start.
Paul
fahrvergnugen
Reply #190 on:
September 26, 2009, 19:42:36 pm »
Did some more work on the steering today. To make sure I can remove the pivot when the car is finished, I drilled the trhead out of the pivot and welded nuts on the pivot bracket, This way it is bolted from the outside. Then I shortend the two short steering rods by cutting more thread and then cut it the wright lenght. The longer (middle) rod is cut in the middle, shortend and, after I put in some massive stee,l welded together again.
Hope it works
Reply #191 on:
September 27, 2009, 02:11:44 am »
Quote from: fahrvergnugen on September 26, 2009, 19:42:36 pm
Did some more work on the steering today. To make sure I can remove the pivot when the car is finished, I drilled the thread out of the pivot and welded nuts on the pivot bracket, This way it is bolted from the outside. Then I shortend the two short steering rods by cutting more thread and then cut it the wright length. The longer (middle) rod is cut in the middle, shortend and, after I put in some massive steel,l welded together again.
Hope it works
Wouldn't it be better to flip the pass side arm with the tall side in? that way the Wheels turn the same and it would center the center link evenly??
fahrvergnugen
Reply #192 on:
September 27, 2009, 08:35:16 am »
After looking at my own pic's I was thinking the same, probebly do that
Cheers, Paul.
fahrvergnugen
Reply #193 on:
October 03, 2009, 15:08:28 pm »
I wasn't satisfied with the steering (the rod came in line with the spindle wile the wheels should steer some more), so today I cut out the beam where the steeringbox was mounted on, and placed it further to the front of the car. Now, even when I steer al te way, the rod still has an angle with the spindel.
Paul.
mychatype3
Reply #194 on:
October 04, 2009, 06:19:11 am »
He Paulskie,
hello from the usa, looks good
Greetings mycha
1968 fastback "in resto"
fahrvergnugen
Reply #195 on:
October 04, 2009, 13:00:01 pm »
Quote from: mychatype3 on October 04, 2009, 06:19:11 am
He Paulskie,
Greetings mycha
Thanks Mych,
How's Vegas?
Paul.
fahrvergnugen
Reply #196 on:
October 10, 2009, 14:18:09 pm »
While I am still waiting on the last parts for the front suspension, I started with the gearshift system.
I am using a 901 box with the selecter on the undersite of the box, that is why I was thinking to use a cable shift system.
I bought a VW Corrado shifter, and today I started trying some things, it's not finished but you'll get the idea.
fahrvergnugen
Reply #197 on:
October 15, 2009, 20:09:07 pm »
Did some more work on the shifting today.
Made two brackets and installed them, needs some adjusting but I think it can work
Paul.
fahrvergnugen
Reply #198 on:
October 23, 2009, 20:33:20 pm »
When the car is ready I will probebly run it with my type4 2.0 120HP engine, this egine runs very well and is ready to go.
But in the near future I (offcourse) want to be faster, and because the car is not one off the shell the motor also will be different.
So I started collecting some parts;
WBX 1.9 engine.
Megasquirt motor management system.
A probebly to small turbo (golf 1.8 20V)
Water to air intercooler from a Mercedes
Porsche 964 100mm nikasil P/C
Scat split-ports with twin spark (airplane)
And lost of small parts.
Paul.
Last Edit: October 23, 2009, 21:52:29 pm by fahrvergnugen
tikimadness
Reply #199 on:
October 23, 2009, 21:02:36 pm »
Hey paul how are you going to make all those different parts to work together?
Put everything in a kettle and cook it for half an hour and see what will come out?
Seriuosly you bought xsome nice stuff hope it will work together.
Michael
NIDGAFWYT
fahrvergnugen
Reply #200 on:
October 23, 2009, 21:49:40 pm »
Quote from: tikimadness on October 23, 2009, 21:02:36 pm
Michael
Don't these parts fit
I thougt it was a plug and play thing, you say it's more plug, pray run and hide
sam P
Reply #201 on:
October 24, 2009, 00:27:16 am »
Wow, those heads look like they've got some serious potential! Lose the twin spark and get some bigger valves in there!
Love what you're doing. Not an easy project. Good luck!
fahrvergnugen
Reply #202 on:
October 24, 2009, 12:06:08 pm »
Quote from: sam P on October 24, 2009, 00:27:16 am
The valve size is 40 and 35,5mm i think it's good for a 2,1 turbo.
It's not easy indeed, but it's nice to try something different
Paul.
fahrvergnugen
Reply #203 on:
October 26, 2009, 20:59:13 pm »
Today a bought an 2,1 WBX engine, just for the 76,4mm crank
So the new engine will be a 2,4
Paul.
fahrvergnugen
Reply #204 on:
October 26, 2009, 21:01:58 pm »
Together with my 100mm Porsche nickies this will make a verry nice 2,4
Paul.
warp
Reply #205 on:
October 28, 2009, 12:43:37 pm »
How do you plan to cool the heads when driving on the street? ...not a lot of cooling fins on those things
/Jacob
fahrvergnugen
Reply #206 on:
October 28, 2009, 16:50:31 pm »
Quote from: warp on October 28, 2009, 12:43:37 pm
/Jacob
Not sure yet, when i have them in my hands (the are still in the USA) i'll see.
Paul.
fahrvergnugen
Reply #207 on:
October 31, 2009, 21:39:42 pm »
Quote from: fahrvergnugen on October 26, 2009, 21:01:58 pm
Paul.
This is how the cranck looks like at the moment.
fahrvergnugen
Reply #208 on:
October 31, 2009, 21:44:52 pm »
This week I picked up the brackets to mount the front brakes, and today I put them on.
Paul.
Last Edit: October 31, 2009, 21:47:36 pm by fahrvergnugen
JSL
Reply #209 on:
November 02, 2009, 16:08:20 pm »
Love it!!
Still following this thread like a hawk! ;-)
Where did you get the caliper brackets made up? Would it be cool to PM me some details?
Awesome stuff!!!
J
56 Bug Rat-look
http://www.volkszone.com/VZi/showthread.php?t=583273
54 Bug Cal-look Project
http://cal-look.no/lounge/index.php/topic,9879.0.html
Lil'turbo engine project
Defcon-3
http://www.defcon-3.co.uk
6
7
8
9
28
